Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
Suspension Noise: What Needs Replacing?
Responding Members:
User Tag List
Old 06-29-2012, 02:01 PM   #1
HeX
Grammar Police
HeX's Avatar
Default Suspension Noise: What Needs Replacing?
For some time, my suspension makes noise when parked when I jump inside roughly or when I shake the car in different angles. Im pretty certain its the rubber ring at the upper strut mount because I cant imagine how the mount itself would go bad. Ive tried to locate the part online, but the descriptions dont seem clear on whether its the mount or the rubber ring or both. Ive come up with the part numbers listed below. Someone please clarify this for me or suggest exactly what the part I need is called.
KYB SM5538 (front)
KYB SM5516 (rear)
FYI, I have Tein S.Tech Springs & Koni STR.T Shocks.
HeX is offline   Reply With Quote
Old 06-29-2012, 03:22 PM   #2
emerican
emerican's Avatar
why are you certain thats what it is?
what all have you checked?
Y8 AEM sri, Yonaka catback exhaust Megan 4-2-1 header, Megan racing high flow cat, front and rear upper strut tower bars, front and rear lower tie bars, ngk plugs and wires, summit racing distributor cap and rotor button, Accel super coil, AEM ps pulley, c-pillar bar, BWR LCA's, BWR subframe brace,Auto meter A/F and volt gauge, slim fan, maxbore tbody
http://www.clubcivic.com/board/showthread.php?t=200155
Originally Posted by CHILD View Post
painted carbon fiber is like wearing a zipped up jacket over a purple label shirt
emerican is offline   Reply With Quote
Old 06-29-2012, 03:41 PM   #3
HeX
Grammar Police
HeX's Avatar
I say certain because I hear it from that area of the suspension. It doesnt sound like its from below that. I also suspect that because I noticed the car doesnt sit evenly from driver to passenger side so I assume its also in part from those "seats" being worn out.
On a side note, when I take hard turns, one side sounds like it rubs inside, but Im beginning to think its the mud guards rubbing on the pavement. That might be part of the audible issue at least. So ill be removing them this weekend and testing it out.
Old 06-30-2012, 01:26 AM   #4
civexspeedy
civexspeedy's Avatar
If anything I'd say those rubber bushings for the springs would be the last item to make the noise.
The noise could be the top mount bushings where the shaft of the shock goes though. Or it could be the shock itself that has internal damage and is causing noise. It could also be the spring itself. It could be something slightly different like a bad inner tie rod which I've personally heard squeaking/creaking noises come from. Could even be as stupid as the brake shield rubbing the rotor..
Just about all Civics I've seen on lowering springs sit uneven from left to right side. This is due to weight distribution of the car. Don't base it off of that.
Karcepts - SSC Tint & Graphics
'07/'08/'09/'11/'13 Autocrossers Incorporated ST Champion. '08/'09/'10/'11/'12/'13 Washington D.C. Region ST Champion. '08/'11 Capital Driving Club Small Bore Series Champion. '11 CDC Index Champion. '10/'12/'13 NCCBMWCCA X4 Champion.
civexspeedy is offline   Reply With Quote
Old 07-02-2012, 11:36 AM   #5
HeX
Grammar Police
HeX's Avatar
The top mount bushing is what I referred to. I couldnt recall its proper name. Im really leaning towards that being the culprit. Can anyone tell me roughly how long before those should usually be replaced?
Also, would worn tie rods make noise even when the car is parked and you rock it?
The shocks& springs are less than a year old and just fine, and I know the sound bad shocks make so its not that. My camber is also perfectly aligned, so I dont see an issue there. No warped brake shield either. Thats a different sound.
faulty srs and replacing front suspension ball joints xeno71 Tech Archive (No Posting) 2 07-31-2010 09:50 PM
Help replacing suspension cadieux_j Wheels / Tires / Brakes / Suspension 4 03-22-2009 09:13 PM
Replacing rear suspension queastion Drive4Fun Wheels / Tires / Brakes / Suspension 14 12-10-2006 12:45 AM
suspension noise!!! CivicFreak26 Tech Archive (No Posting) 5 01-18-2006 11:25 PM
Clanking noise after replacing header mizzstardust Tech Archive (No Posting) 11 04-10-2005 10:07 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
