Search:
Welcome to ClubCivic
d16y8 head onto d15zc bottom end. Anything I should know?
Responding Members:
User Tag List
Old 11-12-2010, 12:49 AM   #1
HotHatchEG707
Default d16y8 head onto d15zc bottom end. Anything I should know?
So i recently bought a 1993 civic hatch. The car was the vx model and came with a d15zc engine, according to honda the motor is pushing a maximum of 90 horsepower and 98 ft lb. its seriously...so slow. The motor has 180k miles on it and still has perfect compression on all cylinders and runs just fine. I am purchasing a d16y8 head from a friend. Its been rebuilt with a stage 2 vtec cam, he used the head on an old turbo project.
So from what I can tell I will need an ECU, since he used a aftermarket programmable ecu originially since the head was part of a turbo setup. But which ECU do I use?
Can I use my stock fuel rail?
Is there anything else I should know? Im assuming its pretty straight forward, bolt on and go.
Thanks guys.
Heres a pic of my car.
Uploaded with ImageShack.us
HotHatchEG707 is offline   Reply With Quote
Old 11-12-2010, 09:31 AM   #2
civicmand16y7
civicmand16y7's Avatar
was there a d15zc ever made??? that car came with a d15z1 and the zc is a dohc motor make sure what type of your motor you have frist and let us know so we can help you better
GO FAST MOST GO FAST
MY 94 HONDA CIVIC THEADhttp://www.clubcivic.com/board/showthread.php?t=193960
civicmand16y7 is offline   Reply With Quote
Old 11-12-2010, 09:31 AM   #3
civicmand16y7
Old 11-12-2010, 10:57 AM   #4
jlicrx
jlicrx's Avatar
the 93 VX came with a D15Z1 engine, not a ZC - all ZC engines, DOHC and SOHC are 1.6L - a D16Y8 head on a D15Z1 bottom end with D15Z1 pistons will result in a compression ratio of around 8.0:1 - not going to make much power
ZCspeed Racing
jlicrx is offline   Reply With Quote
Old 11-12-2010, 11:44 AM   #5
civicmand16y7
and the z1 motor is a vtec motor anyways it will be a wast of time and money
Old 11-12-2010, 11:54 AM   #6
31dev31
Chillin' Canadian Member
31dev31's Avatar
D15Z1 have too low of a compression to fully benefit from a mini-me setup.
I would recommend a full D16Z6 swap.
2004 Ford Ranger EDGE - 4.0 V6, 4x4, 4:10 LSD
Click for HID Projector Retrofit DIY
Click for EG6 Inspiration Blog
31dev31 is offline   Reply With Quote
Old 11-12-2010, 11:57 AM   #7
civicmand16y7
why would you do a mini me swap on a motor that has vtec already...just do a motors swap
Old 11-17-2010, 04:06 AM   #8
HotHatchEG707
ah ok. well for whatever reason my motor is stamped d15zc, no joke lol. I will take a photo. if the compression will be that low then your right i really wont be gaining much power from it at all so definitely not worth my time i guess ill just have to hold on until I can afford a B series swap.
Thanks you guys.
D15b7 Head On A D15b Bottom End dustinmp3 Tech Archive (No Posting) 4 02-18-2009 01:44 PM
b16a2 head on a b18c? bottom end 2000siblk Tech Archive (No Posting) 9 11-08-2008 06:00 PM
zc bottom end with z6 head vtec? K.O.S_88 Tech Archive (No Posting) 12 11-05-2008 08:45 PM
New Motor Fund D16Y8 PARTS. BLEW BOTTOM END getbeat04 Parts for Sale 32 09-12-2008 10:10 PM
Just picked up a head...need bottom end to match..... AlbusAngelus Engine Tech / Drivetrain 4 02-14-2006 09:16 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
