Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic DIY / How To > DIY How To's > Engine Tech / Drivetrain DIY How-To's
How To: J32a2 into civic/integra/ etc
User Tag List
Old 12-06-2011, 08:01 PM   #1
FerioEk247
the nerd/geek
FerioEk247's Avatar
Thumbs up How To: J32a2 into civic/integra/ etc
Ok since alot of people want to keep this info hush hush or what not. I have done countless hours of research and looked up on many forum and manuals etc. There are some people who are helpful and some who are not. I am putting this together to help the ease of J swaps in the future.
hopefully i covered the jist of what needed to wire up the J32a2. if i did not please feel free to correct me. Also hopefully this gets stickied!
Please if you use this info, Please give credit to me "EJ32A, FerioEK247" aka Anthony L., for doing all this research and etc. Also credit to TwistedImage aka Chad for confirming shock tower wiring, C131 wiring from his Auto to manual swap.
Anyways this "how to" will cover
1. C131 Plug - green plug: located by passenger kick. it helps run some function to the cluster
2. Civic C101, and Acura C101 & C102 Shock tower plugs: wiring conversion
3. Auto J series engines "A" plug for ECU wiring
4. Manual J series engine "E" Plug for ECU wiring
5. Secondary O2 sensor wiring "buy a female plug end and run extra wires to reach 2nd o2 sensor."
6. CL type S cluster: wiring "optional WIP"
Somethings are optional, but this is pretty much all you have to hook up to get it fired up and running...
tid bit: 96-98 engine harness is one piece that comes with green plug. But 99-00 the green plug is separate. which need to be wired up. if your like me, and have one car. goto the junk yard and pick up a male end plug off a civic from 96-00 from the interior.
"A" auto ECU and "E" manual ECU plugs are 90% same as for wiring up to the C131 plug and ECU. So all you have to do is wire the C131 to the
1. C131 green plug - located at the passenger side kick panel. It wires up to the main interior harness which as well to the cluster. "Thanks to TwistedImage for confirming my wiring"
There are only 8 wires the need to be wired up. From the "A" auto ecu plug, and the "E" plug Manual.
below is "A", "E", and C131 Pinouts
J32a2 ECU "E" plug Pin outs
J32a2 ECU "A" Plug Pin outs
Civic C131 Plug Pin outs
ok use the pictures above for reference and wiring up your "E" or "A" plug to the C131 green interior plug.
"HOW TO" wires need to C131 wiring.
C131 green plug Civic, goes to "E" Plug/ "A" Plug
Pins-------Color-------Description
6-----------Green---------Fan Control "tap in-between "A" or "E" plug and C131 to Tempsensor green wire"
8-----------Green/Orange---------MIL "Malfunction Indicator lamp"
9-----------Brown---------Service Check Signal "For DLC"
16---------Green/Red---------ELD "Electrical Load Detector"
17---------Green/White---------BSWS Brake switch signal
18---------Blue/White---------VSSout Vehical Speed sensor output
20---------Green/Yellow---------Fuel Pump Relay
21---------Blue/White---------K-line "for DLC"
that should all be needed to wired the C131 green plug.
2. Sock tower plugs: Converting CL C101 & C102 plugs to civic and so forth. "Thanks to TwistedImage for confirming my wiring"
CL C101 & C102 plug pin out
C101
C102
Civic C101
-it is quite simple, to hook up. follow the steps below, then voila!
"HOW TO" Shock tower wiring
- Merge all Black/Yellow wires together
-2 off civic plug
-2 off CL engine harness
tip
- Cut both C101 and C102 plugs off CL Engine Harness, and extend 7-8 inches to reach the Civic/integra female end shock plug.
90% of wiring match up.
Civic C101 plug Cl type-S C101 and C102 plugs
Pin-----Color----------------Descripton----------------connects to
10-----Black/Yellow--------Ignition 1----------------Merge to all black/yellow wiring to single wire
9-----Black/white-----------Starter signal----------------C101 10 pin plug, pin 9 "black/white"
8-----Blue------------------- RPM/Tach----------------Run extra wire all the way to the ECU "E" or "A" plug to BLUE "NEP"
7-----Yellow/Green--------Temp Gauge----------------"not used"
6-----White/Blue-----------Charging system light----------------C102 14 pin plug, Pin 14 "white/blue"
5-----Yellow Black----------PGM-FI?----------------C101 10 pin plug, pin 7 "Yellow/Black"
4-----Brown/Black----------ECU Ground/logic ground----------------C102 14 pin plug, Pin 5 "Brown/Yellow"
3-----Yellow/Red-----------Oil Pressure light----------------C102 14 pin plug, pin 1 "Yellow/Red"
2-----Black-------------------Chasis Ground----------------C101 10 pin plug, pin 5 "Black
1-----Black/Yellow---------Ignition 1----------------Merge to all black/yellow wiring to single wire
there will be a lot of left over wires from CL harness which is not used. so mask or wrap off.
