Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 5th Generation Honda Civic (1992-1995)
5th Generation Honda Civic (1992-1995) 1992, 1993, 1994, 1995 honda civic hatchback, coupe, sedan, hatchback si
Fixed rough idle and cold start issue!
Responding Members:
User Tag List
Old 01-30-2012, 03:01 AM   #1
Vx2ko
Default Fixed rough idle and cold start issue!
My 95 Civic EX has been having trouble on a cold start. When I would first start it in the morning, it idle really rough. and if I threw it in drive, it would die. unless I let it warm up, it would run right. So I checked the timing and it turns out, the previous owner timed it wrong. They timed it using the TDC mark on the cam pulley. So I advanced the dizzy all the way an now it runs like a champ and no cold start rough idle issue. I am going to take off the timing belt and put it on the right way soon. But just for those of you having idle problems on a cold start, check your timing first.
Vx2ko is offline   Reply With Quote
Old 01-30-2012, 01:08 PM   #2
JohnS.
BANGARANG
JohnS.'s Avatar
That's what I was hoping to read lol.
Good to see you got it figured out!
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline   Reply With Quote
Old 01-30-2012, 03:08 PM   #3
Vx2ko
Thanks man. All my problems pointed to something dealing with idling when it was all about my timing. Hopefully this will help someone out.
I am here: http://maps.google.com/maps?ll=29.541870,-98.309074
Old 05-18-2012, 08:39 PM   #4
DavidR
I'm having rough idle issues that seem to have come about after changing my drive belts, which is probably a coincedence. Don't have a check engine light for anything but a P0420 that I've been driving around with since I bought the car 3-4 months ago. I've already bled the cooling system but no change. I then went to testing the ECT sensor below the distributor with a multimeter and according to the haynes manual the resistance doesn't match up with the chart in the book. At 190 degrees it was showing resistance of ,2 when the book shows that around that temp it should read somewhere between .5 and .4. I don't have a CEL for the temp sensor so I don't know if it is really bad plus I don't trust this haynes manual when it comes to specs of sensors as I have been steered the wrong way when I replaced my temp gauge switch to find out it was working properly.
2000 Civic SI
144k
DavidR is offline   Reply With Quote
Annoying cold rough start everytime I don't drive for like, 3-4 hours. Dnguyen92 Engine Tech / Drivetrain 5 11-06-2011 07:17 PM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 3 05-20-2011 02:02 AM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 1 05-19-2011 07:25 PM
Cold start Idle problem slowhatch Engine Tech / Drivetrain 9 02-13-2007 12:51 AM
Wierd Cold Start Idle? Help! Mr.Luder Engine Tech / Drivetrain 8 12-10-2005 05:08 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
