Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
Struts replace??
Responding Members:
User Tag List
Old 12-29-2010, 03:22 PM   #1
In my car
Question Struts replace??
The mechanic told me that my front struts need to be replaced, while he shakes his head. He went on to tell me that he'd never seen anything like that before (struts needing to be replaced on an ALMOST three year old car).
The struts are not visibly cracked, broken, or leaking. When the steering wheel is turned, the car makes a grinding noise. Thus the investigation to determine what was causing the noise.
1. In general, how often should struts be replaced (miles or years, or both)?
2. In general, how much should it cost to replace two struts?
3. What are some of the reasons they would fail?
Ironically, the car is past warranty (mileage). So this is probably an out of pocket expense.
In my car is offline   Reply With Quote
Old 12-29-2010, 06:33 PM   #2
Jabes
is the car lowered at all? and one way to check them is to push down on the front end near the tire on each side and if when you do that the response is really bouncy then its probably the struts
Jabes is offline   Reply With Quote
Old 12-29-2010, 08:01 PM   #3
lowlife9
lowlife9's Avatar
did you buy it used ??? how many miles are on it is it modified at all.
lowlife9 is offline   Reply With Quote
Old 12-29-2010, 10:30 PM   #4
In my car
The car has not been modified in any way, shape, or form.
I bought it new in 01/2008.
Have had all the recommended work done on it through the ownership.
Miles are high, but the mechanic said that struts, in general, do not need to be replaced, especially on a car with less than 100k miles.
Old 12-30-2010, 12:24 AM   #5
93Civicspeed
Maybe it was a faulty pair of struts, that happens sometimes, and struts for my Civic are $48 a peice before install and you can do it yourself if your mechanically inclined or you can have a shop do it it should about an hour each side
There is nothing like shiftin from first to second to third back down to second and down to first and than pulled over because you took off to fast from a stop light
93Civicspeed is offline   Reply With Quote
Old 12-30-2010, 08:16 AM   #6
In my car
So the $900.00 the mechanic quoted me is totally outrageous (to replace two struts)??
And odds are there is something wrong with the struts were probably faulty to begin with?
In general, how long do struts last on a car with careful/normal driving and great maintenance for the car?
Thanks guys!
Old 12-30-2010, 12:17 PM   #7
CivicxTree754
CivicxTree754's Avatar
Struts are suggested about 50k miles. Most are done by 100k under normal driving id say. 900 may have been all 4 parts and labor. I can see anyone with a labor rate that high.
I got hella skills im multi-talented,
I can work it fast or slow, so baby can u handle it? /
-Treez
My 5th gen LX build
http://www.clubcivic.com/board/showthread.php?t=199886
CivicxTree754 is offline   Reply With Quote
Old 01-02-2011, 03:16 PM   #8
LXDriver
More HP is always good
LXDriver's Avatar
Although I cant tell you for sure how long the struts should last, I think you can replace the struts on ur own and save the labor money. Heres this DIY I found might help:
http://www.clubcivic.com/board/showthread.php?t=130371
LXDriver is offline   Reply With Quote
replace or not to replace? Jenn6350 Exterior / Detailing / Bodywork 1 05-02-2009 12:13 AM
Stock 99-00 Si Struts, Struts/Springs Luminix bulbs (PA) luckylad82 Parts for Sale 17 02-26-2007 10:33 AM
How to replace a headgasket? kimsuprapa Engine Tech / Drivetrain 2 02-05-2007 11:32 PM
How would you take apart and replace the fenders? datssoled Tech Archive (No Posting) 5 09-20-2006 11:06 PM
Replace TPS? makmadison Engine Tech / Drivetrain 7 11-11-2004 07:15 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
