Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Exterior / Detailing / Bodywork
Exterior / Detailing / Bodywork Includes exterior lighting and body styling
How to Replace 2000 Civic SI side mirror (do I have to remove the door panel?)
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 03-25-2011, 01:57 PM   #1
JasonL
JasonL is on a distinguished road
Default How to Replace 2000 Civic SI side mirror (do I have to remove the door panel?)
I've looked on this forum for replacing a side mirror but have not been able to find information regarding a SI model. I know the mirrors are similar buit some places on-line are saying you have to remove the door panel and others referring to LX and other models say you don;t have to remove the door panel just the little triangle. Any info would be great. thanks
JasonL is offline   Reply With Quote
Old 03-25-2011, 02:36 PM   #2
R3dline
f*** you.
R3dline's Avatar
Reputation level: 14
R3dline is on a distinguished road
yah pretty much, the little triangle has a wire to the tweeter. it doesnt have much play and you cant get it out of the way enough to get to the lil 8 mm nuts
Honda Pilot 4WD slow build
f*** yo jeep
R3dline is offline   Reply With Quote
Old 03-25-2011, 02:37 PM   #3
R3dline
f*** you.
R3dline's Avatar
plus there are only 2 screws and a one plastic clip , then it just pops out. its not hard man
f*** yo jeep
Old 03-25-2011, 02:39 PM   #4
mportedcivicsi
mportedcivicsi's Avatar
mportedcivicsi is on a distinguished road
I never take my door panel off to get to the mirrors. Just be easy as you pop off the triangle with the tweeter. 3 Si's and I've never damaged anything :)
1999 EM1 EBP On the Daily
2005 TSX ABP Wifey Daily
1999 EM1 FBP Wifey Daily - SOLD
2000 EM1 FBP Eaten by a car crusher
1999 EM1 MR SOLD
mportedcivicsi is online now   Reply With Quote
Old 03-25-2011, 02:43 PM   #5
R3dline
f*** you.
R3dline's Avatar
-shrug- i worked in a honda body shop, and we always took the panel off. 10x easier
f*** yo jeep
Old 03-25-2011, 02:59 PM   #6
JasonL
So pretty much I can replace it fairly easy by just poping out the little traingle. I just don't want to go thru the trouble of taking off the door panel the mirror inside broke and fell out and I just want to replace it with a OEM one I found at a junk yard that matches my paint.
Thanks for the reply, Hope I don't run into any issues.
Old 03-25-2011, 03:46 PM   #7
cgpEJ6
noob
cgpEJ6 is on a distinguished road
I don't have the tweeters by the mirror but I just pop the corner triangles out, never broken one. I see what you're saying about the wire getting in the way though, the door panels are easy to pop off too, just start at the bottom.
1997 Honda Civic LX – project car to be | 2010 Honda Fit Sport – daily driver
cgpEJ6 is offline   Reply With Quote
Old 03-25-2011, 03:47 PM   #8
jazzyJAE
Pandora's box
jazzyJAE's Avatar
jazzyJAE is on a distinguished road
2 minutes worth of work, makes it so there's way more room to work with
Originally Posted by guitar_adam2000 View Post
although i'd like to think its not quite the same as my Pog phase, the amount of money i spend on those s***ty cardboard caps is unreal
Wow a turtle neck and cats, mine as well tattoo I hate girl pussy on your forehead.
jazzyJAE is offline   Reply With Quote
Old 03-25-2011, 04:57 PM   #9
mportedcivicsi
Personal preference i guess. Its all good...both ways work :)
1999 EM1 MR SOLD
Old 03-25-2011, 05:07 PM   #10
JasonL
I know popping off the door panel is pretty easy but you have to disconect a couple of spots and pop out the clips holding the door panel and I just don't want to risk breaking or making anything else loose. I'm doing this tonight I'll come back on here after and let everyone know how easy it was.
Old 03-29-2011, 02:40 PM   #11
JasonL
Just did this over the weeked and it was extremely easy. You definetly do not have to take the door panel off to replace this mirror. Just pop off the triangle cover on the inside unscrew the 3 bolts and unplug the wiring connector. The bolts on the bottom were kind of lower than the door panel so I just pushed down on the panel to get the socket on them no damage. The only somewhat difficult part was just getting the triangle peice to fit back right but I just messed with is for about 3 minutes and it went back in right, I just had to pull back the door panel a little bit and then push the piece in with some force. But everything looks good, no damage and the mirror works.
Replace side mirror Malfa Tech Archive (No Posting) 5 11-03-2010 10:09 PM
WTB: Driver's Side Fender, possibly door panel (1998 Civic EX) 98civic_boii Parts Wanted 3 07-06-2009 07:16 PM
remove dx door panel!! helppp!!! mikey1714 Tech Archive (No Posting) 0 01-13-2009 12:37 AM
HELP! CANT remove door panel on civic 05 lilshorty Tech Archive (No Posting) 2 02-18-2007 09:19 PM
F***ed my side mirror, need to remove it 2kstreetcivic Exterior / Detailing / Bodywork 4 09-20-2004 10:53 PM
