white smoke from exhaust
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 11-29-2004, 03:47 PM   #1
vejita1283
import mechanic and racer
vejita1283's Avatar
vejita1283
Default white smoke from exhaust
hey guys, i need some help. 1990 plymouth acclaim..v6 LX
white smoke comes out when cold or long idle. long idle makes engine warmer then usual. any help would be nice.
vejita1283 is offline   Reply With Quote
Old 11-29-2004, 04:40 PM   #2
io_303
NIFOC
io_303's Avatar
io_303 is on a distinguished road
Steady white smoke; warm engine; any air temperature. This is bad news. The engine's coolant is leaking into the combustion chamber and creating a steady flow of steam. Caused by a leaking head gasket or a crack in a cylinder head, most commonly in the exhaust port area. Usually requires serious surgery on the engine.
Puff of white smoke during cranking, before the engine starts; cold engine; gas or diesel. This smoke is unburned fuel vapor being pumped out the exhaust pipe. The white is tiny droplets of fuel. In a gas engine, the spark plugs aren't firing, or the fuel mixture is too rich to ignite. It may mean the choke plate is stuck closed, or a load of bad gasoline. In a diesel, this cranking smoke indicates defective glow plugs, but may also come from low compression caused by worn rings or valves.
DD: 2003 Eclipse GT
WIp: SBF 1985 RX7 on the bottle
io_303 is offline   Reply With Quote
Old 11-29-2004, 10:04 PM   #3
97BlackCivic
97BlackCivic's Avatar
97BlackCivic
from what ur sayin it sounds like a blown head gasket.
97BlackCivic is offline   Reply With Quote
Old 12-02-2004, 06:56 AM   #4
HiGH_CiTY
Lock It Up!
HiGH_CiTY is on a distinguished road
u should be able to smell the coolant if that is what is burning and the car will eventually overheat once the coolant level is low . . . . . . get a leak down test done
Went to school in ________for a couple of years
My college career got downed with a couple of beers
Came back home, now I gotta pay back loans
Same *****, same block, same s*** they own
Only thing different, quicker, they click that chrome
HiGH_CiTY is offline   Reply With Quote
Old 12-02-2004, 06:58 AM   #5
J32a2OwnsU
Resident Old Man
J32a2OwnsU is on a distinguished road
Yeah sounds blown HGasket. Those cars are notorious for doing that to.. isnt that a 3.0 or 3.5L motor.......?
J32a2OwnsU is offline   Reply With Quote
Old 12-02-2004, 12:27 PM   #6
nd4sped
nd4sped is on a distinguished road
You got coolant getting into the combustion chamber. There are many ways that it can get in there also.
Dosent necasarily mean a head gasket is blown. THough that may be the case. You could have bad valve seals.
nd4sped is offline   Reply With Quote
Old 12-02-2004, 07:27 PM   #7
98_4door
Sexy Cabana Boy
98_4door is on a distinguished road
those are some strong little engines
-That was so f***ing money. That was like the Jedi mind-s***.
98_4door is offline   Reply With Quote
Old 12-03-2004, 12:58 AM   #8
terceltyler
The Silver Bullet
terceltyler is on a distinguished road
so a bit of exhaust is bad is what it sounds like 1o_303 is trying to say. my moms car and everyone elses car here smokes a little when you 1st start it up in the cold. leaking coolant has a very distinguised smell too..like something burning almost like rubber......kinda
Originally Posted by toneekay View Post
Right now my car is set up for autox/rr and I want it to be more street friendly (so when woman ride in my car they wouldn't be bouncing all over the place)... (great for looking at teh boobs, but not so pleasant in getting into them pantaloness)!!!
terceltyler is offline   Reply With Quote
Old 12-04-2004, 01:18 AM   #9
wildest5
B16a1 CRX Si
wildest5 is on a distinguished road
sell it quick
wildest5 is offline   Reply With Quote
Old 12-06-2004, 08:13 PM   #10
vejita1283
vejita1283's Avatar
vejita1283
oh...ALOT of water is leaking out of the exhuast, but its clear, not murkey or yellowish(coolant)
Old 12-15-2004, 08:14 AM   #11
Doms_EJ2
Doms_EJ2 is on a distinguished road
White smoke. Most of the time means your piston rings are gone......
Doms_EJ2 is offline   Reply With Quote
Old 12-21-2004, 01:56 AM   #12
cheezeonmakneez
love unicorns
cheezeonmakneez's Avatar
cheezeonmakneez
sell it to a junk yard, j/p if water is coming out your exaust you could have a cracked block or head or a bad head or intake gasket. check to see if you got water in your oil if so i highly reccoment drain the fluids and chase the water with wd40. ( spray it in the spark plug holes) this will save whatever is left of your piston rings. if you let the water stay in the cylinder's in the next month you will notice particles of your piston rings flying out of the tail pile. water will rust the hell out of them and then your due for a rebuild.
cheezeonmakneez is offline   Reply With Quote
White Smoke Pouring Out Of Exhaust, Sluggish, Hesitant onesikEJ8 Engine Tech / Drivetrain 2 05-19-2011 01:05 PM
white smoke from exhaust? 1993civicDX Tech Archive (No Posting) 31 07-22-2010 12:46 PM
What causes white smoke in the exhaust? CiViC_eK24 Tech Archive (No Posting) 14 05-24-2010 10:44 PM
white smoke out exhaust, help please jardine90si Engine Tech / Drivetrain 5 07-06-2009 06:16 PM
white exhaust smoke ekturbo Engine Tech / Drivetrain 2 10-16-2008 03:04 PM
