Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Forced Induction
Forced Induction Nitrous, supercharger, turbo
what do i need to boost my d16 eg?
Forced Induction
Responding Members:
User Tag List
Old 11-05-2010, 02:31 PM   #1
lil95ex
lil95ex's Avatar
Default what do i need to boost my d16 eg?
ok so im kinda new when it comes to boosting a car so i have a T12 turbo from a saab and other than the manifold, intercooler and intercooler piping what else would i need my motor is stock except for a cold air intake this isnt going to be the next thing i do but im just collecting parts for now. Thanx for any help or suggestions
lil95ex is offline   Reply With Quote
Old 11-05-2010, 03:00 PM   #2
TigBitties
Frame Bangin
TigBitties's Avatar
google or search. these questions get asked daily
TigBitties is offline   Reply With Quote
Old 11-06-2010, 08:39 PM   #3
civic92si
Gina my Lady in red
please use the search. you might want to consider building your bottom end before you even boost. otherwise your motor wont last long. I suggest getting some JE piston and Eagle Rod. 1st...before even talking about boosting..here what you need since i got some time.
You will need:
Downpipe
injector
BOV
Bigger Fuel pump
Tune.
that just for the turbo stuff itself///
B18C TURBO all the way!
civic92si is offline   Reply With Quote
Old 11-09-2010, 12:39 AM   #4
mcivice199_6x
turbod16.com is helpfull
mcivice199_6x is offline   Reply With Quote
Old 11-09-2010, 12:00 PM   #5
TigBitties
Frame Bangin
TigBitties's Avatar
^^^i agree lol
Old 11-09-2010, 01:40 PM   #6
lil95ex
lil95ex's Avatar
Thanks guys really helps out alot. Now atleast i know for the most part exactly what im looking for and where to look.
Old 11-10-2010, 04:13 PM   #7
techavluis
ok, yes do alittle looking around. ALOT of info everywhere. but i will help alittle.
you can run boost on your stock d16. alot of people do like 5-8 psi. (180-225 hp) but yes something well go wrong. on a good motor maybe 40,000 miles
u can build it too, but if u..... note u will never get what u put into it. so plan on keeping it if u do. with building there is ALOT of ways to go. i want cp-eagle.
my civic build
http://www.clubcivic.com/board/showthread.php?t=191947
techavluis is offline   Reply With Quote
Old 11-10-2010, 04:16 PM   #8
techavluis
i give this info to other guy. but alot can help u
well u really have not said how much you wanna put or your end goal. key to this world is to plan it out (money & whp number) but i will help u pick alittle.
alittle bolt ons maybe 500-1300 and 80k miles (dd)
put together a turbo kit (or a kit already together) for about 1000-3000. all new vs all used or a mix of the two. and boost 6psi with a tune and call it a day for 30,000 miles on a good stock z6. when it takes a s***, buy other for 300-400 and hope for other 30,000 and so on..... (2nd time around i would go y8, same money, easy to get, alittle better, and easy to put it) this well be 175-225 whp
next is to do a low end build. just Pistons, Rods and Bearings. ($1000 if you do it yourself or pay other 600-800 at a shop. so 1600-1800) stock head. and a few alittle things like head gasket and other seals and gasket. (250 maybe) then with the turbo ($1000-3000) and tune ($300-400) you will have 250-350whp. about 40,000 miles.
then alittle more wild, intake manifold, cams, cams gear, springs, retaniners, fuel pump, injectors, and s*** like that. maybe $2000 and with the same boost make other 40-60whp more... (key there is making more whp with the same boost cuz less boost is safer.) so 300-400whp at 40,000 miles
and now the best of them all. FIRST NOTE!!! if you wanna go here think about it now cuz you can save alot of money saving up and just doing this from the start. everything above with sleeving the block (900-1200), full block (1500-3000 if done your self or shop) and head build (900-2000), a D to B tranny plane cuz at 400+ the d tranny is going to fail (600-1100 used or new) (note you will need flywheel, starter, and a few alittle things for b tranny) big injectors, fuel regulaor, throttle body, just all out!. look at i dont know (thorwing numbers out there) 6000-9000 and hope to god for 60-100,000 miles dd driving.
now all this can be WAY more detailed and money can be more or less with who you know and whp can be more or less on tuner and with what you buy. skunk2 vs ebay.
also note, alot of people dont know about d vs b vs h vs k vs there head up there ass. do homework on them all. they all have good and bad. i will start you off with B vs D. (lets say you put 3k of work in) B will make more whp. but the D can jump timing cuz timing belt goes to s*** or something with the head goes wrong and you well have it better off then the guy with the B.
and this is all power. not even moving into breaks, coreovers, springs, and other things be sides power. its a long road when its all said and done.... ask me how i know. started with things about getting a civic to save money and end up putting 18k and still going.....
my civic build
Old 11-10-2010, 05:52 PM   #9
TigBitties
Frame Bangin
TigBitties's Avatar
lol
Old 11-12-2010, 01:33 PM   #10
lil95ex
lil95ex's Avatar
Thanks im honestly going to start on working to that set up techavluis that helps out alot and thanx for giving the numbers and est. price. I'm looking to get all i can out of it and i plan on doing all i possibly can myself with the help of friends. I greatly apprechiate that list and im really looking forward to having parts come in the mail. They would be already but i just got it bout two weeks ago. Oh and does anyone know of pretty good and reliable sites to get some of this from i know of a few but just trying to widen the table if you know what i mean.
Old 11-12-2010, 07:32 PM   #11
TigBitties
Frame Bangin
TigBitties's Avatar
go-autoworks, any of our sponsor sites, procivic might. um idk what else
Old 11-13-2010, 10:08 AM   #12
techavluis
Lol u have a civic...... 7-11 has parts. Just playing. Use sponsor site. All good
my civic build
Old 11-23-2010, 03:02 AM   #13
paulx022
paulx022's Avatar
Originally Posted by anyuta34 View Post
When the 3 morning arrived new york escort the Druids would give new york asian escort a piece of wood new york escorts from their fires to each family,then they would take them home to start new cooking fires.These new york asian escorts fires would keep the homes warm and free from evil
please ban him.
paulx022 is offline   Reply With Quote
Old 11-23-2010, 11:31 AM   #14
What Civic?
XpL0d3r's Avatar
Originally Posted by paulx022 View Post
please ban him.
Done. Next time please flag the post, as all mods will get an email about it. Much easier than having to prune through threads looking for spam like that, lol
But thank you sir!
Originally Posted by Bhikku View Post
At least i have a banjo coming in the mail, i had ordered it while drunk as f*** on saturday....i have no idea how to play a god damn banjo...
( '02 Acura RSX Type-S | '05 Kawasaki Ninja 500RR | '97 Honda Civic B18 Turbo | '05 Infiniti G35 Coupe (SOLD) )
XpL0d3r is offline   Reply With Quote
Building up D16 for boost supermario25 Forced Induction 10 09-17-2010 12:12 AM
d16 boost riley1234civc Tech Archive (No Posting) 2 03-29-2009 10:56 PM
D16 / B18 & Boost Parts! Szady Parts for Sale 59 02-17-2009 10:48 PM
Turbo d16, boost? 95turbocivic Tech Archive (No Posting) 9 05-29-2005 05:58 PM
D16 Edelbrock turbo boost problem? lambocivic Forced Induction 0 02-21-2005 07:09 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
