Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Interior / Audio / Electronics
Interior / Audio / Electronics Anything Interior related Including interior electronics
Dome light not working.... tried everything
Responding Members:
User Tag List
Old 10-10-2010, 07:53 PM   #1
JDM_SPEC_SI-R
JDM_SPEC_SI-R's Avatar
Default Dome light not working.... tried everything
hey guys. ive done a bunch of research on how ti fix my dome light. it has never worked since i got the car.
i have checked the door hook ups, the ground on the switch, my radio has the two wires spliced since its an after market head, the fuse is good..... the bulb is brand new. i dont know what else to check to make this light turn on. it does not work in any position. i also pulled the switch out and examined it.... looks fine and perfect. like its making all connections....
any ideas on whats wrong? thanks
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
JDM_SPEC_SI-R is offline   Reply With Quote
Old 10-10-2010, 08:11 PM   #2
JDM_SPEC_SI-R
it also occured to me the the headlight busser does not work either and i have heard that these two things are linked to each other. is there a fuse for headlight buzzer?
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 10-10-2010, 09:01 PM   #3
4bangincivic
sup
4bangincivic's Avatar
Have you checked power going to the buzzer?
.ǝɯ ǝɹoɟǝq pǝɹǝʌoɔsıpun ǝı1 ɥʇnɹʇ ɟo suɐǝɔo ʇsɐʌ ǝ1ıɥʍ 'ɥɔɐǝq ǝɥʇ uo buıʎɐ1d p1ıɥɔ ɐ ʎ1uo ɯɐ ı
4bangincivic is offline   Reply With Quote
Old 10-10-2010, 09:03 PM   #4
JDM_SPEC_SI-R
wheres the buzzer? i know on the teg its on the back of the fuse box
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 10-10-2010, 10:22 PM   #5
97civicMan
Knucklehead h8r
97civicMan's Avatar
^Hey bro i pretty sure its in the same spot
97civicMan is offline   Reply With Quote
Old 10-11-2010, 09:50 PM   #6
gotcher17
gotcher17's Avatar
my dome light doesnt work either and neither does my keyless entery remote... mine doesnt work because the factory head unit was removed and they wont work without it
gotcher17 is offline   Reply With Quote
Old 10-11-2010, 11:16 PM   #7
What year Civic???
Are you sure you checked 7.5A hood fuse 43?
Does the Wht/Red wire at the dome light have voltage to body ground?
RonJ is offline   Reply With Quote
Old 10-12-2010, 01:02 PM   #8
JDM_SPEC_SI-R
its frankenstien. the shell and dome light is a 98 hb dx. the floor harness, dash all electricals are from a 96 ex.
everything is connected. no unwanted grounds or nothing. fuse is good too.
it could be the switch but i think its something that is the light is connected to like my headlight buzzer cause that doesnt work either
the busser goes off if i pull out a fuse and put it back in but i cant remember wish one. i think its fuse 15 though
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 10-12-2010, 01:04 PM   #9
JDM_SPEC_SI-R
yours is an easy fix. splice l grn/red wire to grn/black wire and done
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 10-12-2010, 02:30 PM   #10
Again, check whether or not voltage reaches the dome light. This is the first logical step.
Old 10-13-2010, 11:13 PM   #11
JDM_SPEC_SI-R
i am 95% positive the switch is getting voltage or i would like to think that.
now ive looked all around the car tested the door switches and everything is hooked up an works.
now i did find a plug with two wires white red and green black. this plug is just sitting there, not plugged into anything. i am thinking that is it, but here is where im lost. the fuse for the dome light is under the hood. so why would another plug for it be behind the the fuse box under the dash???<- thats if this plug is even for the dome. also the two wires coming out of the dome liught aree green red and white red. so it doesnt match the plug. the door wires are green red on the passenger and driver is solid green.
im really lost on it. dooes anyone know where the dome light harness goes? im sure it leads somewhere by the passenger side. down the frame towards the hood fuse box.
is it possible to just find the dome harness and splice it into a power supply since it has its own switch?
i would rather do it correct but i need mroe direction on this.
i also placed a fuse in every terminal that was missing one in the fuse box and still nothing....
but i did get the defroster and headlight warning working. one of the fuses placed in the terminals turned them on.
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 10-14-2010, 09:36 PM   #12
JDM_SPEC_SI-R
got it!!!
si guys the damn connection harness from the 98 dome light is different from the 96 harness.
i actually ended up findgingt he 98 harness and splicing it into the icu and a harness from the back of the fuse box.
the plug was never even connected from the dome light thats why it was not coming on. but its fixed and working now.... damn dome light.
now onto the rear wiper switch setup with a non rear wiper main harness under the dash!
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Intermittent Wipers, Dome/Trunk lights, and Horn not working Stickyittoyou Tech Archive (No Posting) 5 04-11-2010 06:07 PM
Interior Lights: Map light & Dome light defvayne Interior / Audio / Electronics 5 04-14-2009 11:28 PM
Interior dome light not working. BONESTOCK Tech Archive (No Posting) 10 07-30-2007 11:16 PM
help dome light not working crazydyke Interior / Audio / Electronics 5 07-03-2005 11:02 PM
dome light not working pearlgreenciv Tech Archive (No Posting) 20 02-09-2005 01:37 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
