Search:
Welcome to ClubCivic
GSR cranks but won't start: No spark
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
User Tag List
Old 05-27-2010, 11:54 PM   #1
H22aEg
Default GSR cranks but won't start: No spark
Hey guess I have a rebuilt gsr motor and this is the first time its gonna turn on but its not cranking over now everything is all brand new wires plugs dizzy everything and I'm hearing my fuel pump and I'm getting fuel in the fuel rail. The motor sounds its wants to kick over but nothing yet and could i try using maybe starting fluid thanks guys for your help
H22aEg is offline
Old 05-27-2010, 11:59 PM   #2
Deezy
silent partner
Deezy's Avatar
Have you Checked for spark??? Also, set your ignition and mechanical timing correctly??
Everybody knows somebody who loves a Civic.!!!!
Deezy is offline
Old 05-28-2010, 12:05 AM   #3
H22aEg
Timing should be fine cylinder 1 was top dead center fire order is right can gears are pointing same direction and no I'm not getting spark
H22aEg is offline
Old 05-28-2010, 12:11 AM   #4
Deezy
silent partner
Deezy's Avatar
Ok, read the check for spark link in the above post, for possible solutions....
Deezy is offline
Old 05-28-2010, 12:20 AM   #5
H22aEg
Thanks. Ok I read it and it helps little but what I'm still confused is that my coil rotor igniter is all brand new never used and I'm gonna look into the ign switch and also if my battery is relocated in the back would that effect it
H22aEg is offline
Old 05-28-2010, 12:30 AM   #6
Deezy
silent partner
Deezy's Avatar
..Could very well.... Check and double check connections,,,......Especially ground..
Deezy is offline
Old 05-28-2010, 12:41 AM   #7
H22aEg
The pos is connection is good but my ground cable is connected where the strut is where it holds on that nutis where my ground is
H22aEg is offline
Old 05-28-2010, 10:40 PM   #8
Pocket_eh
Ordering Civic HB Parts
check the firing order could be wrong. and sand down your grounded area. could help. and check the transmission ground.
Pocket_eh is offline
B18b1 Cranks, but won't start dannwo1 Engine Tech / Drivetrain 7 01-10-2011 05:11 PM
95 civic cranks but no start. HELP! Nismo1191 Engine Tech / Drivetrain 9 10-09-2010 11:15 PM
car wont start,cranks but no start zoomoutt Tech Archive (No Posting) 7 06-20-2010 05:20 PM
Help please! Cranks but won't start erichreneau Tech Archive (No Posting) 13 05-27-2010 08:56 PM
B16a cranks won't start! 4thgenman Tech Archive (No Posting) 4 02-18-2008 01:10 AM
Copyright ®2007 ClubCivic.com
Freelance Web Design
