Search:
Welcome to ClubCivic
B20Z2 question
Responding Members:
User Tag List
Old 07-05-2005, 10:15 PM   #1
Mister_Perkins
Team Honda
Mister_Perkins's Avatar
Default B20Z2 question
I found a motor that looks promising. Its a B20Z2 Long Block. it has 84mm bore 9.8.1 Compression. I was told from a guy that is a mechanic at honda usa, and he said that if I got a CRV Block with an Integra head, it was the way to go as far as power. First, would the engine fit in my car? My other question is would I be able to use my tranny, or would I have to swap a new tranny in it as well? I am assuming I will need to change motor mounts, Computer, Harness, etc.. ? Is this a correct assumption? I would really appreciate some feedback, as I am seriously looking into either getting a B16a2 or a B20z2 if it will fit. Thanks.
Mister_Perkins is offline
Old 07-05-2005, 10:19 PM   #2
Inigo Montoya
powered by boost
Inigo Montoya's Avatar
b20z2 is indeed the CR-V.
You will need the following if you are running a D motor:
mounts
harness
axles
ecu (get p28 or similar obd1)
ecu conversion harness (or rewire yourself.. easy if you know what youre doing)
tranny
As far as b20 + b16/b18 vtec head... its like any other frankenstein.. have a shop do it, and make sure they adress oil pressure.
b20 + turbo = pwnge.
300whp is a safe limit on these blocks too btw.
How mucha are you paying?
I know cars. Kinda.
The lair of the beast
Inigo Montoya is offline
Old 07-05-2005, 10:22 PM   #3
grncoupe98
yes it will fit i have a friend with the b20 vtec in a 92 hatch and no you cant use your tranny and your assumption is correct
grncoupe98 is offline
Old 07-05-2005, 10:27 PM   #4
Mister_Perkins
Team Honda
mounts
harness
axles
tranny
Thats awesome that it will fit.. Im totally stoked. The guy is selling me it for 900.00 + 300.00 s&h. Is this a decent deal price wise?
Old 07-05-2005, 11:19 PM   #5
Mister_Perkins
Team Honda
Old 07-05-2005, 11:28 PM   #6
that VERBAL
AKA Theiven Stealberg
that VERBAL's Avatar
I have never had or ridden in one, but I have heard of reliability issues with the CRV-tec. I am not an expert on B20 motors, and I'm sure somebody can elaborate on it, but the stroke isn't very suitable for making high power apparently and the cams can't be adjusted too much.
It's a frankenstein motor, so don't expect the most reliability out of it. You can read up on it here....
http://honda-tech.com/zerothread?id=174153
that VERBAL is offline
Old 07-05-2005, 11:33 PM   #7
Inigo Montoya
powered by boost
for just the motor or tranny + ecu + harness + axles etc included?
I personally would pay 1200 shipped if its a complete swap, otherwise i wouldn't spend over 800 shipped.
I know cars. Kinda.
Old 07-06-2005, 12:55 AM   #8
Handlebars
None Taken.
Handlebars's Avatar
1200 is pretty high, it better have a warranty and very low miles. b20's are great motors, i had one in my car for a year, it totally transforms the feel of a civic. its a b**** to do the swap though, it takes more work than a normal b swap.
Handlebars is offline
Old 07-06-2005, 09:25 AM   #9
Mister_Perkins
Team Honda
It is a complete swap
Old 07-06-2005, 09:26 AM   #10
Mister_Perkins
Team Honda
Why did you only have it in your car for a year? Is the B20 a horror story?
Old 07-06-2005, 11:01 AM   #11
Handlebars
None Taken.
Handlebars's Avatar
no not at all, i just wanted something different.
Old 07-06-2005, 11:53 AM   #12
that VERBAL
I have heard a number of horror stories though, you always do with frankenstein motors though. if it is done right and you aren't trying to squeeze like 400 whp out of it daily driven though you shouldn't have to worry TOO much.
Old 07-06-2005, 07:39 PM   #13
Inigo Montoya
powered by boost
its all in the build.
if you want to rev.. build the head.
if you want to push over 250whp daily, it would be wise to look into internals for longevity.
if you want over 300whp, you need to adress the thin sleeves.
and for all vtec conversion, you need to adress how much oil is delivered to the head.. aka turn up oil pressure.
I know cars. Kinda.
Old 07-06-2005, 07:43 PM   #14
stealthy
4 Doors For More Whores
why do you say that?what makes it more work than a normal b swap?
--BJ--
- GSR Sedan
- CP 81.5 9:1 Pistons
- Eagle H Beam Rods
- Garrett T3/60-1 .63a/r
stealthy is offline
Old 07-06-2005, 09:53 PM   #15
Handlebars
None Taken.
Handlebars's Avatar
most b swaps are just pull out the d, drop in the b, maybe add a few wires. b20 requires actually putting together a swap by searching down a bunch of parts. the physical swap itself is no harder, but making it all happen is.
b18c, Ls/Vtec, or B20z2/Vtec ??? NoWayBack91Si Engine Tech / Drivetrain 5 08-17-2008 12:27 AM
Need help with my b20z2 turbo hondajc19 Forced Induction 7 02-27-2008 06:20 PM
B20Z2 Question juan2k2001 Tech Archive (No Posting) 0 09-17-2007 01:54 AM
b20z2 into the coupe eg eddie Tech Archive (No Posting) 9 05-10-2006 06:48 PM
b20z2 into my eg coupe eg eddie Tech Archive (No Posting) 8 04-11-2006 05:40 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
