ls non-v motor to vtec help
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 08-31-2011, 11:56 PM   #1
Bennieboiy
Bennieboiy's Avatar
Bennieboiy is on a distinguished road
Exclamation ls non-v motor to vtec help
so i got a ls motor nd its ready for vtec
how do i install it
do i need a different head
extra parts lmk asap please
all opinions welcome help help help
Bennieboiy is offline   Reply With Quote
Old 09-01-2011, 11:16 AM   #2
2slo4u
wait4me
2slo4u's Avatar
Reputation level: 17
2slo4u is on a distinguished road
Well you'd obviously need a vtec head. Either the b16 or b18(gsr) heads are the popular choice. But I think you have a lot more researching to do because these questions shouldn't be asked. But I'll answer them anyway because we all start somewhere. You'll need to piece together a vtec conversion kit. It usually includes an oil line, sandwich adapter, dowel pins, vtec timing belt(which ever head you use) and vtec head gasket. Id recommend that you upgrade other things as well since the motor is out. Arp head studs and arp rod bolts are HIGHLY recommended. You might as well get a new oil pump and water pump Do not cheap out on the build! If you do you'll soon be making a "I blew my ls-vtec motor" thread. People do not build the motor correct and then complain later that the motor is reliable. And don't forget this important important important part...get it tuned!!
2slo4u is offline   Reply With Quote
Old 09-01-2011, 11:35 AM   #3
Bennieboiy
Bennieboiy's Avatar
well it already has new itr water pump itr new timing belt n itr new oil pump.
im going with the gsr head
Old 09-01-2011, 02:33 PM   #4
2slo4u
wait4me
2slo4u's Avatar
then now you need the oil line, dowel pins, sandwich adapter, headgasket and find someone who knows how to install it if you dont know how
Old 09-01-2011, 04:49 PM   #5
Bennieboiy
Bennieboiy's Avatar
so this is what i got a b18c head with mild port n polish with ge cams sticking with a ls dizzy for now skunk2 manifold arp head studs, n head gasket
kinda new to this whats the oil line, dowel pins n sandwhich adapter for?
Old 09-01-2011, 08:42 PM   #6
2slo4u
wait4me
2slo4u's Avatar
have you already tried bolting up the distributor onto the head? mine didnt fit.
the oil line goes from sandwich adapter to a hole in the head..the dowel pins go on the block..dont really know what they are for but you need them..
arp rod bolts are really recommended too.
its good to have a mildly built head but its more important to have your block built too to withstand the pressure..
Old 09-02-2011, 01:07 AM   #7
Bennieboiy
Bennieboiy's Avatar
oh ok well now i got everything else i got oil lines n sandwhich adapter too .
the ls dizzy head is on one leg but the gsr has 3 usually cut one to fit thats wat i have done and seen before no difference from gsr dizzy to ls dizzy.
Old 09-02-2011, 02:21 PM   #8
2slo4u
wait4me
2slo4u's Avatar
i've tried the ls distributor on a gsr head as well and had to cut as well..the non perfect fitment was noticeable during the tune so i recommend getting a gsr distibutor..sure it'll work but under tuning if the evidence is there that something is wrong..its not worth it..but its your choice..i just wouldnt cheap out on a ls-v build
honda should carry dowel pins if you didnt already get them
Old 09-02-2011, 03:40 PM   #9
Bennieboiy
Bennieboiy's Avatar
Alright i will do that i got everything so far now all i need is to build it btw would i need a different ecu or use the same one with a tune
Old 09-02-2011, 04:05 PM   #10
2slo4u
wait4me
2slo4u's Avatar
im sure a p28 chipped will be good..i know that p28's are used for many ls-vtec builds..im tuned on apexi power fc so i can't help much on ecu's
Old 09-02-2011, 06:28 PM   #11
Bennieboiy
Bennieboiy's Avatar
those are expensive lol
so stock ecu wont work right
Old 09-02-2011, 08:34 PM   #12
2slo4u
wait4me
2slo4u's Avatar
haha yes they are.but it pays to play
no stock ecu's wont work. atleast not your stock civic one
Old 09-02-2011, 09:45 PM   #13
Bennieboiy
Bennieboiy's Avatar
i know they do but i just want liil more hp nothing major n vtec people would throw opinions of building the block pistins and what not im not building it to race i just want it there after that maybe a turbo on it too,
o so a stock one wont but if a chipped it would it?
Old 09-03-2011, 12:48 AM   #14
Blood_Shot
Blood_Shot is on a distinguished road
you need a chipped VTEC ecu with a map for your LS/Vtec. It will run like total garbage on your stock ecu. Do NOT rev that b**** like a gsr or b16 the LS bottom end is not built for that.
you should of just bought a golden eagle kit would save you ALOT of headaches
Blood_Shot is offline   Reply With Quote
Old 09-03-2011, 06:18 AM   #15
Blood_Shot
they arent the popular choice they are the only choice lol
need a sohc vtec motor n a obd1 92-95 vtec ecu in NJ honda89ray Parts Wanted 8 10-11-2012 11:20 PM
d17 vtec motor jarrellem2 Parts Wanted 4 04-22-2009 10:50 AM
got a sohc vtec motor 4/s 4t 4doorbeast Parts for Sale 3 06-05-2007 09:23 PM
LS-VTEC Motor For Sale BigEars2303 Parts for Sale 18 05-05-2006 11:58 AM
Vtec Motor Question clifford_05 Engine Tech / Drivetrain 4 02-10-2006 04:56 PM
