Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
SRS light stays on???
Responding Members:
User Tag List
Old 05-16-2012, 10:51 PM   #1
jimmy_rose92
Question SRS light stays on???
why does my SRS light stay on, and what does it mean??
jimmy_rose92 is offline   Reply With Quote
Old 05-17-2012, 01:41 AM   #2
6thGeneration
"The purpose of the SRS light is to alert you to a potential problem with your Supplemental Restraint System. When you turn the ignition ON (II), this indicator will light up briefly then go out. This tells you that the system is working properly However, if the light comes on at any other time, you should have the system checked by your dealer."
"If you see any of these indications,
your airbags may not deploy when
you need them. See your Honda
dealer as soon as possible."
This is a direect quote from the owners manual. If the light stays on it technically means your air bad system is not functioning properly.
6thGeneration is offline   Reply With Quote
Old 05-17-2012, 09:58 AM   #3
taluzer45
4 Banger Deluxe
taluzer45's Avatar
X2 on this
02' Civic DX-Sold, 98' SI(EX)-Sold, 96' CX Hatch-Sold Currently rideless...
"When Congress passes new emission standards, we hire 50 more engineers and GM hires 50 more lawyers." -Soichiro Honda
"Sedan Life" Member #7 " D-Squad" Member #10
taluzer45 is offline   Reply With Quote
Old 05-18-2012, 07:02 PM   #4
jimmy_rose92
okay does the SRS have anything to do with the seatbelts locking???
Old 05-20-2012, 05:37 PM   #5
goatastic
Not that I an aware of. It should only be giving you info about the air bags.
goatastic is offline   Reply With Quote
Old 05-21-2012, 09:17 AM   #6
motozachl
motozachl's Avatar
I am just getting knowledge of these cars (civics) but usually there's a separate computer module that can be unplugged to rid of the SRS system. Is this applicable?
motozachl is offline   Reply With Quote
Old 05-22-2012, 03:37 PM   #7
jimmy_rose92
alright well i got no clue either thats why im askin lol
Old 05-22-2012, 04:40 PM   #8
Trekk
Trekk's Avatar
If you want to be ghetto about it just take the cluster out and remove the bulb... I've seen some morons pull the cluster a part and put electrical tap over the light..
If you want to have a working system take it to a shop or throw parts at it.
ASE master
Nissan master
Anyone can be a mechanic, few can be a technician.
Trekk is offline   Reply With Quote
Old 05-23-2012, 12:51 AM   #9
Omg Neub
My car has the same problem. But I always figured it was because i have an rsx steering wheeling on my civic.
(Previous owner did that)
Omg Neub is offline   Reply With Quote
Old 05-23-2012, 01:06 AM   #10
6thGeneration
Yeah if he didny hook up the airbag components correctly or at all then the light will definetely be on. If it's completely stock and its on then something is wrong with the airbag unit and electronics. Someone might have messed with it or it's faulty. Either way you should have it looked at or get under there yourself and establish the problem because currently your airbag will most likely not deploy in an accident.
Old 05-23-2012, 01:07 AM   #11
emerican
emerican's Avatar
take it to the dealer or a mechanic shop.
Y8 AEM sri, Yonaka catback exhaust Megan 4-2-1 header, Megan racing high flow cat, front and rear upper strut tower bars, front and rear lower tie bars, ngk plugs and wires, summit racing distributor cap and rotor button, Accel super coil, AEM ps pulley, c-pillar bar, BWR LCA's, BWR subframe brace,Auto meter A/F and volt gauge, slim fan, maxbore tbody
http://www.clubcivic.com/board/showthread.php?t=200155
Originally Posted by CHILD View Post
painted carbon fiber is like wearing a zipped up jacket over a purple label shirt
emerican is offline   Reply With Quote
Old 05-23-2012, 03:37 PM   #12
jimmy_rose92
okay well im not gune rig my car lol rather spend the money and get it fixed properly lol
Old 06-13-2012, 02:45 PM   #13
greenEJ6
greenEJ6's Avatar
Under the drivers seat there is a connector for the seat belt buckle I would start there
greenEJ6 is offline   Reply With Quote
Old 06-13-2012, 04:23 PM   #14
chromal
chromal's Avatar
If something causes an SRS code, it may not self-reset even if the problem was transient and the initial cause has passed. There's a simple method to reset the SRS module (the 'two paperclip on SRS diag port' method). If the warning light doesn't return after that, you're good. If it does, something is still not right. It may be that if the SRS warning is lt solid, it's just that- a warning that a code posted. If the SRS light is flashing, the airbags will not deploy in an accident. Do some research, you'll find your answers.
chromal is offline   Reply With Quote
HELP! Battery light stays on. Matt316 Engine Tech / Drivetrain 2 10-24-2011 08:23 PM
reverse light stays on guwakjai010 Interior / Audio / Electronics 2 03-21-2007 01:51 AM
empty washer light stays on. pmartell12 Tech Archive (No Posting) 22 04-30-2006 08:55 AM
battery check light stays on hahaha125 Interior / Audio / Electronics 0 04-12-2004 04:32 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
