Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
Rough idle once warm
Responding Members:
User Tag List
Old 03-13-2012, 09:15 PM   #1
dryeager
Default Rough idle once warm
I started having this issue recently so I thought maybe I had a shot ring so I did a DRY compression test:
#1: 120
#2: 110
#3: 120
#4: 120
They are low but I am not burning oil nor does it smoke. No CELs either. Just a rough/missing type idle ONLY after the car is warm. Checked the plugs, they are all in good condition. OHMed out the wires and they are all within spec.
So any thoughts or clues?
dryeager is offline   Reply With Quote
Old 03-13-2012, 09:59 PM   #2
Car? Engine?
Cap and rotor?
CEL work?
RonJ is offline   Reply With Quote
Old 03-13-2012, 10:13 PM   #3
itsmycookie
#1 asshole
itsmycookie's Avatar
plug in a diagnostic tool if u can.
it sounds like the Idle air control valve to me. u can clean it out just to make sure that isnt it though.
itsmycookie is offline   Reply With Quote
Old 03-13-2012, 10:33 PM   #4
dryeager
1998 Honda Civic - D16Y7
Cap and rotor - inspected and fine.
No Cels. I was going to take a look at that this weekend. I will report back with images hopefully.
Old 03-13-2012, 10:36 PM   #5
itsmycookie
#1 asshole
ima bet on IAVC. probably is full of gunk.
Old 03-13-2012, 10:43 PM   #6
codeman76
This^ Also check your pcv valve to make sure its not clogged and working properly.
codeman76 is offline   Reply With Quote
Old 03-13-2012, 10:43 PM   #7
Does the CEL work or are you saying you checked for codes with a code reader?
Describe what you mean by rough idle. Fluctuating high and low? Just low? High and unsteady?
Did you do any work on the engine recently?
Old 03-14-2012, 08:53 PM   #8
dryeager
Took the TB off. The IAVC had a little carbon in it but nothing major. Cleaned it and the TB up and put them back on. I have yet to drive the car so I am not sure if that was the issue but judging from it not being clogged or plugged, I am betting that wasnt it.
I didnt plug a code reader into the car since when I reset the ECU to do the compression test, the codes were erased. I am about to run up to Autozone so I will have them do that and report back.
Only work I've done on the car recently was I replaced the valve cover gasket as I thought it was leaking but it ended up being cam holder #5 being broken on the tab that the dizzy connects to.
The idle is rough but it really feels to me that it is missing. Meaning 3 out of 4 cylinders fired turning a revolution but it isnt consistent or steady - random.
Thank you again for all of your help! I hope we can solve this.
Old 03-16-2012, 10:51 AM   #9
dryeager
*Update*
After cleaning the IACV the idle is a little higher and doesn't miss as much while its idling while warm. Again, its only missing while warm. I am starting to think this has to be electrical but I just cant narrow down what to check next. One thing that has changed is the miss is random at idle and also under 2500 rpm. Boggled.
I still havent had the codes read but I will as soon as I get a little extra time.
Old 03-19-2012, 05:58 PM   #10
dryeager
Replaced cap and rotor thanks to O`Reilly's lifetime warranty on those two parts. Same issue.
Old 03-22-2012, 08:03 PM   #11
dryeager
Update!!
I found a brand new set of OEM Honda wires in the basement and threw them on the my car. Low and behold, miss is gone! I still can not believe it. Will report back if I find anything else!
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 3 05-20-2011 02:02 AM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 1 05-19-2011 07:25 PM
90 civic rough idle then smoke after warm up bludworth06 Engine Tech / Drivetrain 0 09-22-2010 12:44 AM
rough idle --> brake= not rough andre4444 Tech Archive (No Posting) 1 05-31-2007 08:32 PM
Weird idle after warm up loccusst Engine Tech / Drivetrain 2 07-10-2004 09:11 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
