Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 7th Generation Honda Civic (2001-2005)
7th Generation Honda Civic (2001-2005) 2001, 2002, 2003, 2004, 2005 honda civic coupe, sedan, hatchback si
2003 Civic LX A/C clutch,Condenser Fan, Rad Fan not working with A/C button ON
Responding Members:
User Tag List
Old 09-11-2012, 11:56 PM   #1
zestey
Default 2003 Civic LX A/C clutch,Condenser Fan, Rad Fan not working with A/C button ON
Followed Service Manual procedure and jumper Terminal 9 of 12p connector on underdash fuse box to ground and all come on regardless of A/C switch selection. Manual directs me to find the open in the wire from Pressure switch to terminal 9. Ran a temporary wire from switch to fusebox in parallel and does not work. jumper original switch wire near pressure switch to ground and works so wire must be OK.
Does this indicate a failed Multiplex unit? I have not found a schematic to show all connections.
Made a jumper for the "Special Tool" and in Mode 2, no dome light indicators when testing inputs. Am I to assume I need to replace the Multiplex(Fuse PAnel)??
Is there a problem rewiring manually around the multiplex unit? Is this routinely done?
zestey is offline   Reply With Quote
Old 10-27-2012, 06:49 PM   #2
sr6000
still a D
how is the freon charge, because if it is low it wouldn't let the system come on
Coupe Life#19
2005 Honda Civic EX SE, 1985 Chevrolet Monte Carlo, 1978 Kawasaki KZ1000, 1996 Dodge 2500 Cummins!, 1997 Dodge Neon ($150 Three years ago)
sr6000 is offline   Reply With Quote
A/C condenser fan problem!! ek_all_day Engine Tech / Drivetrain 3 09-23-2010 01:48 AM
A/C condenser fan pete m Tech Archive (No Posting) 3 04-13-2010 06:16 PM
a/c condenser fan trouble tmarsh Tech Archive (No Posting) 6 09-17-2009 01:51 PM
Rad Fan not working Hyperblast Engine Tech / Drivetrain 2 06-30-2009 01:30 PM
99 ex - A/C Condenser Fan clicking on and off??? thodi Tech Archive (No Posting) 0 08-17-2006 01:38 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
