Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
creaking/popping from front end
Responding Members:
User Tag List
Old 10-24-2010, 03:52 AM   #1
ImThaBean
ImThaBean's Avatar
Default creaking/popping from front end
A while back I installed new stock LCA/UCA and tie rods with fresh ball joints and bushings. In the last few weeks i've been hearing creaking and popping coming from the front end. It initially started when I'd pull out of my drive way (pretty steep incline). Now it's happening when I turn and on occasion when driving straight.
It sounds like something is binding, but everything was OE spec and I can't see any wear or rubbing on the wheel well around the suspension bits.
Anyone have this issue or know what is popping/creaking/binding? It bugs me to hear it, but my girl is afraid to ride in my car cause she thinks its gonna fall apart.
Car is a '94 Civic DX. stock everything ex. lowering springs
ImThaBean is offline   Reply With Quote
Old 10-24-2010, 04:23 AM   #2
purpej1
honda fiend
purpej1's Avatar
cv joint only thing i can think of since lca and such is new
Originally Posted by 98ej8 View Post
remember once and for all son, nothing that is made by Honda is pointless
purpej1 is offline   Reply With Quote
Old 10-24-2010, 04:27 AM   #3
ImThaBean
ImThaBean's Avatar
The CV joint is popping but that is a sound I am familiar with, I have replaced a few.
Old 10-24-2010, 07:56 AM   #4
EJ6_DMS
EJ6_DMS's Avatar
everythin torqued up to spec?
EJ6_DMS is offline   Reply With Quote
Old 10-24-2010, 01:29 PM   #5
Shaaaft
FNG
Shaaaft's Avatar
Worst case scenario would be take it to a shop, get a second opinion. If you installed everything yourself then maybe spend a day tearing it apart, inspecting each piece an putting it back together. Make sure everything is to spec an hopefully you find your problem before it gets worse.
Shaaaft is offline   Reply With Quote
Old 10-28-2010, 01:40 AM   #6
stateofjustin
Strut/shock tower bushings up top, UCA bushings... jack up the car and see if you can move the wheel grabbing the top of the tire and the bottom and rock top to bottom. should be no play. With the steering column lock engaged, a horizontal rock back and forth should produce much the same, maybe a little movement. Check the UCA bushings and upper ball joint condition and then drop the shock bodies out, compress the spring, and check the bushing up top. Also, check your roll bar bushings at the LCA bolt point if you have a front roll bar, ditto for the roll bar support/carrier bushings. Let us know what you find.
stateofjustin is offline   Reply With Quote
Old 10-28-2010, 03:48 AM   #7
purpej1
honda fiend
purpej1's Avatar
im having the same problem now but coming from the driver side wheel. its like a creaking clunking noise.did it before but now it does it all the time
Old 11-01-2010, 10:41 PM   #8
cspak01
cspak01's Avatar
when you hit the brakes does it stop?
cspak01 is offline   Reply With Quote
Old 11-02-2010, 05:45 PM   #9
ImThaBean
ImThaBean's Avatar
Its not a brake pad issue. It isolated to my bushings. it only creaks when I go in/out of my driveway and around uneven corners. That is what got me to to say bushing, that and I just replaces my control arms. Someone else on another board said its the bushing binding. I didn't grease them enough and didn't tighten them under load. Once I get a chance to do so (I'm moving in the next few weeks) Ima test out that theory and see what happens.
WTB: NY 99-00 Civic Si front end, 96 up front end. Crump Parts Wanted 0 01-01-2011 11:51 AM
Popping in left front/fan noise BlueSiclone Engine Tech / Drivetrain 1 09-01-2010 04:38 PM
Help..popping of front wheel. kikidawn Engine Tech / Drivetrain 6 10-18-2008 07:51 AM
S14 front end or JDM Integra Type R front end? gabriel787 Tech Archive (No Posting) 30 05-09-2007 12:05 PM
JDM CRX front end Vs. JDM Civic front end F40 Tech Archive (No Posting) 3 01-27-2007 12:45 AM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging v3.1.3 (Lite) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 2007 ClubCivic.com
Freelance Web Design
