Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
urgent help!!! Brake fluid leaking
Responding Members:
User Tag List
Old 05-22-2005, 01:04 PM   #1
soswank
Dentist in the making
Default urgent help!!! Brake fluid leaking
so here is the deal..i was cleaning my rear pads. once all done, i put the wheel hub back on and test. once i started to rotate, i could hear some (minute) metal on mental touching. so i though i'd investigate. i could not tell s***. so then i took off the wheel hub and thought i'd test the brakes, i pressed on the brake pedal and the pads extened outwards and then fuild started to squit. i was like oh s***!!! anyhow, now i can't get the "thing" back in and without putting that back in, i cna't get the hub on. please help. attached are some pictures.
p.s. this is urgent. my car is still on jacks.
this is the part i am talking about
and just to give you an overall picture.
Oral B Dental supplies - tooth brushes, electric and manual; tooth paste; mouth rinses; teeth whitening. 40% less than retail, PM me for details.
soswank is offline   Reply With Quote
Old 05-22-2005, 01:13 PM   #2
FRODO
Teh Oldest NooB.
FRODO's Avatar
looks like a blown wheel cylinder to me.
http://www.clubcivic.com/board/showthread.php?t=213508
Turbo build part out.
FRODO is offline   Reply With Quote
Old 05-22-2005, 01:15 PM   #3
soswank
can i fix it myself or do i need to take it to a shop?
Old 05-22-2005, 02:34 PM   #4
soswank
ok, to update you all. i've f***ed up my brakes. i am going to be taking it into the shop on monday. i was saving up the money for my DAT exam. s*** i hate this.
Old 05-22-2005, 03:16 PM   #5
Bangin' HB
surfing member
Bangin' HB's Avatar
wheel cylinder, $15. and did you activate the brakes with the drum off?
reppin the Teal Hatch Cult@civichatchback.com
"Save a wave, ride a surfer!"
Bangin' HB is offline   Reply With Quote
Old 05-22-2005, 03:22 PM   #6
slambed_civic
Titanium Member
slambed_civic's Avatar
crack the bleeded screw on the back of the wheel cylinder open and just push the wheel cylinder piston back in... its as simple as that... bno big deal, youll just need to rebleed your brakes..
slambed_civic is offline   Reply With Quote
Old 05-22-2005, 03:33 PM   #7
soswank
do you have a pic of that screw? how much bleeding should i do?
Old 05-22-2005, 03:33 PM   #8
soswank
how do i activate teh brakes with teh drum off?
Old 05-22-2005, 03:35 PM   #9
slambed_civic
Titanium Member
no i dont, if you look on th aBACK side of your brakes... the heat shield im talking about, there is a little bolt looking thing.. kinda looks like a grease fitting. take the rubber cap (if there is one) off and use a 9mm ( i think) and open it. make sure you do this with someone else.
Old 05-22-2005, 03:36 PM   #10
soswank
do i need to replace teh wheel cylinder?
Old 05-22-2005, 03:37 PM   #11
soswank
let me post a picture of the back so that you can tell me exactly what i need to be doing.
p.s. do i need bleed the front as well?
Old 05-22-2005, 03:39 PM   #12
slambed_civic
Titanium Member
no you dont.
Old 05-22-2005, 03:52 PM   #13
soswank
which ones of these is it? and what do i do exactly?
Old 05-22-2005, 03:59 PM   #14
slambed_civic
Titanium Member
the one in red
Old 05-22-2005, 04:07 PM   #15
silvertuner98
o wow that sucks. ive seen it done before tho and its a simple fix. its already been solved tho by another member. simply open the bleeder and then push the pistons back in. then bleed ur brakes. as long as the seal isnt screwed up u should be okay. and NO the boot that u see is NOT the seal. spray that down with brake clean and then put the drum back on and bleed the brakes then pump the pedal and see if anymore fluid comes out. check behind the dust boot as well. if it still leaks, then u can either replace it or do like my cheap ass sometimes does when money is tight and try to rebuild it
silvertuner98 is offline   Reply With Quote
Transmission Fluid Recommended Urgent !!!!!!! tsujbtc Tech Archive (No Posting) 12 01-26-2011 01:19 AM
Need Urgent Help: Cam Seal Keeps Leaking After Replacement coolguy Engine Tech / Drivetrain 4 05-16-2008 10:25 AM
im leaking tranny fluid what should i do? James_spec Tech Archive (No Posting) 1 08-07-2007 02:59 PM
Leaking brake fliuid guwakjai010 Tech Archive (No Posting) 3 10-10-2006 02:59 PM
leaking brake line? j-muny Wheels / Tires / Brakes / Suspension 10 10-30-2004 06:23 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
