Search:
Welcome to ClubCivic
P0505 Idle Control System Malfunction
Responding Members:
User Tag List
Old 02-25-2005, 11:57 PM   #1
TurboEM1
Default P0505 Idle Control System Malfunction
Hey guys my 99 Si is throwing this code. I erased it but it came back an hour later. How do i got about fixing this? What part should I buy? How much?
Also is it safe to do some minor driving untill i fix it?
TurboEM1 is offline   Reply With Quote
Old 02-26-2005, 12:11 AM   #2
Sleeper
92 4doorSleeper
Sleeper's Avatar
remover the IACV & clean the carbon out of it, if still throws code, then raplace IACV. its like $150
1993 Frost White Built & Boosted GT35R B18C1 Civic sedan
1992 Laguna Green BMW 325i sedan (E36/LS1 project)
1997 Forest Green Toyota Tacoma lifted on 33's
Sleeper is offline   Reply With Quote
Old 02-27-2005, 10:01 AM   #3
TurboEM1
Any info on where its located and how to remove and clean it?
Old 02-27-2005, 10:22 AM   #4
Sleeper
92 4doorSleeper
Sleeper's Avatar
Back of the intake manifold, use chock & carb cleaner
Old 02-27-2005, 11:47 AM   #5
Bobo_686
Shiny things amuse me
Bobo_686's Avatar
open the throttle plate up an just spray the cleaner in and use an old toothbrush, ive found out that works really well and wont scratch the surface
Bobo_686 is offline   Reply With Quote
Old 02-27-2005, 12:16 PM   #6
Sleeper
92 4doorSleeper
Sleeper's Avatar
that wont touch the IACV though, itll clean the thrittle body though lol
Old 12-18-2005, 05:55 PM   #7
Team2000
I just had this code on my EM1 last night, I was wondering what was done to fix it, or if you did anything to fix it dude?
Team2000 is offline   Reply With Quote
Old 12-18-2005, 11:29 PM   #8
gearbox
clean IAC valve and check the fast idle thermo valve if you have one.
gearbox is offline   Reply With Quote
Old 12-26-2005, 10:29 PM   #9
TurboEM1
sorry for the late reply. I unbolted it from the back of the intake manifold. Cleaned it out with carb cleaner really good. Let it soak a lot and rinsed it a lot all with carb cleaner. Sprayed the hell out of it because i didnt want to shell out $190 + for a new one. Then let it sit outside to air dry for about 30 minutes. Bolted it back up and the code never came back **Knock on wood**
Old 12-27-2005, 01:21 AM   #10
j_fukin_t
j_fukin_t's Avatar
try the seafoam to bro sounds like ya got a dirty intake
JDM Honda EK9 Converted To USDM EM1 Coupe
j_fukin_t is offline   Reply With Quote
Old 04-16-2007, 11:06 PM   #11
CIVIC12345
CIVIC12345's Avatar
po505 idle control malfunction poped up i cleaned it with carb choke cleaner still when starting the car rpms go up and then drop like its about do die and after it get warmer the rpms just jump up but when driving and coming to a stop rpm go up and down and then idle at like 1500 or less any help would be appreciated
CIVIC12345 is offline   Reply With Quote
Old 03-28-2008, 02:28 PM   #12
99SilverCX
99SilverCX's Avatar
what car, what motor you have? I had this issue with my B16A OBD1 motor, had to tighten the plate inside the fast idle valve, on my car it was on the bottom of the throttle body
99SilverCX is offline   Reply With Quote
Old 11-25-2009, 07:59 PM   #13
Ben9919591
Default 98 civic ex engine movement
hay guys i have a 98 civic ex. and after replacing all the motor mounts with some new stock ones my shifter still moves up to half of an inch or more wen i am accelerating. i dont like it it makes me feell like i am loosing acceleration speed is it supposed to be like that if not any suggestions???
Ben9919591 is offline   Reply With Quote
Old 11-25-2009, 10:29 PM   #14
What does this have to do with CEL code P0505? You should make your own thread.
RonJ is offline   Reply With Quote
Old 11-29-2009, 08:40 PM   #15
MyNaSi51
MyNaSi51
i have the same problem but no cel. i cleaned my iacv, o btw i have a b16a2 the car idles much better now, only problem is when u give it gas it revs up but it when the idle decreases it hangs at 1400 -1650 rpm for a few seconds then drops back down? normal or should i still investigate please help
MyNaSi51 is offline   Reply With Quote
Code p0505; Idle Control System Malfunction (vid) dth0ng69 Tech Archive (No Posting) 3 11-29-2009 05:38 PM
Code PO505 - idle control system malfunction DenSi Engine Tech / Drivetrain 1 07-02-2009 08:35 PM
CEL Idle Control Malfunction...HELP T!mmy Tech Archive (No Posting) 15 04-17-2007 09:14 PM
Idle Control Malfunction xNOBOOSTx Tech Archive (No Posting) 2 06-10-2006 06:08 PM
idle control malfunction TheGuy258 Engine Tech / Drivetrain 2 12-30-2004 03:25 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
