Search:
Welcome to ClubCivic
Help... Install Cam Gear?
Responding Members:
User Tag List
Old 05-16-2005, 12:24 AM   #1
Evan.
iTrader EVERYthing
Evan.'s Avatar
Question How to: Install Cam Gear?
Alright a couple days ago I bought a new timing belt, cause its about time to change it out. Also though I bought an AEM Cam Gear, which I know goes right along with the timing belt, so I was wondering is a cam gear something you can install yourself? I saw the how-to on the timing belt, so I figure Ill do it myself, but want to know if I can do the cam gear as well. Anybody experienced doing a cam gear before? Can you just install it without any tuning? - cause I know you can either retard or advance timing. Any advice would be helpful.
Evan. is offline   Reply With Quote
Old 05-16-2005, 12:31 AM   #2
FRODO
Teh Oldest NooB.
FRODO's Avatar
honestly it is not going to help you...just put it on and set it to 0.
http://www.clubcivic.com/board/showthread.php?t=213508
Turbo build part out.
FRODO is offline   Reply With Quote
Old 05-16-2005, 12:36 AM   #3
Evan.
iTrader EVERYthing
Evan.'s Avatar
At TDC (Top Dead Center) right? Well if you have a dyno and tune it, it could help
Old 05-16-2005, 12:41 AM   #4
FRODO
Teh Oldest NooB.
FRODO's Avatar
on a SOHC not enough to worry with it..you cant tune the intake seperatly, if you read a lot of articles on DOHC tuning you will find that most of the gains are found in just advancing the intake alone..you dont have this ablity.
Old 05-16-2005, 12:47 AM   #5
Evan.
iTrader EVERYthing
Evan.'s Avatar
Yeah I know, on DOHC is where you find power gains with cam gears...I was just saying that there you can set the gear to either advanced or retard timing...
Old 05-16-2005, 12:50 AM   #6
FRODO
Teh Oldest NooB.
FRODO's Avatar
yes that is why it is adjustable...
Old 05-16-2005, 01:03 AM   #7
stolle
stolle's Avatar
if you have the how to on installing the timing belt the cam gear will be cake simply remove the stock cam gear and replace it with the adjustable one line up all the marks just like the stock cam gear and put the new belt on. the bolt for the cam gear is torqued to 27ftlbs and the bolts on the cam gear are torqued to 15ftlbs. adjustable cam gears on sohc's really arent that usefull unless you have an aftermarket cam about all you can do with a stock cam is move the powerband around retard cam timing and your power will come on in higher rpms advance the cam timing and you power will peak out in the lower rpms between 5-6K rpm this could be used to improve drivablitity so your not rapping out your motor all the time to get power out of it but weres the fun in that? i have a cam gear i have it set 2 degrees retard...
edit: to be clear cam timing and ignition timing are not related and are ajusted independently...one with the cam gear and one by rotating the distributor...
2005 Civic Si
2011 Civic lx-s
stolle is offline   Reply With Quote
SOHC cam gear install champfranco Engine Tech / Drivetrain 0 08-18-2010 02:50 AM
how do i install a skunk2 cam n gear? in a head outside car lownslow Engine Tech / Drivetrain 4 11-02-2007 09:06 AM
Cam/Gear install question (cam key) jonesEK Tech Archive (No Posting) 6 02-05-2007 09:18 PM
Will someone with an AEM cam gear on there single cam please clear this up for me Suanico Tech Archive (No Posting) 8 06-22-2006 01:55 AM
96-00 civic ex intake header cam cam gear vafc Suanico Parts Wanted 2 04-20-2006 02:10 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
