Search:
Welcome to ClubCivic
Removal of stuck distributor rotor?
Responding Members:
User Tag List
Old 04-29-2010, 09:13 PM   #1
hankmeister
Default Removal of stuck distributor rotor?
Hey all,
I decided to put in a new distributor cap/rotor on my '90 hatchback. Appears to have last been changed sometime during the Clinton administration. Predictably, the rotor is well stuck. Any tips on how to get it off?
A quick search returned a ton of non-related threads, but one did mention heating it up and twisting off with pliers. If that's the way to go, what can I use that's likely to be handy? Would a hair dryer work? (Don't laugh, I can't think of much else around here at the moment)
thanks much in advance
Hank
hankmeister is offline
Old 04-29-2010, 10:41 PM   #2
obracer12
obracer12's Avatar
well i would first try and get a good angle on it to get it out, other then that if you can get the sides of it needle nose pliers.. or hit it with a heat gun and/ or a little and i mean little sprits of wd40.. but don't strip it.. but get another one either way
***Image removed do to corrupt file. Please relink***
Originally Posted by JerseyKid View Post
my spark is being a guido and blowing out.
Originally Posted by White Boy View Post
Most of the time, sooner or later, most get a soft spot for a civic's.
South NJ club start up PM ask Q's
obracer12 is offline
Old 04-29-2010, 10:52 PM   #3
Did you already succeed in extracting the rotor screw?
RonJ is offline
Old 04-29-2010, 11:02 PM   #4
hankmeister
Oops...uh, no...didn't know there was one... Sadly, my experience is severely limited. I'll have to try again tomorrow when it's light again.
Hopefully it'll pop right off after I find this screw. I really didn't notice one, but it may be facing 180 degrees down from where I was looking at the rotor. EDIT: just glancing at your illustration, the rotor is in about the exact position in the pic - so, it's probably in a spot where I was least likely to see it....
Thanks!
Hank
Old 04-29-2010, 11:26 PM   #5
Thanks!
Hank
You may need to do some quick flicks of the ignition switch to position the screw for removal.
RonJ is offline
rotor screws stuck OTiS133 Wheels / Tires / Brakes / Suspension 0 08-15-2011 12:20 AM
Brake Pads Stuck On Rotor??? iLoveHaters Wheels / Tires / Brakes / Suspension 6 12-18-2009 04:26 PM
distributor rotor removal AndaHeart Tech Archive (No Posting) 4 05-13-2005 07:24 PM
Stuck Ignition rotor (NEED HELP ASAP!) brockscivic13 Engine Tech / Drivetrain 0 12-31-2003 12:30 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
