Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
Best oil for D series
Responding Members:
User Tag List
Old 12-05-2011, 09:00 PM   #1
Ek_98civicPR
Default Best oil for D series
Hey guy's just wondering what's the best oil for D series engines. It's my 2nd Civic but first time changing oil on Civics. Thanks
Ek_98civicPR is offline   Reply With Quote
Old 12-05-2011, 09:22 PM   #2
ek forever guy
ek forever guy's Avatar
It really doesn't matter as long as you change it often enough and use a quality filter.
I only use synthetic so I don't feel bad when I go 10,000 miles on an oil change.
Mobil 1 is good, Royal purple is outstanding. I've also used Castrol Syntec dino oil plenty of times too.
The bottom line is it is a Honda engine, you're not going to do anything to it unless you seriously neglect it.
ek forever guy is offline   Reply With Quote
Old 12-05-2011, 09:22 PM   #3
97civicMan
Knucklehead h8r
97civicMan's Avatar
I personally use Castrol GTX and have been for years! Pretty good stuff.
My FS Thread. You won't find this stuff @ WalMart!!
http://www.clubcivic.com/board/showthread.php?t=194933
97civicMan is offline   Reply With Quote
Old 12-05-2011, 10:04 PM   #4
Ek_98civicPR
Alright thanks guy's for sharing your opinions. I've used Castrol & Mobil 1 on my 92 Accord though. So Im going to use 10w30..? Is that fine?
Old 12-05-2011, 10:17 PM   #5
ek forever guy
The oil cap says 5w30.
Old 12-05-2011, 10:36 PM   #6
ImportFan1
Super Moderator
ImportFan1's Avatar
Check in the manual. Should tell you based on the region of the county you are in.
R.I.P. Revolver, EM1_Project, and Melt
VSM Crew #43
(Updated 11/24/12)
ImportFan1 is offline   Reply With Quote
Old 12-05-2011, 10:41 PM   #7
emerican
emerican's Avatar
I run 10w30 with no problems what so ever like mentioned above its a honda it will be fine.
Y8 AEM sri, Yonaka catback exhaust Megan 4-2-1 header, Megan racing high flow cat, front and rear upper strut tower bars, front and rear lower tie bars, ngk plugs and wires, summit racing distributor cap and rotor button, Accel super coil, AEM ps pulley, c-pillar bar, BWR LCA's, BWR subframe brace,Auto meter A/F and volt gauge, slim fan, maxbore tbody
http://www.clubcivic.com/board/showthread.php?t=200155
Originally Posted by CHILD View Post
painted carbon fiber is like wearing a zipped up jacket over a purple label shirt
emerican is offline   Reply With Quote
Old 12-06-2011, 12:54 AM   #8
Ek_98civicPR
Ok thanks a lot ya'll. I have plans with the coupe unless I sell it to buy a CB7 coupe again
Old 12-06-2011, 01:13 AM   #9
MistahJuice
100% real juice
MistahJuice's Avatar
GTX FTW, not meaning to thread jack but is it true wants you switch to synthetic you cant go back?
"Sedan Life" Member #1
MistahJuice is offline   Reply With Quote
Old 12-06-2011, 01:22 AM   #10
Osiris19
oilBurner
Osiris19's Avatar
I never fully understood oil viscosity. What's the difference in 10w-30 to 5w-30 and are there any benefits over the two?
Sent from my ADR6300 using Tapatalk
Vehicles I've Owned
1992 Honda Civic LX 4dr = [Link] - Sold
1993 Honda Civic DX HB = [Link] - Sold
1996 Acura Integra LS (auto) = [Link] - Sold
1996 Acura Integra LS (manual) = [Link] - Current
Originally Posted by 00_Civic_Ex View Post
Does your daily routine include picking up 2 more whores? cause you know.. 2 more doors = 2 more whores..
Originally Posted by dj_hallucn8 View Post
What kind of Civic you have? Mess it up?? The car is like a set of legos, easy to take apart & put back together, it's not a dream.
Osiris19 is offline   Reply With Quote
Old 12-06-2011, 01:29 AM   #11
James315
James315's Avatar
you can go back from sythetic to conventional depending on which brand there is ways to do it i know for a fact to swith from royal purple to conventional they recomend letting all your oil drain out and wait til its not even dripping with the filter off too and pour 1 quart of the oil your switching too through the engine with the drain plug still out to flush it out and your suposed to be good i got friend who did the switch and hes having no issues he just changed his oil after a 1000 mile for extra security.
James315 is offline   Reply With Quote
Old 12-06-2011, 01:31 AM   #12
James315
James315's Avatar
10w 30 is good down to a certain temp dont remmeber what the temp is and 5w 30 is suposed to be good for all temps
Old 12-06-2011, 01:35 AM   #13
MistahJuice
100% real juice
oo oo i looked this up somewhere once. the lower number is its cold viscosity while the higher number is its warm one. basically 5w30 is better for colder weather since its first number is lower, while 10w30 can be used in warmer weather. But the 5w30 has a larger distance and therefore uses more modifiers to let it have that wide of a range and less oil basically it wouldn't matter in a well designed and maintained honda, but I guess if it starts to over heat or gets left in too long 5w30 has a bigger chance of degrading and causing carbon deposits so 10w30 is a good choice if your not in snowy weather or something. But like I said with regular oil changes and maintenance 5w30 works just fine.
Old 12-06-2011, 01:36 AM   #14
MistahJuice
100% real juice
and ok, cuz one of my dumb friends let the dudes at jiffy lube convince him that synthetic was better than standard oil for is 1990 Honda Civic with 200,xxx miles and he ended up spending like $80 on an oil change. Not to mention the didn't tighten the filter all the way. An I was gonna have him switch back to regular or at least hondas synthetic blend and just get his oild changed at honda from now on unless he decides he wants me to teach him how to do it himself
Old 12-06-2011, 01:37 AM   #15
cgpEJ6
noob
I use Mobil 1 just for the simple fact that it's available pretty much everywhere. Most oils are going to do you just fine, the only one I would avoid is conventional Pennzoil. It protects fine but it stains more than other oils and it kind of stinks too (my experience from working in an oil change place for a year). I used 5w-30 in my Civic and 5w-20 in the Fit. I might go to 0w-20 in the Fit soon. To keep it simple, the lower the number, the thinner the oil. The thinner the oil, the easier it is to start.
cgpEJ6 is offline   Reply With Quote
help with civic d-series burning oil 96ejsedan Engine Tech / Drivetrain 3 10-03-2010 04:12 PM
B Series Oil Pan killrhatch Engine Tech / Drivetrain 4 08-28-2007 07:35 PM
d series tapped oil pans! 92sickw/it Parts for Sale 10 05-12-2006 01:02 PM
B series oil pan io_303 Engine Tech / Drivetrain 1 08-15-2005 03:20 AM
f/s: d-series oil pan x007den Parts for Sale 1 07-30-2005 08:19 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
