d16y8 97 ex s40 transmission question
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 06-19-2005, 03:15 PM   #1
RKSskier
RKSskier's Avatar
RKSskier is on a distinguished road
Default d16y8 97 ex s40 transmission question
I have a 97 ex and am getting a new tranny. I have heard some mixed up and unclear things about the tranny I need. I Still want the ex tranny. I believe that 96-00 tranny's are all s40, correct? Also am I right that the ex tranny is the b000 ? I am probally getting a tranny from a friend that just bought a replacement motor d16y8, did the y8 only come with the shorter geared tranny? I am just hearing some different things, and want to make sure I get the right one, so if anyone could confirm this if they know it for sure that would be great, thanks.
yup, its waterskier not snow...... i bet you guys had no idea
RKSskier is offline
Old 06-19-2005, 03:20 PM   #2
silvertuner98
silvertuner98 is on a distinguished road
as long as it is the s40 b000 u have the correct 96-00 civic ex 5 speed transmission. the s40 a000 is from the lx/dx etc
silvertuner98 is offline
Old 06-19-2005, 03:40 PM   #3
Nicathug
Nicathug is on a distinguished road
Can a 96-00 Civic EX 5 Speed Transmission fit a 1996 to 2000 Civic Lx?
Nicathug is offline
Old 06-19-2005, 03:50 PM   #4
anfrey
OG スバリスト
anfrey's Avatar
anfrey is on a distinguished road
yes, it will fit perfectly nicathug. i have the b000 on my y7
set the gearshift for the high gear of your soul... you've got to run like an anfelope, out of control!
"government big enough to supply everything you need is big enough to take everything you have.
the course of history shows that as a government grows, liberty decreases." - thomas jefferson
"a wasted vote, is voting for someone that you don't believe in." - gov. gary johnson
"non impediti ratione cogitationis" - conloquium currus
anfrey is offline
Old 06-19-2005, 05:00 PM   #5
RKSskier
RKSskier's Avatar
thanks guys, just what i needed to be comfirmed, and thanks for the quick reply
RKSskier is offline
Old 06-19-2005, 05:02 PM   #6
RKSskier
RKSskier's Avatar
anfrey I am assuming that you mean you have the b000 on your y7 as an uprgrade and that you initially had a a000?
RKSskier is offline
Old 06-19-2005, 05:06 PM   #7
anfrey
OG スバリスト
anfrey's Avatar
i drive an EJ8. i used to have a complete y8 setup stock. my exroommate f***ed up my engine so all i could get was a y7 (being poor sucks, everyone else would be doing a phat swap.. instead i go for an engine with 20hp less) but the only thing y7 in my car is the longblock. all my manifolds are from my y8... but anyway, my b000 y8 tranny bolted on no problem to the d16y7.
anfrey is offline
Old 06-19-2005, 05:06 PM   #8
Nicathug
O for reaal, dats good to know. So the S20 Honda Civic Ex/Si Transmission will fit on my 1998 Honda Civic LX D16y7 Engine?
Nicathug is offline
Old 06-19-2005, 05:08 PM   #9
anfrey
OG スバリスト
anfrey's Avatar
the s20 from the 5gen ex/si should fit as well... most d-series parts will bolt up fine.
anfrey is offline
Old 06-19-2005, 05:22 PM   #10
Nicathug
6 Gen EX/Si Transmission work on the Civic too, by the way what is the code for the 6 Gen?
Nicathug is offline
Old 06-19-2005, 05:24 PM   #11
RKSskier
RKSskier's Avatar
Anfrey... Did you even really notice a difference then from the y8 block to the y7? I mean they have very similar power curves when looking at dyno graphs of them, and the torque is really close. So I imagine that in your case with the y8 manifolds, (do you have a y8 head on there?) and with the b000 tranny that you really didnt notice much of a difference?
RKSskier is offline
Old 06-19-2005, 05:29 PM   #12
RKSskier
RKSskier's Avatar
Ohh and I am pretty sure, but if someone could also comfirm for me that all d16y8 engines came with the b000 transmission only, that would be great.
RKSskier is offline
Old 06-19-2005, 05:31 PM   #13
anfrey
OG スバリスト
anfrey's Avatar
all y8s from the factory should come with the b000
anfrey is offline
Old 06-19-2005, 06:00 PM   #14
silvertuner98
96-00 civic transmission codes are all s40 (except b-series engines/trans), how to tell the difference in the gearing is the casting stamp.
92-95 civic transmission codes are all s20 with the same stamping
s20 b000 is from a 92-95 civic ex/si
i have a s20 b000 in my 98 ej8 right now..... so it does work.
i do believe 90-00 civic transmissions (other then hydro/cable) are interchangable, and as well 88-89 had an input shaft with a different # of splines.... ill research more if needed lol
Old 06-19-2005, 07:52 PM   #15
anfrey
OG スバリスト
anfrey's Avatar
thanks matt
anfrey is offline
WTB: MD: d16y8 transmission lvlistchif Parts Wanted 1 04-14-2010 04:08 AM
1996 DX 4dr S40 Transmission wahoo Parts Wanted 2 11-06-2009 10:32 AM
FS: OBD2 Injectors * 96-98 Coupe Tail lights * S40 Transmission * JR Test Pipe SiRcivic27 Parts for Sale 77 09-14-2009 10:04 AM
WTB: S40-K4F, D16y8,96-00 Civic Ex M/T Project "H" Parts Wanted 0 08-02-2009 03:50 PM
D16Y8 engine and transmission... Jimmy2times Parts Wanted 9 01-23-2007 01:36 AM
