Will a d16z6 ecu work with a d15b?
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 02-11-2011, 10:12 PM   #1
EJmatt
EJmatt is on a distinguished road
Default Will a d16z6 ecu work with a d15b?
EJmatt is offline
Old 02-11-2011, 11:04 PM   #2
OblivionEK
OblivionEK's Avatar
OblivionEK is on a distinguished road
Yes and no, regardless of OBD you can make it work. The fuels maps for both engines will be different, but the first gen d15b will do fine; it'll run much like a z6. However, the OBD2 JDM d15b will not work right if; it will need a second vtec switch for 12 valve mode. You won't see the full 55 mpg benefit from 12 valve mode because fuel maps are different, but you can make it work.
http://i.imgur.com/HmuuZ.jpg
OblivionEK is offline
Old 02-11-2011, 11:32 PM   #3
EJmatt
What is the ecu that goes with the jdm d15 vtec, 5 speed engine?
EJmatt is offline
Old 02-11-2011, 11:35 PM   #4
OblivionEK
OblivionEK's Avatar
OBD1 or 2?
Old 02-12-2011, 05:41 AM   #5
ultimadum4thgen
ultimadum4thgen's Avatar
ultimadum4thgen is on a distinguished road
If your trying to run the P28 on an obd2 you would need a jumper harness and would have to wire it in.
Considering the money and labor of that wouldnt it just be cheaper to buy the right ecu?
Virgin P28= $85-100
Rywire Jumper= $105
Labor= Priceless
Cons to think about: Vtec wont hit right or maybe not at all an your engine will be running perty rich.
Or
Search around
Get on honda tech an theres the Virgin PO8(ecu for the jdm d15b)
shipped for 150
and you could proly find it cheaper on craigslist or at a junkyard
Good luck on this man.
EF90 Honda Crx
ultimadum4thgen is offline
D16z6 or D15b theSikid Engine Tech / Drivetrain 5 01-25-2010 04:43 PM
d16z6 or d15b TikeCiv Engine Tech / Drivetrain 7 11-22-2008 03:56 AM
d15b and the d16z6 that_sick_eg Tech Archive (No Posting) 29 07-04-2007 04:58 AM
D16z6 vs. D15b! 4doorSpoon Engine Tech / Drivetrain 3 03-18-2006 11:18 PM
d16z6 and d15b BigEars2303 Engine Tech / Drivetrain 1 05-18-2005 12:21 AM
