Search:
Welcome to ClubCivic
Reading fault codes??
Responding Members:
User Tag List
Old 06-10-2010, 03:09 PM   #1
cctvman
Default Reading fault codes??
Hi, i have a 6th gen civic coupe with what i assume is a b16 (1.6 SOHC non vtec) in it.
Currently have the engine check light showing is there a way of veiwing the fault codes with out a computer (link some pins out) or does it have to be properly pluged in?
cheers chris
cctvman is offline
Old 06-10-2010, 03:10 PM   #2
You need an OBDII scan tool to read the codes on a 7th gen Civic (01-05). If you have a 6th gen Civic (96-00), then click the CEL link in my signature.
RonJ is offline
Old 06-10-2010, 03:50 PM   #3
cctvman
Many thanks for the super quick reply. Have just found the plug, run the test and got the following fault codes back:
17 speed sensor (sounds right because the speedo stopped working when the CEL came on)
41 primary oxygen sensor heater
65 secondary oxygen sensor heater wire (black wire)
92 EVAP Solenoid/Valve/Vacuum Lines
I'm a bit puzzled about the link to all these different faults when it was just the speedo not working. The alternator sensor fuse also keeps blowing so I don't know how to start fixing this lot
Thanks again
Chris
cctvman is offline
Old 06-10-2010, 03:51 PM   #4
Click the Fuse 15 TSB link in my signature.
RonJ is offline
Old 06-11-2010, 09:51 AM   #5
cctvman
Thanks for your help RonJ. I have checked the Fuse 15 TSB and can find no chafing of the wiring around connector C115 - in fact my connector ends in a blanking plug and there is no continuation of the loom.
However, after checking around all the plugs/sockets on the loom in the engine compartment and resetting the ECU, the speedo started working again and the CEL went out (obviously) - but on a test drive, the speedo once again packed up, CEL came on and fuse 15 blew again. Checked CEL codes again and still gettiing:
41 Primary Oxygen Sensor Heater
65 Secondary Oxygen Sensor Heater Wire
92 EVAP sensor/valve/vacuum line
If there really is a problem with the above components - how come I could fix the speedo just by unplugging/ plugging the loom connectors?
Would it be more beneficial to just get the car on a proper scanner - will this give me more information on what really is the fault?
Any help appreciated.
Cheers
Chris
cctvman is offline
OBC reading, transmission fault evilrilla2 Engine Tech / Drivetrain 6 09-05-2011 05:56 PM
whose fault? JamesOne Off Topic 28 12-06-2007 08:56 PM
Reading OBD1 Codes? stealthy Engine Tech / Drivetrain 5 08-07-2006 06:55 PM
Haviing problems reading cel codes daoshao Tech Archive (No Posting) 2 06-28-2006 12:12 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
