Search:
Welcome to ClubCivic
Autocross setup for my 92 Si HB
Responding Members:
User Tag List
Old 10-19-2005, 01:02 PM   #1
Crave
Default Autocross setup for my 92 Si HB
Hi,
I will be autocrossing my 92 Civic Si HB next year, and want to start planning out the setup for it. This is what I already have installed:
Koni Yellow Adjustable shocks
Eibach Springs
AEM Cold Air intake
DC Sport Ceramic Header
DC Sports front upper strut bar
NoName rear upper strut bar
17" Wheels and tires
Stock exhaust from cat back
D16Z engine
Stock Si tranny
Polyurethane bushings all around
This is what I'm thinking of doing:
Replace the 17" W&T's with 15"
Install rear lower tie bar
Install front h-brace
Reinstall stock exhaust manifold.
Polyurethane engine mount stiffeners
It's no secret the 15" wheels are better then 17" for autocrossing. The lower tie bars are to stiffen the chassis. My reasoning for reinstalling the stock exhaust manifold is to gain some low-end torque since the autocross courses are pretty tight, and usually get run in 2nd gear.
What do you guys think? Should I do anything else? This is not my daily driver, but will have to remain street legal. What would you recommend for tires?
Thanks.
Crave is offline
Old 10-19-2005, 01:54 PM   #2
itsmycookie
#1 asshole
itsmycookie's Avatar
Falken Azenis
itsmycookie is offline
Old 10-19-2005, 02:23 PM   #3
FRODO
Teh Oldest NooB.
FRODO's Avatar
Bigger sway bars.
http://www.clubcivic.com/board/showthread.php?t=213508
Turbo build part out.
FRODO is offline
Old 10-19-2005, 05:42 PM   #4
Inigo Montoya
powered by boost
Inigo Montoya's Avatar
A new car... because most tracks don't allow cars w/ sunroofs.
I know cars. Kinda.
The lair of the beast
Inigo Montoya is offline
Old 10-20-2005, 02:04 PM   #5
Crave
Falken Azenis - I'll look into these, thanks.
Bigger sway bars - by which manufacturer? WIll Integra bars fit?
A new car... because most tracks don't allow cars w/ sunroofs - When I say AutoCross, I mean Solo I, so sunroofs are allowed.
Crave is offline
Old 10-20-2005, 02:09 PM   #6
joe7987
Yep.
joe7987's Avatar
I don't exactly agree that the 15"s are better than the 17"s....
When you downgrade the size of your rims, you'll be more than likely downgrading their width... which means you can't get as wide of a tire... which means you'll have less contact between rubber and the ground... which means you'll have less traction.
I'd probably go with a lightweight 17" rim.... or if you're really that self conscious.. go lightweight 16".. but I wouldnt go all the way down to 15"
CCCC #04
joe7987 is offline
Old 10-20-2005, 02:19 PM   #7
Crave
The reason that 15's are better is because they are lighter. In AutoCross, or Solo I racing, you rarely get past second gear so the car is not moving so fast that you would require the extra contact patch to help you take a corner faster. Also, all else being equal, 15" wheels are cheaper then 17", so the money saved on wheels can be used to buy a better quality tire.
Crave is offline
Old 10-20-2005, 07:19 PM   #8
lo-fidelity
Definitive Motion
sway bars.. it will help you alot.
lo-fidelity is offline
Old 10-20-2005, 09:51 PM   #9
peter
peter's Avatar
For autocross and track days wheels are almost always:
smaller>bigger
look at F1, they don't use super huge wheels
peter is offline
Old 10-20-2005, 09:54 PM   #10
deaconwagers
...now rockin an integra
deaconwagers's Avatar
i'd upgrade only the rear swaybar, makes it easier to steer on a tight course.
deaconwagers is offline
Old 10-20-2005, 09:59 PM   #11
stealthy
4 Doors For More Whores
id get 16s,the sidewalls on the tires will be stiffer.also get falken azenis Rt215 or hankook ventus Rs2 Z212
--BJ--
- GSR Sedan
- CP 81.5 9:1 Pistons
- Eagle H Beam Rods
- Garrett T3/60-1 .63a/r
stealthy is offline
Old 10-21-2005, 01:18 PM   #12
rei
jSolo
rei's Avatar
a basic short ram intake might be better than the cai for autocross, better throttle response..
"It's just a ride"
rei is offline
Old 10-21-2005, 04:48 PM   #13
Bouncer
Bouncer's Avatar
tire choice also depends on the weather conditions, im pretty sure its wet in canada a lot so you might wanna go for some nitto neogens, ive had some really good experiences with these.
Bouncer is offline
Old 11-02-2005, 10:31 AM   #14
Crave
What manufacturer of sway bars would you recommend?
Canada isn't really wet, maybe compared to AZ it is, but not overall, specially in the summer months.
Crave is offline
Old 11-02-2005, 11:05 AM   #15
gabebauman
Sk8aholic
gabebauman's Avatar
Not exactly...I have a 205mm wide tire on my 15's and I ran the same width tire on my 17's. For a 5th gen hatch you'll definately want a 15in wheel with a 205/50 tire or maybe 215/50. You can also swap an ITR rear swaybar straight over for excellent corner response. CLICK THIS TEXT
gabebauman is offline
autocross modifications srtabani New to the Site? 4 12-06-2010 01:13 AM
autocross EGcivicLC Wheels / Tires / Brakes / Suspension 5 07-14-2005 08:33 PM
autocross doug piston NorthWest 46 03-15-2005 04:44 PM
autocross TheGreenMachine Street/Track 10 12-03-2004 11:14 AM
Autocross VTECSOHC02 Street/Track 19 05-04-2004 08:00 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
