Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
Air vents won't stop blowing hot air. Need help.
Responding Members:
User Tag List
Old 11-28-2011, 08:38 PM   #1
96MidoriEK
Default Air vents won't stop blowing hot air. Need help.
For some reasons, my vents won't stop blowing hot air once the car reaches operating temperature. Even if I adjust the temperature all the way to cold.
So whenever I drive on the freeway, the vents won't stop blowing hot air and it gets really hot inside the car. I tried moving the temperature all the way to hot and the air becomes even hotter. Moving the temperature back to cold only makes the air a bit "warmer" but it's still hot air
I already made sure the wire thing attached to the back of the climate control is connected correctly.
Is it because my car has no A/C? I thought it would at least blow outside air temperature even with no A/C.
I drive a 96 civic cx btw.
96MidoriEK is offline   Reply With Quote
Old 11-28-2011, 08:50 PM   #2
Mysteryemotionz
Mysteryemotionz's Avatar
My car does the same thing. In theory its suppose to blow the outside air in but the inlet.for the outside air is still in the engine bay.
I just just usally shut the air all the way off. that's temp control all the way on blew and the actual switch in the off postion. I then also shut the vent switches off.
If my windows fog up and I need to keep the defrost on I crack both the drivers side and passenger side windows. No lower then the vent shades. Put the temp less then half way and the power on 1. This usally keeps me from getting extremely hot
Sent from my SPH-D700 using Tapatalk
Mysteryemotionz is offline   Reply With Quote
Old 11-28-2011, 09:02 PM   #3
io_303
NIFOC
io_303's Avatar
There is a valve on the hose attached to the heater core. Most likely the valve isn't or can't close all the way.
DD: 2003 Eclipse GT
WIp: SBF 1985 RX7 on the bottle
io_303 is offline   Reply With Quote
Old 11-28-2011, 09:02 PM   #4
MartieMar
MartieMar's Avatar
Hey what you may want to check is to see if the cable has came loose on the slider if you have one. Just check both ends. Then check whhere the vents are it may have some junk buillt up on the to keep them from closing all the way. That's my best guess. Hope that helps in some way
Sent from my AT100 using Tapatalk
MartieMar
MartieMar is offline   Reply With Quote
Old 11-28-2011, 09:58 PM   #5
96MidoriEK
Are you talking about the cable that's attached to the back of the climate control? Climate control as in the part where you adjust the temperature to hot or cold.
Old 11-28-2011, 09:59 PM   #6
96MidoriEK
What do I need to take off to get to the heater core for this valve?
Old 11-28-2011, 10:35 PM   #7
io_303
NIFOC
io_303's Avatar
Not sure on an ek, but back on my 4th gen and my matrix it was just under the hood on a coolant line running to the firewall.
DD: 2003 Eclipse GT
Old 11-28-2011, 10:56 PM   #8
MartieMar
MartieMar's Avatar
Yeah check all the cables on both ends and check the vents that they open and close. If that is good the check that heater core vent that was mentioned.
MartieMar
Old 12-04-2011, 07:29 PM   #9
xowiickedox
just turn on the buttom that makes the air in the car recirculate instead of bringing in new heat my car does this alot but once i make it curculate inside it stops in my 00 lx the button is next to the ac it looks like a car with a utun logo inside lol
xowiickedox is offline   Reply With Quote
A/C blowing hot air..help needed iluvpho Tech Archive (No Posting) 14 06-09-2010 12:56 AM
Cold air only blowing out of right and left vents ncarme Tech Archive (No Posting) 1 07-30-2009 12:26 AM
Air only blowing through feet vents - suggestions? Adam_Schwartz Interior / Audio / Electronics 4 02-28-2007 04:18 PM
Ram Air Intake Sucks Hot Air? Arcane Hayter Tech Archive (No Posting) 12 05-21-2006 12:50 AM
where do the air vents lead to? natedoggx331 Tech Archive (No Posting) 4 02-19-2005 07:14 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
