Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
High Idle & Vtec Not Wired
Responding Members:
User Tag List
Old 11-26-2011, 12:28 PM   #1
irawkian_EK9
irawkian_EK9's Avatar
Default High Idle & Vtec Not Wired
ok... My Car has a high idle when sittin in neutral and Have no idea why.... Spec's: D15B Swap in 2000 Hatch DX - 2nd Problem is how to hook up the Vtec...to a DX Model Hatch......
irawkian_EK9 is offline   Reply With Quote
Old 11-26-2011, 12:31 PM   #2
2slo4u
wait4me
2slo4u's Avatar
What ecu are you using? You can wire the vtec straight from your solenoid to the ecu. There are tutorials online.
2slo4u is offline   Reply With Quote
Old 11-26-2011, 12:55 PM   #3
irawkian_EK9
P2E-A92 is whats in the car right now. - I Have another ECU from my 97 Coupe EX but the last clip doesnt fit....
Old 11-26-2011, 01:29 PM   #4
2slo4u
wait4me
2slo4u's Avatar
D15B VTEC
* Found in:
o 19921995 Honda Civic Vti (Japanese Market)
o 19921998 Honda CRX DelSol (Japanese Market)
+ Bore and Stroke :75,084,5 mm
+ Displacement : 1,493 cc (91.1 cu in)
+ Rod Length : 137 mm
+ Rod/Stroke : 1.62
+ Compression : 9.3:1
+ Power : 130 PS (96 kW; 128 hp) at 7,000 rpm
+ Torque: 106 Nm
+ V-tec switch over : 5,500 rpm
+ Redline : 7,200 rpm
+ Rev-limiter : 7,500 rpm
+ Valvetrain : SOHC (4 valves per cylinder)
+ Fuel Control : OBD-1
+ Head Code : P28
+ ECU Code: P08 (small case ECU)***
according to this you have to use the P08 ecu..the clip wont fit unless you have a obd2b-obd2a conversion harness
if above is true(specs) then the ecu is probably what is causing the a/f ratio to be messed up hence the idling problem
vtec wiring
http://www.hondacivicforum.com/forum...rmation-73241/
Old 11-26-2011, 02:22 PM   #5
irawkian_EK9
ok 2slo4u youre the man.. lol thanks for the info.. have to find a P08 I guess
Old 11-26-2011, 04:21 PM   #6
2slo4u
wait4me
2slo4u's Avatar
Old 11-27-2011, 03:07 PM   #7
irawkian_EK9
oh 1 more question.... when I first start the car and go driving... 30 mins into driving all gears turn to neutral.... if I let it sit for 10 mins it goes back to driving again until a few minutes later all gears turn to neutral again...
Old 11-27-2011, 03:20 PM   #8
reptlcal
Caillou
reptlcal's Avatar
Also try cleaning your iavc and check for vaccum leaks which will fix your high idle problem.
reptlcal is offline   Reply With Quote
Old 11-27-2011, 03:49 PM   #9
irawkian_EK9
I would like to post pics of the vac leaks on here... how do I do so.... or any of you have a email addy or such would be highly appreciated.. Im a total noob so in need of help lol thank you..
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 3 05-20-2011 02:02 AM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 1 05-19-2011 07:25 PM
high idle, low idle, high idle, low idle.... jkcivic Tech Archive (No Posting) 7 09-14-2009 12:55 AM
swaped & wired but nothing bugethatch Tech Archive (No Posting) 5 01-27-2006 07:35 PM
Is a 92 DX wired for VTEC? hondadna Tech Archive (No Posting) 12 12-09-2004 01:13 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
