Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Engine Tech / Drivetrain > Engine Tech / Drivetrain Tech Archive / How To's
How To: D16Y8 PCV Valve Change
Old 11-05-2005, 04:33 AM   #1
c_diddy
drove through a tree
c_diddy's Avatar
Car: sea turtle
View/Rate My Garage
Default The Official D16Y8 How to PCV Valve Change+Pictures! Finally! (56K, your pushing it)
Okay, I know a lot of people have been asking about this and I said that I would have done this about 2 months ago, but I kept getting sidetracked and what not. So here it is finally, so no more threads about this!
First of all, I learned how to do this from gabebauman's thread, so I dont entirely take credit for this: http://www.clubcivic.com/board/showt...ight=pcv+valve
so if you would have searched, you should have found this before, right?
Secondly, for you 5th generation owners, the PCV valve is located elsewhere. You can find this here by handlebarsfsr:
One thing you should know is that you have to get the right PCV valve for you car since they're made specifically for it. Anything else and it can cause problems. You can get these cheaply (about $2-$3) from your local autostore or spend about $20 bucks on one from Honda. Your call.
Now onwards!
Parts needed:
Jack and Jack Stands: Saftey First!
PCV Valve
Flat head screwdriver
Needle Nose Pliers
The first step is locating where it is. It is highly recommended that you change your oil first, as you'll see in a moment. But for those who don't want to, good luck lol. The PCV valve is located right above the oil filter (in this picture, it's where the filter should be).
The second step is removing the valve. Here is where you'll need to get the flat head. Do not remove the clamp yet! You'll do that last, trust me. Okay, so locate the hose that's connected to the PCV Valve. Now, just pull on it and it should get stuck; leaving a gap between the edge of the PCV Valve and the black box. Take the flat head screw driver and wedge it between the valve and the black box. You should be able to pop it out with ease.
The third step is to get out from under your car and look under your hood. The hose to the PCV Valve is located in the middle of the intake mani. Pull this out.
Voila!
The fourth step is to unclamp the valve with your needle nose pliers. Shouldn't be too hard without a picture right? Now, get your new PCV Valve and shove it back in; then clamp it.
New PCV Valve from Honda yo:
Here it is out of the package:
Okay, the last steps are to basically do the reverse of what I just said, so I figured you didn't need pictures for that. Ahh the beauty of the internet. And of course to put your filter back on and oil back in and etc. Quick and easy right? Well, I think this should be everything, if there's anything I'm missing, just post it up and I'll add it on. Good luck everyone and of course, always be safe when your under your car!
Ahh, now marvel at my masterpiece , just kidding. This is my one little contribution to clubcivic for all the help and info I've received .
c_diddy is offline   Reply With Quote
Old 11-05-2005, 07:30 PM   #2
AliasNeo
Titanium Member
AliasNeo's Avatar
Car: 96 Civic Ex
1/4 Mile ET: 17.170 @ 81.58 MPH
View/Rate My Garage
yea i was going to do the same thing for a write up but i forgot to get the camera cause i did my pcv valve last week thursday when changing oil for winter times...
good write up tho
AliasNeo is offline   Reply With Quote
Old 11-08-2005, 01:36 PM   #3
dchec
dchec's Avatar
Car: 93 civic lx
View/Rate My Garage
how do u know ur pcv valve needs to be changed? what are the symptoms?
Originally Posted by Rand0m
.. i laugh at everyone who rags on people for having body kits or anything on their car that isnt a performance part "oh faggot, your car is so ricey, go die"....
every car on this site is ricey
dchec is offline   Reply With Quote
Old 11-08-2005, 01:51 PM   #4
J32a2OwnsU
Resident Old Man
Car: UA5
Power: 265 HP / 234 TQ
1/4 Mile ET: 14.700 @ 0.00 MPH
View/Rate My Garage
Where is the article.. all I see are replies.........................
J32a2OwnsU is offline   Reply With Quote
Old 11-09-2005, 04:11 PM   #5
c_diddy
c_diddy's Avatar
Car: sea turtle
View/Rate My Garage
if you haven't changed yours yet, then i would recommend changing it the next time you do an oil change. some symptoms would be "bad gas mileage, low idle, and stalling" -gabebauman. but if you really want to know if it's bad, you have to shake it to see if it rattles or not..if it doesn't replace it, although if you're already doing that then just replace it anyways lol.
