Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
Clunking noise when turning left
Responding Members:
User Tag List
Old 03-04-2011, 09:10 PM   #1
Civvy4Life
Civvy4Life's Avatar
Default Clunking noise when turning left
Hey everybody,
I own a 89 crx and I recently redid most of the front end of my car (everything except for springs and struts) and I've noticed this clunking noise when I turn left or hit a bump. The sound is not constant, it only happens intermittently. As I've replaced all the ball joints and both cv's, is it possible the springs/struts are causing this noise?
Thanks
Civvy4Life is offline   Reply With Quote
Old 03-04-2011, 09:30 PM   #2
jordan00711
jordan00711's Avatar
Yes its possible
jordan00711 is offline   Reply With Quote
Old 03-04-2011, 10:19 PM   #3
evilrilla2
evilrilla2's Avatar
axle?
evilrilla2 is offline   Reply With Quote
Old 03-04-2011, 10:31 PM   #4
Kensai
Kensai's Avatar
Originally Posted by evilrilla2 View Post
axle?
Originally Posted by Civvy4Life View Post
Hey everybody,
Thanks
Since you've replaced the axles next place I would check is wheel bearings.
You can check them by lifting up the front end and grabbing the wheel at 6 and 12 o'clock(or 3 and 9, just has to be opposite sides) and trying to wiggle it, there should be little to no movement.
Also you should try lifting the front end and try to turn the wheel and spin it by hand to see if you can identify where exactly the the sound is coming from.
Hopefully this helps!
Kensai is offline   Reply With Quote
Old 03-05-2011, 10:22 AM   #5
JohnS.
BANGARANG
JohnS.'s Avatar
Also check the upper ball joint. If you don't tighten that crown nut enough, it can cause wiggling and a "clunking" noise.
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline   Reply With Quote
Old 03-05-2011, 06:42 PM   #6
Civvy4Life
Civvy4Life's Avatar
awesome, thanks for the help guys, i'll take a look at the wheel bearings and the upper ball joint
Old 03-05-2011, 07:06 PM   #7
00_Civic_Si
BrokenEM1
00_Civic_Si's Avatar
Also, try tightening all your lug nuts. This happened to me and I couldn't figure it out for like a week
Originally Posted by Raabe View Post
Who would want to go to war with Canada? That's like picking on the retarded kid, it's just not in good taste.
00_Civic_Si is offline   Reply With Quote
Clunking noise when at a stop to go 00CivicSiblue Tech Archive (No Posting) 6 03-17-2011 12:11 AM
Clunking noise JamieLemieux Tech Archive (No Posting) 7 03-15-2011 08:36 PM
clunking noise when turning 94'BLKBRD Tech Archive (No Posting) 2 05-11-2009 06:11 AM
Help - clunking noise Dexters96 Tech Archive (No Posting) 3 04-28-2009 11:19 PM
Clunking/Popping noise... banzai Tech Archive (No Posting) 6 09-19-2005 05:23 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
