i have a 2001 Honda Civic EX Coupe - alternator is not charging. I've replaced the alternator with a new one and checked the fuses under hood. any recommendations?
| Attention Honda Civic Visitor: Remove this block by logging in above or registering. | |||
Welcome to ClubCivic.com, a forum dedicated to the Honda Civic, including all generations. In order to post on this forum you will have to register. Registration is free and will intitle you to other site features including access to post your Honda Civic in the member's garage, join in raffles for performance parts, etc.
| 7th Generation Honda Civic (2001-2005) 2001, 2002, 2003, 2004, 2005 honda civic coupe, sedan, hatchback si |
| Please SEARCH Before Posting a New Thread. -> | |
| Ready to Post a New Thread/Question? -> | ![]() |
Thread Tools |
#1 |
#2 |
What do you mean the alternator is not charging? Let's go through a check list.
Does your car start? If so, start your car and keep it running. Disconnect the positive lead to the battery (you will not get shocked, just don't touch the negative lead), and let the car continue to run. If after several minutes the car is still running, the alternator should be fine. If the car dies, then the alternator is bad. Define in detail what exactly is going on with your car. |
#3 |
Frame Bangin
^dont do this. battery if a buffer in your electrical system. this could cause much worse problems
My Slow Build Thread "Coupe Life" Member #2 I dont always drive, but When I do, I Prefer to drive Low *Stay Classy My Friends* |
#4 | |
out on bail
Your alternator charges the battery, but if you're certain that your battery is fine then simply go to a local parts store such as AutoZone, Advanced, O'reily's, etc, and have them check the alternator. Most do it for free.
#5 |
I have an 05 civic. I just replaced the alternator and it does not charge. The battery is at 12V while the engine is running I checked the Volts at the post on the alternator and it is 12V. Any ideas why both old and new alternator don't charge but pass test at auto parts store?
#6 | |
| Bookmarks |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question on alternator charging voltage. | lethal6 | Engine Tech / Drivetrain | 7 | 05-10-2011 02:38 AM |
| New alternator not charging | loudferio13 | Tech Archive (No Posting) | 69 | 10-23-2009 11:51 PM |
| charging system? | zdiver07 | Tech Archive (No Posting) | 3 | 07-19-2007 01:37 AM |
| Charging problem | redstar98ex | Engine Tech / Drivetrain | 7 | 05-12-2005 08:00 AM |
| charging a cap | 99civic/si | Interior / Audio / Electronics | 10 | 04-10-2005 01:27 AM |
| Thread Tools | |