-CL C101, Fan Control "green" wire runs extra wire to Thermostat plug "tap into green wire".
FerioEk247 is offline   Reply With Quote
Old 12-07-2011, 12:44 AM   #2
FerioEk247
the nerd/geek
FerioEk247's Avatar
pin outs and descriptions
"A" plug MT that needs to be wired up
Pin-----color-----Description----------------------------------where it goes
15------Green/Yellow-----Fuel pump relay/IMMOFPR-----C131 plug, pin 20, Green/Yellow
8------Black/white-----Secondary o2 sensor Control-----Need extra Male/female plug and extend to catalytic converter
19------Blue-----NEP/RPM "engine speed pulse -----Runs extra wires to Shock tower Plug Civic C101
18------Green/Orange-----MIL malfunction indicator lamp----- C131 plug, pin 8, Green/orange
24------Blue/orange-----STSW Starter switch signal ----- Run extra wire to Fuse 30, under driver side dash "starter switch signal"
32------white/black-----Brake switch signal ----- C131 plug, pin 17, Green/white
17------Red-----AC clutch relay "optional"
10------Brown-----Service check signal "DLC" -----C131 plug, pin 21, brown
1-------white/red-----Secondary o2 sensor 2 -----Need extra Male/female plug and extend to catalytic converter
30------Green/red-----ELD electrical load detector C131 plug, pin 16, green/red
26-------Green-----Power steering pressure switch "optional" -----runs to power steering high pressure line
27-------Blue/red-----AC switch signal "optional"
9---------Blue/white-----VSS vehicle speed sensor out -----C131 plug, pin 18, blue/white
21--------Grey-----K-line "DLC" -----C131 plug, pin 21, blue/white
29--------light green-----Fuel tank pressure sensor
12--------Pink-----Immobilizer light -----runs extra wire to Cluster
13--------Blue-----Immobilizer Enable signal -----runs to ignition by key "same color wires"
25--------RED-----Immobilizer Code -----runs to ignition by key "same color wires"
20------Green-----Fan control -----C131 plug, pin 6, green
tip
-when wiring immobilizer, the last remaining wire is
black/white - Connects to "A" plug sG1 "sensor ground"
brown/yellow - Connects to "A" plug LG1 "logic ground".
Optional for emissions
96-00? Civic FTP and EVAP Bypass solenoid valve
EVAP canister vent shut valve
[/CENTER]
"A plug"
4 - Light green/white - VSV Evaporative emission (EVAP) Canister vent shut valve
3 - Blue - 2WBS Evaporative emission (EVAP) bypass solenoid valve
29 - light green - FTP Fuel tank pressure sensor
4. Manual J series engines "E" plug for ECU wiring
"E" plug MT that needs to be wired up
Pin-----color-----Description-----where it goes
1-----Green/Yellow-----Fuel pump relay/IMMOFPR-----C131 plug, pin 20, Green/Yellow
2-----Black/white-----Secondary o2 sensor Control -----Need extra Male/female plug and extend to catalytic converter
3-----Blue-----NEP/RPM "engine speed pulse-----Runs extra wires to Shock tower Plug Civic C101
4-----Green/Orange-----MIL malfunction indicator lamp-----C131 plug, pin 8, Green/orange
9-----white/black-----Brake switch signal-----C131 plug, pin 17, Green/white
12-----Red-----AC clutch relay "optional"
13-----Green-----Fan Control-----C131 plug, pin 6, green
14-----Yellow/green-----ECT Engine coolant temp-----Run extra wire to cluster
15-----white------Reverse lock out-------run extra wire to solenoid by tranny shifter. white and black wires. tap into white wire.
