Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
1998 Ex 2dr Rough Idle at Low RPMs
Responding Members:
User Tag List
Old 03-16-2012, 07:38 PM   #1
JSpiers
Default 1998 Ex 2dr Rough Idle at Low RPMs
1998 Honda Civic Ex two door. Car has 185,000 miles, has been very reliable car. Have done basic maintenance over the years. CEL has been on for last few years but hasn't seemed too impact function. Yesterday, car began to idle very rough. At higher speeds was hard to notice but didn't seem to have as much power. Figured there was a bad plug or wire. Remove one of the wires as car was running to see if problem got better or worse. Saw white spark, but must have pulled it out too far as the car died. Tried to crank back up, no dice. Tried to read CEL codes but couldn't without cranking the car. Pulled a wire and tried to crank to watch spark and didn't see any spark. Pulled distributor, tested ignition coil and ICM. Ohms were low on ignition coil, parts store said ICM showed bad at low RPMS but good at high RPMs, but to replace. Bought new distributor, installed and car cranked back up. Still have rough idle problem though at low RPMs. Sounds pretty good when I idle it up. Checked CEL codes and am getting 41. Reset CEL and get code 41, Primary Oxygen Sensor heater. Should I replace it? Would it cause rough idle at low RPMs? Thanks in advance for the advice.
3/17/12 Update
Pulled the IACV this morning and thoroughly cleaned it. Seems to run a little smoother, but still rough idle. On initial start up with motor cold, idle is very smooth (2000 RPMs). Idle is still smooth at 1500rpms, but once it drops below 1500 (between 1500 and 1000) it begins to idle rough. Typically I only notice the rough idle as the idle is in its down stroke. Once it begins to idle back up the idle goes back smooth. As the car warms the idle typically lands in the 600-1200 rpm range (average 700/800).
Note, while driving engine runs rough with increased throttle too. Major loss of acceleration.
CEL shows code 41, 71, 72, and 23. Today is the first day I've gotten anything other than 41.
Primary oxygen sensor heater
Random misfire cylinder 1
Random misfire cylinder 2
Knock sensor
JSpiers is offline   Reply With Quote
Old 03-18-2012, 11:54 PM   #2
JSpiers
Bump. Anybody have any advice for my situation?
Here is my current plan of attack and reasoning:
1. Since I wasn't getting any random misfire or knock sensor CEL codes before the distributor swap, I'm going to check timing to ensure timing is right. I read in my Haynes manual that the distributor can't be installed 180 degrees off. Based on my research for some basic checks, the wire post on the distributor associated with cylinder 1 is the bottom left hand post (viewing from the passenger side of the engine compartment). Moving clockwise around the distributor, it should be 1, 3, 4, 2. Looking at the engine from the bumper, these should correlate at the valve cover with 4, 3, 2, 1 (viewing left to right).
I've never checked the timing, so here are the steps I was planning on taking. Please correct me if I'm wrong.
A. Hook up red & black clips to battery. Clamp pick up lead to number one cylinder wire
B. Warm up engine, jump out CEL with wire
C. Line up pointer with white mark? on fly wheel by twisting distributor housing after loosening 3 bolts.
D. Lock down bolts
E. Recheck timing
2. Tap number one cylinder plug hole and replace all spark plugs. I pulled 3 of the 4 plugs and they looked fine. Had issues on the number one cylinder plug. Used penetrating oil and let it soak over night. Finally loosened up. Appears to have a some galling on first 2 threads. Appears to be some corrosion on the base of the threaded portion of the plug. Could this be due to the issue with the threads?Click for Pictures. Have a tap that I will slowly run in and out of the hole, wipe off any small pieces of metal. Repeat until run tap through entire hole. Will use a lot of oil to keep the shavings on the threads of the tap.
Is it possible to remove the spark plug tube easily before I clean up the threads?
Old 03-19-2012, 01:13 AM   #3
Knock sensor
First off, never ignore CEL codes. You'll pay in the end.
If you reset the ECU, do all 4 codes repeat?
