Search:
Welcome to ClubCivic
How bad is it to have too much oil?
Responding Members:
User Tag List
Closed Thread
Old 02-07-2005, 06:59 PM   #1
HonUtd07
It's a Joke
HonUtd07's Avatar
Default How bad is it to have too much oil?
How bad is it to have too much oil in your motor? I recently changed my oil myself for the first time, and only about half a gallon of oil drained. I put in the recomended 4.2 quarts of oil, and now the oil level seems to be kinda high on the dipstick. The car runs and drives the same as it did before. I just don't want to keep driving like that if it's gonna hurt anything. Any input is appreciated.
HonUtd07 is offline
Old 02-07-2005, 07:07 PM   #2
05
Show Me Them Titties
05's Avatar
just take the oil plug out and drain a little bit, then check your dipstick again
05 is offline
Old 02-07-2005, 07:12 PM   #3
civic939
Drive Fast Or Die
civic939's Avatar
i over oiled a truck once and i blew the head gaskets because of too much oil pressure. i would fix it quick. im sure it would do the same in a honda.
civic939 is offline
Old 02-07-2005, 07:15 PM   #4
nd4sped
TO much oil is just as bad as to little oil. Having to much can cause the flow of oil to slow, hence build pressure. Building pressure in certain areas of the engine can be very damaging. If too much oil were to get between say the crank bearings, one side of the bearings will make contact with each other.
Its very important to measure teh exact or very closely to your recommended oil capacity. Also if you cant put oil ini teh Oil Filter before its screwed on you need to check the recommened capacity with the filter on.
(All Hondas to my knowledge, cant fill the oil filter and apply the filter without spilling the oil)
nd4sped is offline
Old 02-07-2005, 07:44 PM   #5
Tom
honda.co.jp
Tom's Avatar
you'll blow alot of smoke, and not just outta your ass either.
oh and civic's actually take 3.5 quarts, unless you got a swap.
Originally Posted by Destroy View Post
Put some forged internals in it. What the f*** else would you put in, rainbows?
Tom is offline
Old 02-07-2005, 07:47 PM   #6
nd4sped
4.2-4.5 Qts in most B series engines.
nd4sped is offline
Old 02-07-2005, 08:07 PM   #7
civic939
Drive Fast Or Die
civic939's Avatar
after you put oil in start the car for about ten seconds to get the oil into the filter and into the rest of the motor. turn it off and then check again. repeat this untill you get the right amount of oil. depending on how over full it is it could almost be worse than low oil
civic939 is offline
Old 02-07-2005, 08:24 PM   #8
Tom
honda.co.jp
Tom's Avatar
4.2 for non-vtec b18's, and 4.8 for dohc vtec, that's going by honda's chart at work.
and 3.5 for 92 and newer sohc civic's.
Tom is offline
Old 02-07-2005, 08:55 PM   #9
nd4sped
Tom you get a Gold Star.
Ya your right about 4.8 too. I meant to add that.
nd4sped is offline
Old 02-07-2005, 09:09 PM   #10
HonUtd07
It's a Joke
HonUtd07's Avatar
Outta my Honda Civic & CR-V/Acura Integra - anywhere from 1994 to 2000 Haynes Repair Manual...
Capacities
Engine Oil
Civic
B16A2............ 4.2 quarts
The largest engine oil capacity is 4.2 quarts. The B18B1 is 4 quarts and the B18C1 and C5 is 4.2. That's where I got my info from.
HonUtd07 is offline
Old 02-07-2005, 09:18 PM   #11
Tom
honda.co.jp
Tom's Avatar
Capacities
Engine Oil
Civic
i do this s*** for a living, just trust me, i know i'm right.
A.K.A haynes doesn't know s*** compared to honda, or it's trained employee's, lol.
OH and YEA i get a gold star, lol.
Tom is offline
Old 02-07-2005, 09:27 PM   #12
HonUtd07
It's a Joke
HonUtd07's Avatar
Yea... After I posted I figured Honda would know their engines better than Haynes. Ah well... It's actually been about two weeks since I changed the oil. Do you think if something was gonna happen, it would've happened by now?
HonUtd07 is offline
Old 02-07-2005, 09:32 PM   #13
Tom
honda.co.jp
Tom's Avatar
it might hurt the PCV system, might, but not sure, just check you intake plenum, or rather throttle body, if you see no oil going back in then your ok, but you should drain and refill teh correct amount.
Tom is offline
Old 02-07-2005, 10:11 PM   #14
civic939
Drive Fast Or Die
civic939's Avatar
i agree. instead of waiting for something to happen. do us all a fovor drain some oil. i dont want to hear another "oh crap my cars broke".
civic939 is offline
Old 02-07-2005, 10:31 PM   #15
TenzoMonk
Lick your back on it
TenzoMonk's Avatar
i'm assuming these are all figures based on changing the filter as well, correct? (not that i know anyone who wouldn't take the 3 minutes to change the filter, if changing the oil... but)
TenzoMonk is offline
Closed Thread
Really bad oil leak! Help!? Djames93 Engine Tech / Drivetrain 2 07-16-2011 09:04 PM
bad oil pump JDM_SPEC_SI-R Engine Tech / Drivetrain 5 02-24-2011 01:18 PM
How bad is overfilling the engine oil? bmboll Engine Tech / Drivetrain 6 08-17-2010 01:11 AM
Bad Oil, need to clean out the engine joe7987 Engine Tech / Drivetrain 6 07-09-2009 12:15 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
