Search:
Welcome to ClubCivic
what are the symptoms of a bad fuel pressure regulator?
Responding Members:
User Tag List
Old 12-05-2010, 03:52 AM   #1
Amace013
Default what are the symptoms of a bad fuel pressure regulator?
i got a b18b1 swapped into my 98 civic hx about a month ago if i let my car sit for about 45 min or longer basically when it fully cools down i have issues starting it again it starts sputters and dies and if i hit the gas on and off itll rev and almost die till it warms up. ive replaced plugs wires cap rotor dizzy is newer. someone told me it could be my fuel pressure regulator but if it sits for a few hrs it starts fine just idles pretty low until warm. can the fuel press reg cause this?
Amace013 is offline   Reply With Quote
Old 12-05-2010, 04:04 AM   #2
got traction
i rock the sohc
got traction's Avatar
any CEL's? sounds like a IACV issue to me
"You can never have enough horsepower or ammunition"
7.91@ 196 - Outlaw B series | 9.49 @ 157.3 - Vitara D16 (retired) | 9.81@ 137 Street AM K series 8.46@ 178 - SFWD B series
Originally Posted by redcivicls95 View Post
Yes. Im going to go buy back one of the cars i've built and drive to your s***hole to spank your single cam ass................NOT!
got traction is offline   Reply With Quote
Old 12-05-2010, 04:37 AM   #3
Amace013
well my iacv is disconnected. if it is hooked up it idloes at 2k rpm and i thought i could just disconnect it without any issues, im sorry if i sound like an idiot
Old 12-05-2010, 04:41 AM   #4
Amace013
if i plug it back in it does the same thing. im not sure if its that, if i buy a new one should it idle normally? or would i have to adjust it
Old 12-05-2010, 05:16 AM   #5
got traction
i rock the sohc
so you unplugged the IACV? Plug it back in, let it idle at 2k and adjust the idle screw to see if it drops
Old 12-05-2010, 05:17 AM   #6
got traction
i rock the sohc
either that, or you have a massive vacuum leak
Old 12-05-2010, 02:40 PM   #7
Vitaliy93
Vitaliy93's Avatar
bad fuel pressure regulator is when you loose pressure in the rail right when you shut off the car. Depending on how bad it is, you will need to prime the fuel pump before it will start again. Or else you will be cranking it for a good 10-15 seconds before it starts again as it will slowly build fuel pressure as you're cranking it.
Vitaliy93 is offline   Reply With Quote
Old 12-05-2010, 03:08 PM   #8
Amace013
I plugged back in the iacv it idles at 1500 and I tried the screw it doesn't do anything im pretty sure its the fuel pressure regulator I'm gonna buy an aftermarket one since they are cheaper than stock ones what's the correct fuel pressure for a b18b1. Also I'm just gonna run no iacv because without it my car idles and runs perfectly
Polished BDL Fuel Rail w/ AEM Fuel pressure regulator tx07civicsi Parts for Sale 8 01-05-2011 02:13 PM
Fuel Pressure regulator and pressure calue Eng. Tariq Tech Archive (No Posting) 0 03-25-2009 12:58 PM
wtb throttle body, Fuel pressure regulator,fuel rail, injectors BseriesEG Parts Wanted 0 04-26-2007 10:14 PM
Symptoms of bad fuel pump/fuel filter zach1288 Tech Archive (No Posting) 10 12-22-2006 09:12 AM
Wtb fuel pressure regulator or fuel rail b series 93egcoupe Parts Wanted 4 09-30-2006 11:36 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
