Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
Ground Control Coilovers/Tokiko Blue shocks, Bumpy ride??? D:
Responding Members:
User Tag List
Old 09-17-2011, 11:48 AM   #1
Dnguyen92
Dnguyen92's Avatar
Default [B]Ground Control Coilovers/Tokiko Blue shocks, Bumpy ride??? D:[/B]
Hello CC,
I have a Civic EG 92 lowered on Tokiko blues in the back and ground control coil overs in the front. I'm sure if you have after market suspension your ride is supposed to be relatively smooth but my drive is always rambunctious as hell. Any clues as to what's going on?
Dnguyen92 is offline   Reply With Quote
Old 09-17-2011, 01:54 PM   #2
TigBitties
Frame Bangin
TigBitties's Avatar
what are you spring rates?
My Slow Build Thread
"Coupe Life" Member #2
I dont always drive, but When I do, I Prefer to drive Low *Stay Classy My Friends*
TigBitties is offline   Reply With Quote
Old 09-18-2011, 04:07 PM   #3
ek forever guy
ek forever guy's Avatar
The spring rates don't really matter, anything more than OTS is going to leave the whole setup underdamped. Tokico blues are an OE replacement not designed for increased suspension travel or stiffer rates.
You need new shocks, get some tokico illuminas. A really good shock. Koni sports won't work with the variety of GC you have.
ek forever guy is offline   Reply With Quote
Old 09-19-2011, 03:12 AM   #4
Dnguyen92
Dnguyen92's Avatar
Oh damn, so it'd be better to just swap out my springs in the back?(excuse me if im getting terminology wrong I'm new in the game.) Any ideas about my coil overs? There's another thing, When Im in reverse, in the front left wheel it sounds like the spring is being tugged on or something. Sort of sounds like someone is picking at a very tight metal wire if you know what that sounds like.
Old 09-19-2011, 06:27 PM   #5
ek forever guy
I'm still not sure what setup you have.
Ground control coilovers, on what shocks? Do you have two different setups on the front and rear?
Coilovers are typically the term prescribed to a full shock/coil sleeve assembly. A shock and spring are the two major components of the suspension. Coilovers are just generally adjustable height.
Old 09-20-2011, 03:58 PM   #6
Dnguyen92
Dnguyen92's Avatar
Yeah i have two different set ups. For my ground control coil overs, I can adjust them freely. I know that you're supposed to use a coil over key to adjust the height, but do you think mines are f***ed up? Because I can adjust it freely with my finger when i remove the wheel.
Old 09-20-2011, 04:09 PM   #7
Dnguyen92
Dnguyen92's Avatar
I was reading your thread on how to drop your car properly. You already know what kind of set up I have, ground controls in the front/tokico blues in the back. How can I even really determine the rate and how low I can drop my EG safely? Remember, I'm new! But I've been doing the same as you, saving up waiting patiently. As for keeping the car I'm not sure. It's salvaged and this stock sohc isn't as fun as I thought it'd be. I can't even tell when Vtec kicks in! Or if it even kicks in at all! I have alot to learn about this.. so any info will be greatly appreciated!
Old 09-20-2011, 05:31 PM   #8
speedygonzales
Royal Member ~ RonJ
speedygonzales's Avatar
I know this might be a lil off topic but only the ex and si (d16z6) eg's had vtec. and it'll take headers and exhaust to be able to tell if vtec is kicking in... even then its kind of hard but you'll notice the rpms getting higher faster. And as for how low and safely? it depends on how much work you put into it and how careful you are. you just throw shocks and springs on it and not take the time to do it right it will never be safe, but if you take your time and do it right you could be scrapping the ground every time there is a slight imperfection in the road and the only thing you'd really have to worry about is your oil pan lol
Originally Posted by RonJ View Post
During the overnight PB Blaster soak of the bolt, re-soak it several times. Drink lots of beer between soaks.
