Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic DIY / How To > DIY How To's > Engine Tech / Drivetrain DIY How-To's
How To: Cam Install
User Tag List
Old 09-02-2005, 11:58 AM   #1
civic hatch
civic hatch's Avatar
Default How To: Cam Install
*not responsable for your mess ups, go buy a tech manual, use common sense, dont know what your doing dont do it.*
How to: Cam Install
Car: 96-00 Honda Civic SOHC
Tools: 12mm Socket
10mm Socket
Timing Gun
Feeler Guages
1. remove neg batt cable
2. remove valve cover (5 10mm bolts)
3. remove timing belt cover (2 10mm bolts)
4. remove spark plugs (makes it easier to turn crank)
5. set #1 cylinder at TDC (Top Dead Center)
6. remove top 12mm distributor bolt
7. loosen timing belt tensioner and slide timing belt of cam gear
8. loosen rocker bolts in sequence (start in center and work out in a cris cross pattern), do not remove bolts from rocker assembly they help to hold the assembly together (10 12mm bolts and 4 10mm bolts)
9. lift of rocker assembly as one unit
10. remove cam shaft and cam gear
11. if want now clean rocker assembly with break clean
12. remove cam gear off old shaft and install it on new camshaft *donít forget the key
13. replace the cam seal
14. lube the new camshaft with assembly lube
15. put camshaft in head with timing marks at TDC
16. replace rocker assembly in reverse order and tighten bolts in sequence
17. replace timing belt and tighten back up
18. set valve lash
19. reconnect neg batt cable
20. start car and adjust timing if necessary
civic hatch is offline   Reply With Quote
Old 10-01-2005, 09:33 PM   #2
barenca4
did this give u more horse power or not
barenca4 is offline   Reply With Quote
Old 10-02-2005, 01:50 AM   #3
civic hatch
yes i did feel alittle more power on the top end, and also a friend that drove my car said he felt a little more on the top end from about 4000rpm's on up. but i only had it in for about 2 weeks before i boosted the hatch.
I'm not African American, I wasn't born in africa. I'm just American
Old 10-24-2005, 12:10 AM   #4
whitechoc1
white chocolate
whitechoc1's Avatar
Default power
how much extra horsepower will that give you
whitechocolate[[FONT=Courier New]
whitechoc1 is offline   Reply With Quote
Old 10-24-2005, 12:11 AM   #5
whitechoc1
white chocolate
whitechoc1's Avatar
oh my bad that question was alredy answered, but what kind of cam did you use and where did you get it
Old 10-24-2005, 12:26 AM   #6
FRODO
Teh Oldest NooB.
FRODO's Avatar
Nice write up.
http://www.clubcivic.com/board/showthread.php?t=213508
Turbo build part out.
FRODO is offline   Reply With Quote
Old 10-25-2005, 10:46 AM   #7
civic hatch
it a delta cam its a regrind and you can get it from delta cam in washington state, sorry i dont have there number right now.
Old 08-16-2006, 11:12 AM   #8
john92civlx
budget builder :)
john92civlx's Avatar
im newb but whats valve lash?
john92civlx is offline   Reply With Quote
Old 03-08-2007, 04:17 PM   #9
Dante S.
Luv 2 Stock Rides
Can You Please Re-link The Images????
Dante S. is offline   Reply With Quote
Old 11-16-2007, 05:59 PM   #10
rodan
Imagesssss.
rodan is offline   Reply With Quote
Old 02-09-2008, 11:53 PM   #11
civic hatch
sorry bout the images but they are back up for good
Old 02-11-2008, 08:03 PM   #12
lostcivic
thanks again bro!
ED6
JDM D16A
lostcivic is offline   Reply With Quote
Old 02-11-2008, 10:31 PM   #13
guwakjai010
Dr Tai tai
guwakjai010's Avatar
those aren't stock springs and retainers right?
guwakjai010 is offline   Reply With Quote
Old 02-14-2008, 01:15 AM   #14
civic hatch
yes they are stockers but new stockers, the cam profile isnt crazy enough that i needed to change them out.
Old 02-14-2008, 03:58 AM   #15
Kenzo
oh you did that in tacoma!
how much was it?
Kenzo is offline   Reply With Quote
SOHC cam gear install champfranco Engine Tech / Drivetrain 0 08-18-2010 02:50 AM
Cam/Gear install question (cam key) jonesEK Tech Archive (No Posting) 6 02-05-2007 09:18 PM
DIY Cam Seal Install Ion22 Engine Tech / Drivetrain 1 08-23-2006 05:32 PM
Engine not starting after cam install L3V3L Tech Archive (No Posting) 6 07-15-2006 11:20 PM
Help... Install Cam Gear? Evan. Engine Tech / Drivetrain 6 05-16-2005 01:03 AM
Copyright ģ2007 ClubCivic.com
Freelance Web Design