Old 11-09-2005, 04:12 PM   #6
c_diddy
c_diddy's Avatar
Car: sea turtle
View/Rate My Garage
hmm...that's wierd, i still see it ...
Old 11-10-2005, 10:24 AM   #7
dchec
dchec's Avatar
Car: 93 civic lx
View/Rate My Garage
cool..thanks for the info .i'll be sure to change it next oil change...i just did on so it probably wont be for another 30r 4months or so when it gets warmer outside...but i will definitely change it.....
Old 11-17-2005, 09:23 PM   #8
2kstreetcivic
Runnin to Redline
2kstreetcivic's Avatar
Car: 00 MR EJ8
View/Rate My Garage
I did a PCV valve change about 2 weeks ago and my car runs SOOO much smoother and I am getting better MPG.....its a MUST do if you have never done it...you can do it without taking the oil filter off, I did it that way, but its frustrating and takes a little longer...gotta have the right angles...
2kstreetcivic is offline   Reply With Quote
Old 11-17-2005, 10:05 PM   #9
EXSpeedAddict
POWERTHIRST!!!
Car: 00 FBP EJ8
View/Rate My Garage
hit the view article button above the first comment.
This is not a signature.
EXSpeedAddict is offline   Reply With Quote
Old 04-13-2006, 10:32 PM   #10
nightryder99
Gold Member
nightryder99's Avatar
Car: honda civic si 99
View/Rate My Garage
did mine today..with the oil change for less hassles in finding angles plus i was due
well didnt notice anything about smoothness ..im guessing it was still decent but I've heard that its good to change it after 60 000 km
it was a bitch to remove the rubber was so dry that it receded on the plastic hose ... a chunk broke the pcv broke before i got to remove it
other than that ..wtv is good for the engine...
Bacardi cola
Do it ... Just Do it
Who needs Bz when you can have turbo Dz????
nightryder99 is offline   Reply With Quote
Old 05-02-2006, 09:57 PM   #11
Rayden
All Stock....For Now.
Rayden's Avatar
Car: 96 Civic Ex
Power: 93.0 HP
View/Rate My Garage
Ok maybe its just me, but if you replaced the valve from the hose on the Intake...what was the point of going under the car with the flathead...Maybe I missed something. I dont quite understand the first couple of steps. ??
Rayden is offline   Reply With Quote
Old 05-03-2006, 01:31 AM   #12
Wolfy
Raff out roud
Wolfy's Avatar
Car: 98 Toyota Levin BZG
View/Rate My Garage
Holy thread resurrection, but thanks anyway, I was eventually going to ask someone about this... relating to the stalling symptom, if you have an auto, instead of stalling out, will it just hesitate when you step on the gas? Sometimes mine feels like that.
The Last To Let You Down
USMC ALSS - HMM-265, MAG 36, 1st MAW, Okinawa, Japan
| CCCC #007 - VSMC #004 - CCMC #005 - 2003C #010 |
Wolfy is offline   Reply With Quote
Old 05-03-2006, 02:30 AM   #13
c_diddy
c_diddy's Avatar
Car: sea turtle
View/Rate My Garage
well, first the hose is connected to the intake manifold. the valve is under the intake manifold, not connected to the intake. if you don't understand the first few steps, you should go try to pull out the pcv valve with out getting under the car; you'll see why . it's hard to reach under there and the valve sort of snags when you pull on it.
I'm not sure...are you misfiring? bump for an answer though...but it might be easier if you made a thread about it.
Old 05-08-2006, 04:05 PM   #14
Wolfy
Raff out roud
Wolfy's Avatar
View/Rate My Garage
Well I just replaced mine with a $2 autozone valve... God DAMN what a difference. Thanks for the write up
Oh and what kind of pussy needs a screwdriver to pry it out... I pulled that SOB out with the oil filter still in
Old 06-12-2006, 05:55 PM   #15
oc_civic
#2
oc_civic's Avatar
Car: 1991 Mustang LX
View/Rate My Garage
agreed cant believe the difference!
oc_civic is offline   Reply With Quote
vB code is On
ClubCivic.com Merchandise Free Overnight Shipping on Competition Clutch Products Save on AEM UEGO Widebands Skunk2 Camber Kit Sale
Find this site helpful? Donations are appreciated.
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
