Search:
Welcome to ClubCivic
Which fuse can stop my car from starting?
Responding Members:
User Tag List
Old 09-11-2005, 11:36 AM   #1
demoniclizard
Default Which fuse can stop my car from starting?
The company I work for wants me to go work at one of its stores in a different location for the next four weeks. The store is located in a pretty crime heavy area. I want to know is there a fuse I can pull under my hood that will prevent my car from starting, without damaging my car? This isn't some permanent anti theft solution...i just don't have money to buy an alarm or anything and im really paranoid about my car getting messed with in this area. I thought the car couldn't be started without the ECU, but I pulled out that fuse and the car was still able to start fine so are there any others? A detailed description of where the fuse is located or how its labled would be helpful...this is on a 6th gen civic.
demoniclizard is offline   Reply With Quote
Old 09-11-2005, 11:48 AM   #2
Tom
honda.co.jp
Tom's Avatar
starter relay fuse in the passenger compartment in the fuse box.
Originally Posted by Destroy View Post
Put some forged internals in it. What the f*** else would you put in, rainbows?
Tom is offline   Reply With Quote
Old 09-11-2005, 12:13 PM   #3
demoniclizard
I looked in the fuse box and I found no fuse that was labled speciflcally "starter relay"
What I found though were two similar ones, one named "rr def relay" and "p/w relay, s/r relay"
i tried pulling the one labled "p/w relay, s/r relay" but the car still started
Old 09-11-2005, 12:21 PM   #4
Tom
honda.co.jp
Tom's Avatar
one of those is the power window relay fuse, the other i'm not sure of, check under there and see if any are label'd started realy, if not, check the under hood fuse box.
Old 09-11-2005, 12:24 PM   #5
demoniclizard
Would pulling the fuse labled "fuel pump, srs unit" give the same effect? I would think the car couldn't run without the fuel pump...or would this damage my car by not having this fuse in?
Old 09-11-2005, 12:27 PM   #6
Tom
honda.co.jp
Tom's Avatar
well it certainly won't start without fuel, but let me see if i can find something better first before you try taht.
Old 09-11-2005, 12:32 PM   #7
demoniclizard
I tried starting it without the fuel pump fuse and the car wouldnt start.
now my question is, could this cause anything bad to happen by pulling this fuse out for 8 hrs and putting it back in, 20 times?
Old 09-11-2005, 12:35 PM   #8
Tom
honda.co.jp
Tom's Avatar
well i couldn't find anything else, as for causing something bad, i'm not sure honestly.
Old 09-11-2005, 12:58 PM   #9
io_303
NIFOC
io_303's Avatar
there is always the DIY fuel cutoff switch.
http://www.clubcivic.com/board/showthread.php?t=59178
DD: 2003 Eclipse GT
WIp: SBF 1985 RX7 on the bottle
io_303 is offline   Reply With Quote
Old 09-11-2005, 03:55 PM   #10
PFEVER
PFEVER's Avatar
No Nothing Bad Will Happen By Removeing The Fuse For 8hrs But Before U Turn The Ignitiong To On Or Run Make Sure U Put It Back In .
PFEVER is offline   Reply With Quote
Horn won't stop with fuse in jlt1317 Show off your 6th Generation Honda Civic (1996-2000) 4 08-14-2010 03:15 AM
Car shaking from stop, Auto UEDan Tech Archive (No Posting) 9 05-29-2010 12:58 AM
car shuts off when i come to a stop bossman24 Tech Archive (No Posting) 12 05-05-2010 05:21 AM
HELP!! Car stalling when coming to a stop Futurerel Engine Tech / Drivetrain 10 03-16-2006 01:31 PM
so my car doesnt stop.... soberstan Tech Archive (No Posting) 7 11-08-2004 10:07 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
