Search:
Welcome to ClubCivic
Revs fluctuate, lights flicker, car dies out
Responding Members:
User Tag List
Old 06-20-2011, 02:46 AM   #1
Cupid22
Default Revs fluctuate, lights flicker, car dies out
I have a 97 Honda Civic LX. As I'm driving, the dash lights will all of a sudden start flickering, and dimming in and out. The check engine light comes on, and is still on. The revs will fluctuate, as I'm going a constant speed or accelerate, the revs will shoot up and down. The car does this off and on for a good 20-25 minutes until finally dying out. If anyone else had this problem and knows how to fix, please help me.
Thanks, all help appreciated.
Cupid22 is offline   Reply With Quote
Old 06-20-2011, 06:05 AM   #2
Blood_Shot
does it have trouble starting or is this just after you have been driving for awhile
Blood_Shot is offline   Reply With Quote
Old 06-20-2011, 02:18 PM   #3
Gunner
Gunner's Avatar
start by pulling your code..find out what the check engine light is tell you. It could be a lot of things at this point so start with the light. :) dying while driving would lead you to check your alternator and battery system also.
Gunner is offline   Reply With Quote
Old 06-20-2011, 02:25 PM   #4
Cupid22
Alternator has just been changed.
Old 06-20-2011, 02:33 PM   #5
Cupid22
It starts, and then will either act up early into the drive or after a while..
Old 06-20-2011, 02:51 PM   #6
Gunner
Gunner's Avatar
What is the code for? still could be several things.. sensor could be bad, computer, ignition system..etc.
Old 06-20-2011, 03:01 PM   #7
civic209
civic209's Avatar
Need code.
civic209 is offline   Reply With Quote
Old 06-20-2011, 03:15 PM   #8
young_
out on bail
young_'s Avatar
definitely pull the code, but you can also check the ground on your negative terminal off your battery, and make sure your alternator is properly grounded.
Originally Posted by lethal6 View Post
if I am going to take a baked cake from someone, it better damn well be young_. I have seen some of the stuff he puts down. Mmmmmmmmmm...
young_ is offline   Reply With Quote
Old 06-20-2011, 05:55 PM   #9
Cupid22
ok, just did the code checking and I got 5 codes
17- VSS Speed Sensor
20 - Electrical Load Detector
41- Primary Oxygen Sensor Heater
65- Secondary oxygen sensor heater wire (black wires)
67- Cat Converter
Old 06-20-2011, 07:58 PM   #10
young_
out on bail
young_'s Avatar
Damn, I can find you the speed sensor for 15 buck on eBay though. Autozone wants 90.
I just replaced mine and thankfully its an easy fix, this wasn't the case in mine but I read that the speed sensor gone bad can mess up all type of stuff, (inaccurate shift points, etc.)
Old 06-20-2011, 09:41 PM   #11
Is 7.5A dash fuse 15 blown? If so, click the fuse 15 TSB in my signature.
RonJ is offline   Reply With Quote
Old 06-21-2011, 04:51 PM   #12
mikemo
check engine ground also had most of same issues with my civic
mikemo is offline   Reply With Quote
Old 06-23-2011, 01:37 AM   #13
Cupid22
Ok, quick update...
Fuse 15 was surprisingly not blown...but I did discover there was an exposed wire behind the Intake Manifold Bracket. I taped it up, and the VSS and Cat Converter code went away...
I'm only left with the ELD, and the 2 Oxygen sensors
20, 41, and 65...I'll be replacing the the 2 Sensors, and see what happens afterwards...
another note, the Speedometer is still not working
Old 06-23-2011, 01:45 AM   #14
Test installed fuse 15 for voltage at both top test tabs with the key in ON(II). Click on the Fuses link in my signature.
GSR Civic starts, revs up, then dies. jdmjml Engine Tech / Drivetrain 1 08-20-2011 08:09 PM
push on gas and my lights flicker lvlistchif Engine Tech / Drivetrain 3 03-24-2010 07:44 PM
Dash lights flicker when car OFF! ? siebos Engine Tech / Drivetrain 2 03-16-2010 07:09 PM
speedo/cluster lights - flicker on n off 93vxgsaver Tech Archive (No Posting) 5 03-04-2009 01:54 PM
My car revs itself...any help? xposigroovex Engine Tech / Drivetrain 8 06-11-2006 02:06 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
