Search:
Welcome to ClubCivic
What causes white smoke in the exhaust?
Responding Members:
User Tag List
Old 04-27-2010, 04:40 PM   #1
CiViC_eK24
CiViC_eK24's Avatar
Default What causes white smoke in the exhaust?
So all of a sudden white smoke started comin out
of my exhaust anyone kno of a reason?? Car runs fine just smoke started coming out then stops
then starts randomly
anyone got and type of answer ??
CiViC_eK24 is offline
Old 04-27-2010, 04:53 PM   #2
dani92
ur probably burning coolant
Dani
dani92 is offline
Old 04-27-2010, 05:22 PM   #3
CiViC_eK24
CiViC_eK24's Avatar
Really??
Old 04-27-2010, 06:19 PM   #4
forcdincivic
Needs More Snail
Headgasket.
Project Boost...Slowly but surely...
Eibach-Tokico-BlackWorksRacing
forcdincivic is offline
Old 04-27-2010, 08:25 PM   #5
Mugenn_civic
Mugenn_civic's Avatar
yep, head gasket blown, leaking coolant into your exhaust, burning it = white smoke
2000 Si Build Thread - - http://www.clubcivic.com/board/showthread.php?t=182579 - - R.I.P.
1998 Ex Build Thread - - http://www.clubcivic.com/board/showthread.php?t=213781 - Current
Amp Install D.I.Y. for 96-00: http://www.clubcivic.com/board/showthread.php?t=218406
Previous name: 2002civicLx
Mugenn_civic is offline
Old 04-27-2010, 08:32 PM   #6
CiViC_eK24
CiViC_eK24's Avatar
Radiator still full wit coolant tho and head gasket
was just replaced blows out white smoke for afew
seconds then stops the rest of the day has happened twic so far
Old 04-27-2010, 08:34 PM   #7
fwdpower
No traction though.
fwdpower's Avatar
Oh...then it's just condensation.
It depends on how much white smoke it is.
Signatures are OVERRATED.
fwdpower is offline
Old 04-27-2010, 09:24 PM   #8
forcdincivic
Needs More Snail
+1
You said it blows it out, stops, blows it out...you never said anything about a little bit right on start up..thats normal.
Old 04-27-2010, 10:34 PM   #9
Kensai
Kensai's Avatar
Take off the radiator cap and see if there's oil mixed in with the coolant, dead give away for a blown HG.
Kensai is offline
Old 05-06-2010, 05:57 PM   #10
Finnish~Racer
The ONLY Finnish-Canadian
Finnish~Racer's Avatar
Originally Posted by forcdincivic View Post
+1
you both need to do some more reading before posting. condensation WILL NOT get into the cylinders of the engine....ever! unless it leaks in from somewhere.
a cracked cylinder wall, a failed HG, or another seal would allow coolant in.
since its small i'd imagine you either got a. the wrong HG or b. you bought a one in a million faulty HG.
replace it and find the leak.
PODS Imports & Customs
Xx Street Racer xX
Finnish~Racer is offline
Old 05-24-2010, 10:48 PM   #11
Bigoj2
Darn its funny how you guys are talking about this, I JUST replaced my HG like 2 days ago and just put the coolant and oil change in last night and it's still smoking on mine mainly after I get done like on the highway or speeding a lil bit but not really getting on it at all, like not even letting the vtec kick in if that tells you anything
Bigoj2 is offline
Old 05-24-2010, 10:57 PM   #12
Mugenn_civic
welll, YOU may have to change ur rad then lol... look into ur rad filler hole, do u see oil/gas? if so, run down to ur local wrecking yard or parts store and grab yourself a new rad
Old 05-24-2010, 11:11 PM   #13
vjf915
vjf915's Avatar
Or maybe the head gasket wasnt installed properly. Did you replace the head gasket, or did a shop do it? If the shop did it, do they guarantee their work? If you did it, did you torque down the head bolts from the inside-out? Or, if Im not mistaken, your rings could be bad too, causing you to burn oil. Check your oil level on your dipstick......remember to take it out, wipe it, put it back in, then check it.
vjf915 is offline
Old 05-24-2010, 11:41 PM   #14
Mugenn_civic
nope. if he was burning oil it would be blue smoke.
Old 05-24-2010, 11:44 PM   #15
VSP
Just hand me the wrench.
VSP's Avatar
Really? That's kinda cool to know.
(by UltraMagneticAL)
"now i'm not a mechanical or manufacturing engineer..."
(reply by under8seconds)
"Yeah, well I am."
Bluring the line between hobbyist and enthusiast since 2001.
My MOSTLY STOCK NITROUS-POWERED EJ8 M/T SLEEPER BUILD/REPAIR THREAD, for your pleasure and enjoyment. It's fun. I promise.
VSP is offline
White Smoke Pouring Out Of Exhaust, Sluggish, Hesitant onesikEJ8 Engine Tech / Drivetrain 2 05-19-2011 02:05 PM
white smoke from exhaust? 1993civicDX Tech Archive (No Posting) 31 07-22-2010 01:46 PM
white smoke out exhaust, help please jardine90si Engine Tech / Drivetrain 5 07-06-2009 07:16 PM
white exhaust smoke ekturbo Engine Tech / Drivetrain 2 10-16-2008 04:04 PM
white smoke from exhaust vejita1283 Engine Tech / Drivetrain 11 12-21-2004 02:56 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
