Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Interior / Audio / Electronics
Interior / Audio / Electronics Anything Interior related Including interior electronics
A/C not working - please advise
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
User Tag List
Old 05-27-2010, 01:05 PM   #1
yasen
Exclamation A/C not working - please advise
Hi All civic DIY gurus......
I am having a hard time fixing my Civic 2004 sedan A/C and I am looking for someone’s help and advice.
The problem is! I did turn my A/C on and figured out that there is no difference in air temperature; it is not getting any colder. Did open my hood and found that the condenser fan not spinning. OK, did check if there are any fuses blown (did check all of them) and found fuse #1 in under hood box blown....I did put a new fuse but this fan is still not working. Fine!!! So, the blower works as I am getting air through blow holes when A/C is ON, compressor not spinning, condenser fan not spinning. I was thinking maybe it is some electrical problem!!! So, I did check A/C wire harness and found out a small difference between my harness configuration and whatever is in Honda Documentation. Basically, the A/C wire harness should have a ground connection in the place when it goes around condenser fan (just above it)....but somehow my harness doesn’t have this connection at all. I did trace my harness and it goes from compressor and receiver into cable interface, than this interface merges with condenser fan cables ....and then this big harness goes all the way around merging with some other cable interfaces, goes under fuse box.....etc. BTW, condenser fan doesn't ground connection connected to the car body as well, it has a black cable but it goes inside of the harness as I have described before.
Is there any way to find out what is going on? I know that I can test condenser fan by connecting it's blue cable to the battery's "+" and black to car ground, right?
yasen is offline   Reply With Quote
Old 05-27-2010, 01:50 PM   #2
The blown 20A fuse 1 deserves more attention. Did the new fuse blow again immediately after turning on the A/C? Does the radiator fan run when the A/C button is pushed?
RonJ is offline   Reply With Quote
Old 05-27-2010, 03:12 PM   #3
yasen
Thank you for your reply
NO, the fuse is fine. I was expecting it to die again but it didn't, the radiator fan is not spinning when A/C is on. Strange behavior, isn't it?
Old 05-27-2010, 05:50 PM   #4
Click the Fuses link in my signature. Use a test light or multimeter to verify that installed fuse 1 has voltage at both top test tabs.
Does the light in the A/C button illuminate when pushed?
Old 05-27-2010, 06:22 PM   #5
yasen
OK, will do fuse testing today and will get back to you ASAP but the A/C switch light comes on green when it is ON.
Old 05-27-2010, 11:04 PM   #6
yasen
OK, I did some testing. As I said the green light comes ON when AC button is ON. I did test conderser fan just connection it's black wire to the ground and another wire to the "+" battery and it is spinning. Didn't test fuse for voltage yet.
Thanks
Old 05-28-2010, 12:56 PM   #7
yasen
I did spend some time researching what could be a possible reason and I lot of people seaying that the very common reason for civics to have this problem is compressor thermal protector, what do you think? But I don't know how to test is out and how to change it!
Thanks
Old 05-28-2010, 12:59 PM   #8
Thanks
I have heard this as well, but don't guess, troubleshoot. If the thermal protector were bad, then the condenser and radiator fans would still run. In your case, nothing (fans and compressor) works.
Fuse 1 voltages at the test tabs? Seriously, not providing requested information only serves to delay resolution of your problem. If you want help, supply answers to questions. If you just want to guess at solutions, there's no need to make a thread.
Old 05-28-2010, 02:39 PM   #9
yasen
No Problem, I will go to Home Depot today and will try to complete all the testing. I will keep you up to date.
Thanks
Old 05-28-2010, 04:50 PM   #10
Thanks
A high impedance digital multimeter is what you need for car work. I bought mine on sale for $15 at Sears. Many stores have them, including Walmart. Also check at Harbor Freight Tools if you have one near you.
Old 05-30-2010, 11:50 PM   #11
gudoffer
my a/c wasnt working either...problem was the thermal switch...more like a switch that goes somewhere by the a/c compressor under the hood...i replaced that and its working mint!
gudoffer is offline   Reply With Quote
Old 05-31-2010, 01:11 AM   #12
yasen
Hi, with miltimeter set to 20M at OHM it shows me "-1" on all fuses.
Old 05-31-2010, 01:21 AM   #13
My best advice for you is to take your car to a mechanic who will do the electrical troubleshooting for you.
Old 05-31-2010, 01:28 AM   #14
yasen
Am I doing something wrong?
Old 05-31-2010, 01:32 AM   #15
Did you read post #4 in this thread?
Just want some advise.. Roy95Hatch Engine Tech / Drivetrain 0 08-14-2011 07:47 PM
Gauge, Dash & Tail lights NOT working! Only headlights are working HELP civic94lx Tech Archive (No Posting) 5 07-22-2009 02:15 AM
looking for advise too whiteciv88 Tech Archive (No Posting) 19 06-11-2009 09:43 PM
advise? VeracityChild Show off your 5th Generation Honda Civic (1992-1995) 2 03-06-2009 10:17 PM
Need advise!!!! eortizr Tech Archive (No Posting) 1 08-27-2006 01:35 AM
Copyright ®2007 ClubCivic.com
Freelance Web Design
