Search:
Welcome to ClubCivic
AC Compressor noise
Responding Members:
User Tag List
Old 09-21-2010, 11:10 AM   #1
SSJimmy
Default AC Compressor noise
I have a 98 civic 5spd and my compressor has been making some new noises im thinking its going on and off in about a 15 second cycle. I was in an accident a year ago and replaced the condenser and the dryer before have it vacuumed and refilled. Its been working fine for 6 months and then its started with the cycle I had the level checked and it has enough r134 in it.
So not sure what the problems is I hope its not the compressor and something easy does anyone have any ideas. Also cold air still comes out of the vents if that helps.
2000 NBM Camaro SS
Baer Rotors | OEM ZO6 Rims | Magnaflow | SLP Lid | DMH E-Cutout | QTP LT & ORY| LCA w/ brackets | Ported TB | LS6 Intake 321HP & 331TQ|13.1 @ 108 mph
1998 Honda Civic LX Sedan Stolen/Recovered/Wrecked/Repaired
SSJimmy is offline   Reply With Quote
Old 09-21-2010, 12:50 PM   #2
ohsnapzitzmeng
ohsnapzitzmeng's Avatar
can you specify the noise? where is it coming from? if its a screechy, scratchy noise, its probly your compressor clutch. if so maybe the clearance is off of its just rusted
Hold On Not Done Accelerating
ohsnapzitzmeng is offline   Reply With Quote
Old 09-21-2010, 01:04 PM   #3
SSJimmy
its more like a whine its like your hearing a load but on the compressor and then it goes away and then comes back every 15 seconds. and its coming from the engine bay driver side where the compressor.
2000 NBM Camaro SS
Old 09-21-2010, 01:32 PM   #4
Does the condenser fan run when the compressor clutch engages?
RonJ is offline   Reply With Quote
Old 09-21-2010, 03:29 PM   #5
1FastEX1994
^ROFLcopter
1FastEX1994's Avatar
i'm having the same problem in my ek hatch.
but mine sounds like my compressor clutch is shot,
1994 honda civic EX-SOLD
1997 honda civic CX Hatchie(:
a man and a duck walk into a bar....i forgot the joke, but your mother's a whore
arguing over the internet is like the special olympics, even if you win, you're still retarded
1FastEX1994 is offline   Reply With Quote
Old 09-21-2010, 06:09 PM   #6
SSJimmy
the fan is always on
I noticed today that if I hear the noise and then shift to N or down shift it stops and then comes back once i put it in gear that is while driving/
when im just at idle i dont really hear the whine noise more of a tick but it still comes and goes. I also switched around the relays since i saw that as a possible fix and there was no change.
2000 NBM Camaro SS
Old 09-21-2010, 06:17 PM   #7
zachkelly
zachkelly's Avatar
mine was doing something similar and it would be loud for a few seconds and then stop. Turned out to be the clutch. I replaced the entire thing actually from a junkyard compressor for $20 and fixed it. I think the noise could be the clutch slipping every now and then?
maybe? just my 2c
zachkelly is offline   Reply With Quote
Old 09-21-2010, 06:17 PM   #8
Sounds like a bad compressor clutch. It's possible to replace it without removing the compressor if you don't mind working in tight space.
Old 09-21-2010, 06:32 PM   #9
zachkelly
zachkelly's Avatar
with that ill link you to my thread where ron told me how to do that
http://www.clubcivic.com/board/showthread.php?t=187611
FYI: It is also possible (though a bit tricky) to replace just the clutch and bearing without removing the compressor.
Old 09-22-2010, 07:15 AM   #10
SSJimmy
k thanks ill look for a good used compressor is there any tutorials on how to remove the compressor?
2000 NBM Camaro SS
Old 09-22-2010, 10:22 AM   #11
zachkelly
zachkelly's Avatar
Its pretty self explanitory. Theres 2 bolts holding the hoses on the compressor, and 4 long ones bolting the compressor on. Loosen the adjustment pulley bolt kinda behind the power steering (this is to relieve the tension on the belt) and then vice versa.
Technically you should legally evacuate the system but I just did it myself too, and then you should also replace the dryer, however I did not and it still all works fine.
Old 09-23-2010, 06:50 PM   #12
SSJimmy
sounds good time to start looking at the junk yards thanks for the help
2000 NBM Camaro SS
Ticking Noise? Noise @ around 4 RPM's? Tamerin Engine Tech / Drivetrain 2 10-04-2011 04:43 PM
A/C compressor and compressor switch problem :S gudoffer Tech Archive (No Posting) 0 08-07-2009 05:40 PM
a/c compressor Goodmayn Engine Tech / Drivetrain 3 09-17-2005 12:10 AM
Ac Compressor Help 4doorSpoon Interior / Audio / Electronics 0 07-13-2004 01:53 PM
concerning A/C compressor Jaymasta Tech Archive (No Posting) 1 05-27-2004 12:03 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
