Search:
Welcome to ClubCivic
K20 swap info 96 dx coupe
Responding Members:
User Tag List
Old 02-02-2013, 08:32 PM   #1
Chris'
Default K20 swap info 96 dx coupe
Curious on what is needed for the swap. Parts, wiring, mounts, ect.. Any recommendations would be a big help thanks guys
Chris' is offline   Reply With Quote
Old 02-02-2013, 09:12 PM   #2
CHILD
All Day, All JDM
CHILD's Avatar
Engine, transmission, ecu w/immobilizer bypass or kpro/aem ems, wiring harness, conversion harness, axles, swap mounts, shifter mechanism, shifter cables, swap header, modified fuel setup, modified radiator and hoses, b series temp and fan switches.
Id recommend hybrid-racing.com because i basically own everything they offer.
flickr ~MY EKK24A2 BUILD
VIDEO UPDATES: DYNO TUNED 228.5whp
Originally Posted by emerican View Post
there is nothing in the world that can replace a child
^ see what i did there
CHILD is offline   Reply With Quote
Old 02-02-2013, 09:40 PM   #3
Jeffhondadc5
Jeffhondadc5's Avatar
Might be useful to use the eg/dc subframe with the ek as well.
Leaves more room in the bay and much better angles for the axles.
"Coupe Life" Member #3
Jeffhondadc5 is offline   Reply With Quote
Old 02-02-2013, 10:43 PM   #4
Chris'
Any downside to sub Frame swap^^^.
Old 02-02-2013, 10:57 PM   #5
Jeffhondadc5
There's limited room in the bay cause the motor sits so far forward. You can't run a larger intake manifold or larger radiator.
Like I said, the axles as well.. different angles. They don't tend the hold up as well with the ek subframe.
IMO, if you have the money for a k-swap.. you can do the subframe swap too. It's worth it IMHO.
Goodluck
Old 02-03-2013, 01:20 AM   #6
CHILD
All Day, All JDM
CHILD's Avatar
With that subframe mentality you would end up upgrading tons of parts. Although beneficial, its not necessary for a plain swap.
If you do switch subframes, then you need eg/dc lca's, you may need a different U joint for the steering column depending on what subframe you start with and switch to.
Old 02-03-2013, 02:37 AM   #7
Jeffhondadc5
It's not necessary but it''s worth it IMO
Old 02-04-2013, 10:39 AM   #8
Jeffhondadc5
Are you not swapping out your subframe?
Old 02-04-2013, 06:04 PM   #9
CHILD
All Day, All JDM
CHILD's Avatar
I am, but that's just so i can stay low and to cover my future power plans with the k24. The higher torque output along with my performance plans will be hard on the axles with ekk1's. Otherwise I would have been saving a lot of time and money with leaving the stock subframe in place. A plain k20 is just fine with ekk1's. Think about all the years that k's have been around prior to the subframe and mounts upgrade. It never was aproblem, it's just better now....and more expensive.
Old 02-06-2013, 01:39 PM   #10
Jeffhondadc5
Yeah I hear what your saying..
IMO I would still swap it out either way but I know what you mean. Defiantly more cheaper as well.
What axles would you go with though? Keeping the stock ek subframe with ekk1 mounts.
Old 02-06-2013, 07:14 PM   #11
CHILD
All Day, All JDM
CHILD's Avatar
An OEM combo. Base rsx with swapped inners. Stock ones are pretty durable and much cheaper to replace if that's ever needed. Some people are thrifty and use the warranty autozone base rsx axles so they can replace them with no issues
Old 02-06-2013, 08:09 PM   #12
Jeffhondadc5
Hmm autozone warranties they're axles? That's a thought too.
Wouldn't ep3 axles work as well?
Old 02-06-2013, 08:12 PM   #13
CHILD
All Day, All JDM
CHILD's Avatar
Ep3 and base rsx are basically three same, so yes. Price changes between the two sometimes, so it's best to check the local pricing on each. Some places treat the ep3 like a "sports car" and raise prices
Old 02-06-2013, 08:15 PM   #14
Jeffhondadc5
Lol I have noticed that..
Thanks for the useful information though.
98 ex coupe k20 with questions?????? bhawk1987 Show off your 6th Generation Honda Civic (1996-2000) 2 01-15-2011 09:25 AM
b18 or k20 for 99 civic coupe RidnCleanOn17s Engine Tech / Drivetrain 7 10-29-2010 10:52 PM
K20 Engine - Coupe Conversion moleykart Tech Archive (No Posting) 16 09-05-2009 02:34 PM
K20 in a 98 EX coupe anyone know if it has been done? CivicVelox17 Tech Archive (No Posting) 25 12-22-2003 10:55 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
