Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Interior / Audio / Electronics
Interior / Audio / Electronics Anything Interior related Including interior electronics
New head unit wont turn on
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 09-11-2005, 04:31 PM   #1
r3v0ltcivic
The Ordinator
r3v0ltcivic's Avatar
r3v0ltcivic is on a distinguished road
Default New head unit wont turn on
I bought a new head unit for my car yesterday, i didnt have much money so i went with the best i could find for under $200 Alpine CDE-9843, i bought the harness for it and did all the wiring myself, the wires all match up and theres even power running through it. But when its all connected and the faceplate is on it wont turn on. i read the manual and everything is done right.
any ideas? or should i just take it back and have it looked at/ get a new one.
r3v0ltcivic is offline   Reply With Quote
Old 09-11-2005, 11:57 PM   #2
cujo613
cujo613's Avatar
cujo613 is on a distinguished road
most shops install stereos for free when you buy them there
cujo613 is offline   Reply With Quote
Old 09-11-2005, 11:59 PM   #3
DirtyD
DirtyD's Avatar
DirtyD is an unknown quantity at this point
how do you know there's power running through it
check your wiring again
DirtyD is offline   Reply With Quote
Old 09-12-2005, 12:00 AM   #4
j_fukin_t
j_fukin_t's Avatar
j_fukin_t is on a distinguished road
some wire has to be disconnected then or your radio fuse is blown
JDM Honda EK9 Converted To USDM EM1 Coupe
j_fukin_t is offline   Reply With Quote
Old 09-12-2005, 12:00 AM   #5
EG_CaSe
ScAre CrOw
EG_CaSe's Avatar
EG_CaSe is on a distinguished road
sounds like either somone droped it or its a defect.. it happen to me plenty of times, i even got one without a face cover and the damn assholes swore to god i stole the radio
I'm Back
Honda|Done
ONE SIG IMAGE PER MEMBER.
EG_CaSe is offline   Reply With Quote
Old 09-12-2005, 12:13 AM   #6
ventturei26
Capt. Fuse
ventturei26's Avatar
ventturei26 is on a distinguished road
check all the fuses, sometimes 2 or 3 fuses can control the important wires to your deck. u might have touched a wire to a wire and not noticed
I CONSIDER IT MY CIVIC DUTY TO OWN A HONDA
wtb: front camber arms, jdm audio console, CF hood and hatch
ventturei26 is offline   Reply With Quote
Old 09-12-2005, 12:20 AM   #7
EG_CaSe
ScAre CrOw
EG_CaSe's Avatar
yea this could be another thing to check while the radios in..,
I'm Back
Honda|Done
Old 09-12-2005, 12:49 AM   #8
Mr.Luder
SSM EP3
Mr.Luder is on a distinguished road
check ur fuses.!!! if u changed ur radio without pullin the negative side of ur battery almost 80% of the time ur fuse has went out during installation
Mr.Luder is offline   Reply With Quote
Old 09-12-2005, 10:06 AM   #9
GTIUNIT
very yes...
GTIUNIT's Avatar
GTIUNIT is on a distinguished road
check the back up fuse under the hood, 9 times out of ten that fuse is blown
98 civic...164,000 miles of single cam slowness...
GTIUNIT is offline   Reply With Quote
Old 09-12-2005, 05:22 PM   #10
97civic123
97civic123 is on a distinguished road
might not be it, but some alpine you have to press the source button.. you probably already did that. if so, most likely it's defective.
97civic123 is offline   Reply With Quote
Old 09-12-2005, 05:26 PM   #11
deaconwagers
...now rockin an integra
deaconwagers's Avatar
deaconwagers is on a distinguished road
first check your fuses, then take the radio back where you bought it and have them test it.
deaconwagers is offline   Reply With Quote
Old 09-12-2005, 06:51 PM   #12
cujo613
cujo613's Avatar
then have them install it
Old 09-12-2005, 06:58 PM   #13
Mr.Luder
SSM EP3
check fuses under dash panel and under the hood...if all fuses are go than its ur deck! simple as that! unless u lost power somewhere in between
Old 09-12-2005, 08:06 PM   #14
homicydalboy
vtec+turbo=no traction
homicydalboy is on a distinguished road
With all of the head units that I have delt with there are three wires that you have toi have connected in order for it to turn on. The power wire, the ground, and the memory wire. I know that this isnt the right way to test it but this is what I do if it wont turn on. I take the head unit out of the car up to the battery in my car and I hold the ground to the negitive pole and I hold the memory and the power wire to the positive pole if it does not turn on then you know that the radio is defective if it does turn on then you know that the wiring is messed up or you have a blown fuse.
that is all I can think of. Or just take it back and get a new on installed for you.
__________________________________________________ __________
My Momma always said I could be anything I wanted to be when I grew up....... So I decided to be an ASSHOLE!!!
homicydalboy is offline   Reply With Quote
Old 09-12-2005, 09:28 PM   #15
loccusst
Experienced Noob
loccusst's Avatar
loccusst is on a distinguished road
Did you get it to work or what? Did you check the fuse under the hood, dash, and on the back of the radio? Did you use a DMM to see if you were getting power to the radio? If you bought it some where like Best Buy why not have them install it for free?
Anyone can drive fast in a straight line......its driving fast around corners that takes skill.................
loccusst is offline   Reply With Quote
Wont turn over robk66 Tech Archive (No Posting) 5 05-29-2010 12:30 PM
D16Y8 wont turn HELP!!!!! Project "H" Tech Archive (No Posting) 15 08-30-2009 04:02 PM
Head unit wont turn on and clock on Dash keeps resetting itself Dankmaster24 Interior / Audio / Electronics 7 11-18-2008 10:49 PM
FS: Alpine head unit and pioneer head unit cheap da2005pizimp Parts for Sale 0 05-08-2008 01:27 AM
Amp wont turn off darkness Interior / Audio / Electronics 3 03-08-2005 09:34 AM