When was the last time you replaced the plug wires and plugs?
Have you ever replaced the fuel filter?
What's the resistance of the primary O2 sensor heater element? Is 7.5A dash fuse 15 blown?
RonJ is offline   Reply With Quote
Old 03-19-2012, 02:34 AM   #4
Ek_Rider
Ek_Rider's Avatar
didi you check and make sure everything was top dead center your timing cuz i know that if you try and crank your car to much you can jump timing i know cuz i did before and car had a real rough idol
Ek_Rider is offline   Reply With Quote
Old 03-19-2012, 08:14 PM   #5
JSpiers
Ron, thanks for the additional checks.
Plugs and wires replaced probably 4 years ago.
Replaced fuel filter probably 6 years ago.
Is the 02 sensor heater element the same as the 02 sensor sticking out of the exhaust manifold? What is the easiest way to check it if so? I think there are 3 wires coming out of it with a shroud around them.
I checked all the fuses in the dash and under the hood with the continuity tester on my ohm meter (didn't pull, but used probes on face of fuse). They all checked out.
However, there is one fuse that is hard wired to the battery that I checked and it was blown, replaced with a new one and it blew again upon cranking. Appears to be factory, but makes me think of a hot that could've been ran to the trunk for an amp. Previous owner traded in with 45K miles when the wife bought from the dealer. Runs directly from battery through firewall, but has in line fuse right after connection to battery. Has plastic corrugated shroud around it. Looks very factory.
Will double check fuses, reset CEL and recapture codes, chase threads on number cylinder, adjust timing and report back.
Old 03-19-2012, 08:17 PM   #6
JSpiers
EK Rider, do you mean I should physically check TDC or just ensure timing is set to TDC via light? Forgive me if I don't make any sense. Much of this is very new to me.
Old 03-20-2012, 07:04 AM   #7
JSpiers
Update
Chased the spark plug threads and replaced the fouled plug. Adjusted timing (it was off quite a bit). Pulled fuse to reset CEL, warmed car up, and got new CEL codes. Here is what I got:
Code 71 Random misfire cylinder 1
Code 72 Random misfire cylinder 2
Code 73 Random misfire cylinder 3
Code 22 VTEC Pressure Sensor (could have misread code before or this time, before I read 23 Knock Sensor)
Code 41 Primary Oxygen Sensor Heater
Observations: When I started the engine cold, I really couldnt tell that there was anything wrong with the engine. Even after the engine initially warmed up I could only hear a faint miss when I listened to the muffler. As the car stayed at operating temperature for longer, it began to get worse. The frequency of the misses or roughness got progressively worse. Still major loss of power when trying to accelerate.
What next? Will verify CEL code 22 first.
Old 03-20-2012, 10:41 AM   #8
1) Figure out whether the code is 22 or 23.
2) Focus first on solving misfire codes 71-73. Remove the coil and ICM from the distributor. Resistance test the coil and have an auto parts store test the ICM.
3) Code 41: Unplug the primary O2 sensor (closest to header) and then measure the resistance across the two black wires in the plug on the sensor side.
Old 03-20-2012, 10:56 AM   #9
epic_civic
epic_civic's Avatar
Ronj, wasn't there an issue where the wiring under the throttle body could throw the code for 41 and blow your fuse #15?
epic_civic is offline   Reply With Quote
Old 03-20-2012, 10:58 AM   #10
Yes, click the Fuse 15 TSB link in my signature. Is your fuse 15 blown?
Old 03-20-2012, 11:55 PM   #11
JSpiers
Here are the results:
1) It was code 23 - knock sensor. I reset and continued to get 23, until the last check when it disappeared.
2) Pulled the coil and ICM from the brand new distributor I put in last week. The coil resistances were from A to B = 0.5-0.6 ohms, from A to Secondary = 15.8 kilo ohms. Had the ICM tested and it checked out good.
