Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
2000 Honda Civic cranks but wont start!
Responding Members:
User Tag List
Old 03-08-2013, 10:25 AM   #1
swaggyb
Default 2000 Honda Civic cranks but wont start!
Okay
I have a 2000 Honda Civic DX ( 1.6 Liter 4 cylinder engine ) (SOHC)
Two days ago I was driving to work and it died in mid flight.Now all it does is cranks but for the life of it wont start no matter what I try. Not throwing any codes and the check engine light isnt on. I have changed everything I can think of but for nothing can I get it to go. Any ideas would be great.
Changed:
Ignition
ignition coil
Distrubutor Cap and rotor
Spark plugs and wires
Main Relay
Timing belt- which is correct according to specs
Fuel injectors are clean and functioning
Fuel pump is priming
Full tank of gas
All wires are hooked up
I Have plenty of spark and gas Just will not turn over
WHAT AM I MISSING????
swaggyb is offline   Reply With Quote
Old 04-06-2013, 02:12 PM   #2
Is there bright white spark at all 4 spark plugs?
Do the fuel injectors spray fuel when the engine is cranked?
Have you checked whether the timing belt skipped a tooth?
Have you compression tested the cylinders?
RonJ is offline   Reply With Quote
Old 04-09-2013, 04:37 PM   #3
agol
agol's Avatar
sounds like it is either your battery or alternator.
agol is offline   Reply With Quote
Old 04-11-2013, 12:39 AM   #4
colojpn25
colojpn25's Avatar
its probably your alternator
colojpn25 is offline   Reply With Quote
Old 04-11-2013, 01:40 AM   #5
xxBLOOD88SHOTxx
Surge Master
xxBLOOD88SHOTxx's Avatar
Im leaning towards timing or fuel too. What the f*** does the alternator have to do with starting the car? If his battery has enough power to crank over and over then it probably isnt dead.
Positive Intake Manifold Pressure (PIMP)
xxBLOOD88SHOTxx is offline   Reply With Quote
Old 04-11-2013, 03:03 AM   #6
Intertwined
It's onski brah
Intertwined's Avatar
make sure all your grouns have a solid connection. Battery, Tranny, Valve Cover. if any of those have a poor connection or the ground wire itself is bad it can cause the car to not start.
i had a similar issue, replaced the 3 grounds and never had the issue again.
"If you are not remembered, Then you never existed"
Intertwined is offline   Reply With Quote
Old 04-11-2013, 02:28 PM   #7
Trekk
Trekk's Avatar
Shoot some ether into the intake and see of it starts.
ASE master
Nissan master
Anyone can be a mechanic, few can be a technician.
Trekk is offline   Reply With Quote
CRANKS!, but wont start.HELP GEE-Zus 6th Generation Honda Civic (1996-2000) 10 11-21-2012 03:27 PM
2000 Honda Civic LX Cranks but does not start/Stay on HammerHead 6th Generation Honda Civic (1996-2000) 3 06-17-2012 05:22 PM
92 civic 4dr cranks but wont start 92sedancivic Engine Tech / Drivetrain 6 04-15-2011 12:54 AM
92 civic cranks but wont start 92civic hatch Engine Tech / Drivetrain 15 03-21-2011 10:33 PM
car wont start,cranks but no start zoomoutt Tech Archive (No Posting) 7 06-20-2010 05:20 PM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging v3.1.3 (Lite) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 2007 ClubCivic.com
Freelance Web Design
