Rough Idle, Stalls at stop???
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 05-16-2011, 09:00 PM   #1
Hopps493
Hopps493 is on a distinguished road
Default Rough Idle, Stalls at stop???
OK! I have a 93 Honda Civic EX 1.5L.
Yesterday I turn on my car and it seems as if it is idling really rough. but got worse when I put in reverse and drive. the car is jumping back and forth until i actually drive away then it rides fine. Now as I stop any red light or stop the car for any reason the car stalls out but will turn on right away. I can keep it from stalling by putting it in Park and giving it a little gas till the light turns green. There are somethings I have already done but the problem continues. I would appreciate some help from anyone. I don't know where to go from here. This has not been a on and off again problem it just started yesterday morning running that rough.
Things done:
New plugs and wires
New dist cap
new fuel pump
What else should I do?????
Hopps493 is offline   Reply With Quote
Old 05-16-2011, 09:08 PM   #2
R3dline
f*** you.
R3dline's Avatar
Reputation level: 14
R3dline is on a distinguished road
Maybe clean the iacv or the fuel filter?
Honda Pilot 4WD slow build
f*** yo jeep
R3dline is offline   Reply With Quote
Old 05-16-2011, 09:37 PM   #3
CivicxTree754
CivicxTree754's Avatar
CivicxTree754 is on a distinguished road
I've experienced low coolant causing rough idle sometimes. And you may loose some when you clean the iac.
I got hella skills im multi-talented,
I can work it fast or slow, so baby can u handle it? /
-Treez
My 5th gen LX build
http://www.clubcivic.com/board/showthread.php?t=199886
CivicxTree754 is offline   Reply With Quote
Did Valve adjustment now idle problems and stalls 99civicy8 Tech Archive (No Posting) 21 10-26-2010 01:50 PM
Engine stalls: Possible low idle problem bwahhj128 Tech Archive (No Posting) 2 05-31-2010 11:17 PM
Idles rough, stalls in neutral mikewetmore Tech Archive (No Posting) 11 05-18-2009 06:05 PM
rough idle egibbs1 Tech Archive (No Posting) 4 11-29-2008 11:34 AM
rough idle --> brake= not rough andre4444 Tech Archive (No Posting) 1 05-31-2007 07:32 PM
