Search:
Welcome to ClubCivic
91 Civic Hatch Thermostat Replace?
Responding Members:
User Tag List
Old 10-06-2011, 04:58 AM   #1
1991CivicEf9
Cruiser
1991CivicEf9's Avatar
Default 91 Civic Hatch Thermostat Replace?
I have a bad thermostat in my 91 civic hatch. Stock motor. Is there anything else I should replace while doing the thermostat? My buddy told me to replace the Thermostat switch aswell but i'm not sure. Also, how would I go about replacing the thermostat? Remove the top rad hose that goes to the engine and go from there?
1991CivicEf9 is offline   Reply With Quote
Old 10-06-2011, 05:04 AM   #2
Kensai
Kensai's Avatar
If you ran low on coolant its probably a good idea to replace the coolant temp. sensor.
Check the hoses while you're at it as well!
Kensai is offline   Reply With Quote
Old 10-06-2011, 05:52 AM   #3
Blood_Shot
how do you know its bad
when was the last time you had that fluid changed?
things to think about
Blood_Shot is offline   Reply With Quote
Old 10-06-2011, 12:11 PM   #4
jlicrx
jlicrx's Avatar
first off, you should get a service manual for your car and not listen to your buddies - the manual will tell you everything you need to know in making repairs
second, your buddy is most likely referring to the switch that is on the thermostat housing on 92 and up cars, but it is not located there on a 91 - that switch is the cooling fan switch - on the 91, the cooling fan switch is on the back of the block next to the oil filter - if your cooling fan is working, the switch is o.k
third, the thermostat is not located where the top radiator hose goes into the engine - it is located where the bottom radiator hose goes into the engine, which is just behind and below the distributor - this is the instructions from the 91 factory service manual for replacing the thermostat
ZCspeed Racing
jlicrx is offline   Reply With Quote
Old 10-06-2011, 05:27 PM   #5
1991CivicEf9
Cruiser
Well for one, When I run my car till it gets hot (a few miles or so) and turn it off, it won't start back up. It just cranks but does not turn over and actually start. I replaced the ECT sensor, so it was not that. So I turned the car off when it was hot, took the rad cap off, and tried to start it again. It shoots fluid like a fountain, so basically the thermostat isn't opening up to let it go thru the engine.
Old 10-06-2011, 06:51 PM   #6
jlicrx
jlicrx's Avatar
not starting when the engine is hot can sometimes be a faulty igniter in the distributor - do you have any codes showing on the ECU? - a faulty igniter would be code 15, meaning the red LED on top of the ECU will be flashing 15 times
ZCspeed Racing
Old 10-06-2011, 07:20 PM   #7
1991CivicEf9
Cruiser
Wouldn't that throw a CEL?
Old 10-07-2011, 01:51 AM   #8
Blood_Shot
yes he said it thows code 15
Free Mishimoto Hose Kit(s), Thermostat, & Fan shroud (92-00 Civic) Mishimoto Off Topic 42 02-26-2010 03:10 PM
What replace the Civic RS (01-03) in 04-05? Hondan. Show off your 7th Generation Honda Civic (2001-2005) 3 05-19-2009 05:05 AM
99 DX Hatch Thermostat Replace, How do I? dx driver 99 Tech Archive (No Posting) 0 04-12-2009 08:40 PM
Replace thermostat? Dough Tech Archive (No Posting) 15 03-02-2008 09:20 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