3) Unplugged the 02 sensor and tested resistance across the 2 posts in the connector that correspond to the black wires on the 02 sensor side. Couldn't get a reading. Tried between other wires and couldn't get any readings either. This was when the car was off, should I have done this while it was running?
In addition, I checked the plug wires for resistance. I got the following:
Cylinder 1 = 8.5 kilo ohms
Cylinder 2 = 7.8 kilo ohms
Cylinder 3 = 6.5 kilo ohms
Cylinder 4 = 6.0 kilo ohms
Also checked fuse 15 under the dash again. It was good.
Observations:
The longer the car runs the worse it runs rough. While not in gear it seems to run smoother at higher RPM's than lower. When in gear, it runs terrible at high and low rpms. Major loss of power while in gear.
I initially pulled the codes when the car was cold today. Only got 41. As it heated up, I pulled them again, got 41 and 23. When it got to full temp and let it run for a bit, began to run even rougher, put it in gear etc. I got 41, 71, 72, and 73. Code 23 disappeared the last time I pulled them.
While sitting in the car, noticed different smell. Exhaust doesn't smell normal, maybe richer?
Last observation. Hope this is my problem, not a result of another issue. The last time I pulled the codes, the idle was so rough the car died. This is the first time it has died on its own while running. I cranked it again, it barely started, still very rough idle. Decided to turn it off, noticed smoke from under the hood. I do have some oil leaks so I wasn't surprised given the car isn't being driven daily noq. Did some snooping around saw that smoke was mainly coming up from around the firewall. Got under the car, notice that the catalytic converter was glowing red. Could this have been my problem all along? Or is this a result of the car running rough? Might explain why it runs rougher the longer the car is on.
Ideas?
Old 03-21-2012, 12:09 AM   #12
The engine misfires result in unburnt fuel in the exhaust that ends up burning in the cat. That's the reason the cat was glowing red. The substrate inside the cat is likely melted = cat is toast.
Is the new distributor OEM or aftermarket?
No resistance across the two black wires of the primary O2 sensor indicates that it's bad and needs to be replaced. The non-functioning primary O2 sensor is also contributing to the engine running rich. In the meantime, test whether unplugging the primary O2 sensor eliminates the misfiring and misfire codes. It probably won't help, but it's worth trying.
The knock sensor (blue in picture below) is attached to the rear of the block. It has one Red/Blu wire. Check the wire and sensor for damage.
Old 03-21-2012, 12:45 AM   #13
The TEC coil A-B reading should be 0.63-0.77 Ohms. Is your A-B measurement corrected by subtracting the internal resistance of your multimeter?
Old 03-21-2012, 12:47 AM   #14
This is likely due to a combination of engine misfiring and a clogged cat.
Old 03-21-2012, 01:52 AM   #15
JSpiers
Aftermarket distributor. Couldn't locate an OEM quickly enough. Original was TEC...coil resistance was low on it and ICM failed test. How do I determine the internal resistance of my multimeter? What is the coil resistance supposed to be for an aftermarket distributor?
I will go ahead and test unplugging the 02 sensor to see if that helps and then replace it. The resistance test was completed with the car not running. Was that correct?
Will inspect knock sensor for any obvious issues and report back.
Will the cat need to be replaced before I do any further testing to accurately troubleshoot? Or, will the bad cat just impact emissions testing?
Rough Idle, low RPM Civic_Cinderela Engine Tech / Drivetrain 1 10-05-2011 12:12 AM
I'm having the same Low rough Idle with A/C on. But mine is in a 1996 Civic EX The_Rookie 6th Generation Honda Civic (1996-2000) 7 06-03-2010 11:24 AM
96 LX: Intermittent low power, backfiring, and rough idle Mny300zx Tech Archive (No Posting) 4 05-30-2010 05:40 PM
95 civic lx.. somewhat rough/low idle & backfiring PhatAzzCracka Tech Archive (No Posting) 5 04-07-2010 06:45 PM
Nasty evil rattle at idle / low RPMs Alpha.kx Engine Tech / Drivetrain 6 05-25-2009 11:48 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