The bolt will pretend to challenge your manhood. Don't let it win.
speedygonzales is offline   Reply With Quote
Old 09-20-2011, 08:20 PM   #9
Dnguyen92
Dnguyen92's Avatar
Ooh true. Well I bought the car like that.. and I was reading up on the 92 cx's and it said the d16 vtec kicks in at 4500.. I guess I dont have it then? because my head said Vtec and It is a d16z6. Idk man. Oh and just coming into my drive way, I heard 1 loud pop coming from my driver side. I'm guessing its the coil overs.. any idea what is causing the pop? D:
Old 09-20-2011, 09:08 PM   #10
civexspeedy
civexspeedy's Avatar
I'm not very clear with what exactly you have for your suspension.
Tokico blues are shocks. Ground Control sells coilovers. They are 2 seperate things. From what you are tell us, we are only getting half of the information we really need.
What shocks do you have on the front? What shocks are on the rear? What springs/coilovers are on the front? What springs/coilovers are on the rear? That should help clear things up a bit.
What do the springs on the coilovers say on them? There should be numbers stamped on them that look like this:
Give us the numbers and we can help figure out what shocks to use or if you need to change your springs. In most cases, if you lower a car or modify the suspension, you will have a more uncomfortable ride. Moreso when you use coilovers.
No your GC's are not messed up. To adjust them, you loosen the allen bolt that's in the spring perch and then spin the perch up or down the collar. It is supposed to move up and down easily by hand. When you are done adjusting, tighten the allen bolt back up. Keep in mind that when ever you make significant height changes to your ride height, you will need to have the car aligned. Raising or lowering a car changes camber and toe settings.
Karcepts - SSC Tint & Graphics
'07/'08/'09/'11/'13 Autocrossers Incorporated ST Champion. '08/'09/'10/'11/'12/'13 Washington D.C. Region ST Champion. '08/'11 Capital Driving Club Small Bore Series Champion. '11 CDC Index Champion. '10/'12/'13 NCCBMWCCA X4 Champion.
civexspeedy is offline   Reply With Quote
Old 09-20-2011, 09:43 PM   #11
Dnguyen92
Dnguyen92's Avatar
oooh ok, i plan on changing my breaks and rotors this week so when i lift them i'll take some pictures. Thanks for the tips speedy! Very useful info and I'll keep you guys updated this week. I really appreciate the help.
Old 09-20-2011, 10:39 PM   #12
Puma
Has no filter
Puma's Avatar
Main problem: you have 2 different setups. Best ride=1 set up, and coilovers.
/thread.
Puma is offline   Reply With Quote
Old 09-20-2011, 11:47 PM   #13
Dnguyen92
Dnguyen92's Avatar
So do you think I should get rid of everything and just buy one whole new set?
Old 09-21-2011, 12:07 AM   #14
Puma
Has no filter
Puma's Avatar
Well, yes.
Old 09-21-2011, 09:33 PM   #15
Dnguyen92
Dnguyen92's Avatar
So i got an oil change today, and they told me the status of my alignment. Apparently it's really bad. So bad it has caused my cv boots to tear. LOL. Sooo I'm probably going to have to put new ones in.. but any idea how I can adjust my height properly so that I don't break or tear anything.
koni shocks/ground control set-up paul_a Wheels / Tires / Brakes / Suspension 0 10-07-2010 07:15 PM
What springs go good with Tokiko Blue Shocks EGxBru Wheels / Tires / Brakes / Suspension 7 05-15-2010 11:30 AM
Ground Control Coilover Sleeves...Shocks ? SIckCIVIC89 Wheels / Tires / Brakes / Suspension 5 04-22-2010 04:21 PM
Ground Control Coilovers w Skunk2 Shocks 99ExDriver Wheels / Tires / Brakes / Suspension 3 09-04-2007 03:19 AM
Ground Control Coilovers mistaree Tech Archive (No Posting) 14 01-10-2005 08:25 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
