Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
'98 Civic EX Firing Order?
Responding Members:
User Tag List
Old 10-03-2012, 04:55 PM   #1
A2C
Default '98 Civic EX Firing Order?
I tried looking for the order the cylinders fire in, but I've found it in a few places and they were all different.
I've got a 1998 Honda Civic EX
Engine: D16Y8
I took the spark plugs wires off since I replaced the distributor and cap together, but didn't check which plugs went where. I know which wires are for 1, 2, 3, 4, but I'm not sure where they connect on the distributor cap.
Anyone here know?
Also, since I found a few different orders all ready, can you let me know how you know that's the right order?
Thanks
A2C is offline   Reply With Quote
Old 10-03-2012, 05:05 PM   #2
203CT
Slow But Not Low
203CT's Avatar
If you are standing on the passenger side of the car facing the dizzy the top left terminal is 1. Remember it rotates clockwise so just put the plugs in one by one in a clockwise order following the firing order.
"Coupe Life" Member #1
203CT is offline   Reply With Quote
Old 10-03-2012, 06:16 PM   #3
Failsafe88
gt CasaNova
Failsafe88's Avatar
http://lmgtfy.com/?q=d16y8+firing+order+
Click here for everything google!
JDM- Japanese Domestic Market
if your car is not directly imported from japan you are USDM now stfu you ricer.
Failsafe88 is offline   Reply With Quote
Old 10-03-2012, 06:56 PM   #4
A2C
Originally Posted by 203CT View Post
1-3-4-2
Thanks. I've plugged them in in that order.
Originally Posted by Failsafe88 View Post
Google is where I found the three different firing orders for it.
I saw the link to the other forum here. That was for a different engine and although someone else said it worked for them in that order in another, I'd rather just see if someone knew for sure it was the same for this situation.
I've got the new distributor on, and the spark plugs all set in the 1-3-4-2 order, but it still wont start.
Any one have any ideas? It sounds like it wants to turn over right when I turn the key, but then stops.
I'm sure it's something with the new distributor being on, since before replacing the distributor the car would start, but since oil was getting into the cap and all that it was stall after a bit.
Old 10-03-2012, 07:49 PM   #5
A2C
Also, I didn't check this time, but I'm sure it has spark as that was checked when I still had the old distributor on.
firing order aubs Engine Tech / Drivetrain 6 09-18-2011 06:00 PM
D16Y8 Firing Order? 98civic_boii Tech Archive (No Posting) 4 03-01-2009 02:03 PM
FIRING ORDER Diagram 92civicboost Tech Archive (No Posting) 1 02-18-2007 03:55 PM
does anyone know the spark plug firing order for a 94 civic username Tech Archive (No Posting) 2 04-23-2006 09:54 AM
D15B8 Firing Order boosted_cd5 Engine Tech / Drivetrain 2 09-16-2005 09:10 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
