Search:
Welcome to ClubCivic
my heater doesnt work!!!!
Responding Members:
User Tag List
Old 11-03-2004, 09:41 PM   #1
stolle
stolle's Avatar
Default my heater doesnt work!!!!
does ne one know why my heater wouldnt blow out warm air?
edit: it works it was the mix cable it was on full cold my climate controll knob was broke so i took it out and put the mix on full hot then moved my controls to the glovebox....
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-03-2004, 09:42 PM   #2
J32a2OwnsU
Resident Old Man
Check your anitfreeze levels first. if there isnt enough juice, you wont get heat........!!!
J32a2OwnsU is offline
Old 11-03-2004, 09:46 PM   #3
stolle
stolle's Avatar
i have antifreeze good thermostat my fans dont run all the time my engine warms up quick i just have no heat its just luke warm barely defrosts the windows
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-03-2004, 09:48 PM   #4
J32a2OwnsU
Resident Old Man
Umm, my only other guess would be your water pump starting to go...Check the water pump see if its starting to seep??? I dont know. Heater core shot....Just guessing sorry bro.
Old 11-03-2004, 09:53 PM   #5
stolle
stolle's Avatar
i just replaced the timing belt and water pump, my heater controls are broke i have the valve on the other side of the firewall turned on but, is there somthing else i noticed two cables going to the heater control knob on the back of the climate controls i guess i could always check the heater core...
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-03-2004, 10:01 PM   #6
J32a2OwnsU
Resident Old Man
SOme water pumps are bad out of the parts store.....but i doubt its that....did u bleed the air out of the cooling system?
Old 11-03-2004, 10:02 PM   #7
J32a2OwnsU
Resident Old Man
ANd the fact that your knobs are jacked up probably doesnt help matters much... yeah be sure the valve or whatever u r talking about IS actually turned on and u r getting flow through the system.
Old 11-03-2004, 10:04 PM   #8
stolle
stolle's Avatar
bled the system yes, oem honda water pump better not be bad...
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-03-2004, 10:05 PM   #9
stolle
stolle's Avatar
im getting flow air gets warm but not very...
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-03-2004, 10:06 PM   #10
J32a2OwnsU
Resident Old Man
U got me.........sorry.
Old 11-03-2004, 10:07 PM   #11
stolle
stolle's Avatar
its alright mang thanks for the help...
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-03-2004, 10:28 PM   #12
stolle
stolle's Avatar
no one else has had this problem?
2005 Civic Si
2011 Civic lx-s
stolle is offline
Old 11-04-2004, 01:22 PM   #13
EG_CaSe
ScAre CrOw
EG_CaSe's Avatar
its ur heater motor... if it works but blows out cold air.... dose ne1 know if a 88-91 heater motor would work in a 92-95 hatch??? i dunna my 90 hatch seems 2 get warmer faster.
I'm Back
Honda|Done
ONE SIG IMAGE PER MEMBER.
EG_CaSe is offline
Old 11-04-2004, 01:28 PM   #14
Tom
honda.co.jp
Tom's Avatar
heater motor doesn't control temp, just teh speed the s*** is blown out at, but no, they are not interchangable.
Originally Posted by Destroy View Post
Put some forged internals in it. What the f*** else would you put in, rainbows?
Tom is offline
Old 11-05-2004, 01:14 AM   #15
EG_CaSe
ScAre CrOw
EG_CaSe's Avatar
i always though that it blew out heat.. learn new things everyday i guess
I'm Back
Honda|Done
EG_CaSe is offline
Speedometer doesnt work flacosofly1 Tech Archive (No Posting) 6 05-18-2010 05:26 AM
Heater doesnt work... usdm.ehtu Tech Archive (No Posting) 19 03-06-2008 10:00 PM
AC doesnt work on 1 or 2, only on 3 and 4 supermonkeyball Tech Archive (No Posting) 15 06-15-2007 12:29 AM
Heater doesnt push any air... Drows Interior / Audio / Electronics 13 10-17-2006 02:15 PM
heater doesnt blow! DX_hatch88 Interior / Audio / Electronics 6 01-10-2006 09:48 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
