Search:
Welcome to ClubCivic
Scanned my car and throughout; Code P0113
Responding Members:
User Tag List
Old 07-17-2010, 04:00 AM   #1
kakatotti
Default Scanned my car and throughout; Code P0113
I own a Honda Civic 1998 ex coupe, automatic transmission.
Recently I scanned my car and it throughout the code P0113 which is the Intake Air Temperature Circuit High Input. What does this mean? How can I fix this and does any body have instruction? Has anybody had this problem before that can help me out? Thank very much for your time.
kakatotti is offline   Reply With Quote
Old 07-17-2010, 04:23 AM   #2
2NRSTV
Team Exile/ADO Garage
2NRSTV's Avatar
It means that the ECU is reading low resistance. It could mean that you have a bad IAT Sensor, a bad ECU (Probably not), or an open (short) in the positive or ground.
Get a voltmeter. Unplug the IAT from the connector and hook the voltmeter to the positive and negative of the IAT sensor. Turn the key to the ON position (DO NOT turn the engine on). And measure voltage. It should be close to 5volts.
If you get close to 5 volts - Sensor is bad.
If you get 0 volts - Short in positive or ground wire.
If you get over 5 volts - Bad resistor in ECU
Feel free to visit TeamExile.Org to ask questions.
Or Email me directly to Tuner Steve
2NRSTV is offline   Reply With Quote
Old 07-22-2010, 02:46 AM   #3
kakatotti
Hey,
I'm still having problem with this code and now I have the code P0171 "system too lean (bank 1).
Can I use a GB instrument GMT-12A" as a volrmeter to test the sensor?
DO you pics to where the sensor might be and how I can go about connecting the voltmeter to the sensor to check if it is bad.
Thanks
Old 08-01-2010, 01:47 AM   #4
kakatotti
Hey,
Thanks
Old 08-01-2010, 02:39 AM   #5
2NRSTV
2NRSTV's Avatar
Yes, you can use the GMT-12A to test the sensor.
This is the best I could do for a pic since I don't have a D16Y8 engine.
It's the sensor with 2 wires that is plugged into the intake tract. It should be just before the throttle body.
Unplug the connector from the sensor and put the positive (red) lead to the red/yellow wire on the plug and the negative (black) lead to the green/black wire on the plug.
Old 08-03-2010, 06:25 PM   #6
kakatotti
Hey,
Nothings happens when I put the GMT. No voltage, nothing. Can this be a sign that I need a new sensor?
How can a replace the sensor? What tools am I going to need? Thanks
Old 08-03-2010, 06:36 PM   #7
What Civic?
XpL0d3r's Avatar
Originally Posted by kakatotti View Post
Hey,
If you're getting nothing that usually means there is a short somewhere.. typically if it were the sensor you would get some sort of voltage (probably much lower) because it's still getting power. Check the wiring to see if there are any damaged wires anywhere.
Originally Posted by Bhikku View Post
At least i have a banjo coming in the mail, i had ordered it while drunk as f*** on saturday....i have no idea how to play a god damn banjo...
( '02 Acura RSX Type-S | '05 Kawasaki Ninja 500RR | '97 Honda Civic B18 Turbo | '05 Infiniti G35 Coupe (SOLD) )
XpL0d3r is online now   Reply With Quote
P0505 Code, got new IACV, code returned JohnS. Engine Tech / Drivetrain 49 04-04-2013 01:01 AM
96 Civic Communications Error when scanned, Gets no readinds, running rich Mcgarvie51 Engine Tech / Drivetrain 21 02-21-2011 07:27 PM
Help ASAP, car shut off, code 20 NoWayBack91Si Tech Archive (No Posting) 16 10-01-2007 04:42 PM
ctr trans stamp code and gsr head code? what are they? nurevEKcivic00 Engine Tech / Drivetrain 2 05-27-2007 02:54 PM
the code for my car............>??????????????? cole Tech Archive (No Posting) 11 09-15-2004 11:35 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
