Search:
Welcome to ClubCivic
Constant revving up and down at idle
Responding Members:
User Tag List
Old 02-14-2011, 02:00 AM   #1
BeastMode0N
Default Constant revving up and down at idle
Hey, I gotta manual 1995 Honda Civic Hatchback. It has a d15z1 block with a d16z6 head. I just bought the car and when idling, the car revs from about 1200 to 2000 over and over pretty quick. It never corrects itself. When feathering the clutch, it idles fine. It drives quick as hell too. There arent any vacuum leaks. I don't think it's the idle contol either. Any ideas?
BeastMode0N is offline   Reply With Quote
Old 02-14-2011, 02:26 AM   #2
2NRSTV
Team Exile/ADO Garage
2NRSTV's Avatar
O2 Sensor maybe?
CEL on?
Feel free to visit TeamExile.Org to ask questions.
Or Email me directly to Tuner Steve
2NRSTV is offline   Reply With Quote
Old 02-14-2011, 02:29 AM   #3
slammedhatch
slammedhatch's Avatar
its the peice that is in back of ur intake maifold clean it or buy a new on it happend on my 94 hatch
slammedhatch is offline   Reply With Quote
Old 02-14-2011, 02:35 AM   #4
2NRSTV
2NRSTV's Avatar
^2x
Clean your IACV.
Old 02-14-2011, 03:32 PM   #5
reichbc
"Brandon"
reichbc's Avatar
reichbc is offline   Reply With Quote
Old 02-14-2011, 03:38 PM   #6
Clean and adjust the FITV attached to the bottom of the throttle body.
RonJ is offline   Reply With Quote
Old 02-14-2011, 07:28 PM   #7
Scrpn17w
Si wannabe
Scrpn17w's Avatar
There is a chance it could be low coolant as well. Definitely clean your IACV and make sure all the air is bled out of your coolant system.
http://profile.myspace.com/index.cfm...endid=80621435
Originally Posted by Blahman240 View Post
just yell vtec out the window when you're getting on it, its kind of like egging it on, then eventually it just gets louder.
Originally Posted by anonmassive View Post
i heard the louder the vtec, the faster the car.
Scrpn17w is offline   Reply With Quote
Old 02-15-2011, 12:46 AM   #8
BeastMode0N
Alright, thanks guys. Ill try to clean out the IAC
Old 02-15-2011, 01:58 AM   #9
civrex
i just did this today to my friend's car. it drove fine but idle was fluctuating. so first thing i did exactly in order was cleaned the intake idle air control valve out, then sealed around his sensor on the intake and pulled unpluged the battery for like a min and then we started it up and vroom no more funny idle problem fixed!!! check gasket's like around tb and vaccum line's ect.. with car running either with your hand and listen for idle changes or a piece of paper just go around everthing!
civrex is offline   Reply With Quote
Old 02-21-2011, 09:36 PM   #10
93civicloco
93 coupe
where is the iacv located on a 95 d15b7 mine is doing the same thing
93civicloco is offline   Reply With Quote
Old 02-21-2011, 09:45 PM   #11
For you^ and the OP:
For 92-95 Civics, this is a more common cause for a fluctuating idle. Click the FITV link in my signature.
Old 02-21-2011, 09:54 PM   #12
civrex
should be on back of the intake manifold two bolt's hold it in, it has two hoses connected to it, and one plug!
Old 02-22-2011, 09:57 PM   #13
93civicloco
93 coupe
ok thanks
Tags
civic
Constant power that_sick_ls Interior / Audio / Electronics 5 04-19-2010 03:32 AM
constant brake light mastashea20 Tech Archive (No Posting) 3 03-01-2010 08:12 PM
constant additions jinx Show off your 5th Generation Honda Civic (1992-1995) 80 05-03-2008 09:48 PM
idle/constant throttle problem.!!! help Kingjames83 Engine Tech / Drivetrain 10 07-16-2007 09:19 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