16-----Brown-----Service check signal "DLC"-----C131 plug, pin 21, brown
18-----white/red-----Secondary o2 sensor 2-----Need extra Male/female plug and extend to catalyic converter
19-----Green/red-----ELD electrical load detector-----131 plug, pin 16, green/red
20-----Green-----Power steering pressure switch "optional"-----runs to power steering high pressure line
21-----Blue/red-----AC switch signal "optional"
26-----Blue/white-----VSS vehicle speed sensor out-----C131 plug, pin 18, blue/white or straight to Cluster VSSin "CL-s cluster"
27-----Grey-----K-line "DLC"-----C131 plug, pin 21, blue/white
28-----light green-----Fuel tank pressure sensor
29-----Pink/white-----Immobilizer light-----runs extra wire to Cluster
30-----Blue/white-----Immobilizer Enable signal-----runs to ignition by key "same color wires"
31-----RED-----Immobilizer Code -----runs to ignition by key "same color wires"
tip
"E plug"
22 - Light green/white - VSV Evaporative emission (EVAP) Canister vent shut valve
23 - Blue - 2WBS Evaporative emission (EVAP) bypass solenoid valve
28 - Light green - FTP Fuel tank pressure sensor
Hope this helps will post CL-s Cluster wiring to civic a bit later after i work more tweaks out. Enjoy
Old 12-07-2011, 12:48 AM   #3
FerioEk247
the nerd/geek
FerioEk247's Avatar
Automatic ECU schematics
Manual ECU schematics
also here is a video of it running
My J32a2 civic hatch Video, click image to watch
Last edited by FerioEk247; 12-09-2011 at 03:15 AM. Reason: ecu AT and MT schematics added
Old 12-07-2011, 01:35 AM   #4
mymmeryloss
RHD is where its at
mymmeryloss's Avatar
I know nothing of the j swaps except i think theyre cool. I have also done no research on them, but this looks like a great writeup!
Good job!
***** Turbo Rotary Mazda Minitruck Build*****
Originally Posted by civhatch92 View Post
I love the custom aspect of this build.. totally genius and still super clean!!
mymmeryloss is offline   Reply With Quote
Old 12-07-2011, 02:49 AM   #5
FerioEk247
the nerd/geek
FerioEk247's Avatar
Good job!
thanks, i just recently post my build thread here My EK/Ej Civic HB rebuild to V6 powered 56k beware
went over the whole shbang, from gsr to v6. As for the lack of V6 swap info, i have more indepth info in my thread. as for swapping the V6 in, it really easy to do, and cheaper then K swaps. well from what i gather..
Old 12-07-2011, 04:13 AM   #6
Raabe
Hell yea I suck toes!
Raabe's Avatar
...think i may have found my next project...
Raabe is offline   Reply With Quote
Old 12-07-2011, 05:28 AM   #7
FerioEk247
the nerd/geek
FerioEk247's Avatar
sweet! what car were you thinking of doing the swap in? have you seen a V6 engine swapped in a S2000?
3.2 type S
3.2
j37 3.7l V6 i-Vtec
Old 12-07-2011, 11:41 AM   #8
mymmeryloss
RHD is where its at
Where u at in Colorado?
Old 12-07-2011, 11:56 AM   #9
rey_boricua
2000 EM1 B16A2T
rey_boricua's Avatar
great work this swap is becoming more and more tempting for my next project
RIP David Mercado 1971-2009; You will be missed
2013 Honda Accord V6 Touring
2007 Honda Pilot
2000 Honda Civic SI
rey_boricua is offline   Reply With Quote
Old 12-07-2011, 11:59 AM   #10
FerioEk247
the nerd/geek
FerioEk247's Avatar
im in Thornton
Old 12-07-2011, 03:08 PM   #11
obracer12
obracer12's Avatar
My next project will officially be a J.
***Image removed do to corrupt file. Please relink***
Originally Posted by JerseyKid View Post
my spark is being a guido and blowing out.
Originally Posted by White Boy View Post
Most of the time, sooner or later, most get a soft spot for a civic's.
South NJ club start up PM ask Q's
obracer12 is offline   Reply With Quote
Old 12-08-2011, 03:49 AM   #12
FerioEk247
the nerd/geek
FerioEk247's Avatar
sweet, which one are you going to do? j32a2? j35a? j30a?
Old 04-11-2012, 03:20 AM   #13
FerioEk247
the nerd/geek
FerioEk247's Avatar
update video of car current running stats
http://youtu.be/DsBoaYEwZuQ
Old 04-11-2012, 03:51 AM   #14
FerioEk247
the nerd/geek
FerioEk247's Avatar
Default update pictures
Old 06-07-2012, 03:22 AM   #15
Laziz
Laziz's Avatar
Guys, check it out! This is EK with j32 and a tranny from Celica! This is just mad! AND IT'S RWD CIVIC!!!
The whole article is here
Those guys re-welded almost the whole car!
Laziz is offline   Reply With Quote
want to swap a j32a2 or j35a4 eg1_coupe Engine Tech / Drivetrain 1 05-14-2013 12:55 AM
J32a2 swap to 99 civic 5 speed stock Ryan campbell Engine Tech / Drivetrain 6 04-26-2012 12:44 AM
J32a2 LSD 6spd MT FerioEk247 Automotive Related Video Gallery 1 12-07-2011 03:19 PM
FS: Wisconsin D16z6, D16y8, 90-93 Integra, 94-01 Integra, 92-95 Civic kuchtaboy Parts for Sale 15 04-11-2009 07:38 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
