Search:
Welcome to ClubCivic
How To Remove Intake Resonator
Responding Members:
User Tag List
Old 11-13-2003, 08:49 PM   #1
VTEC FaNTaSIeS
Default How To Remove Intake Resonator
Whassup.....I'm gonna take off the resonator for a civic ex 2000 ....how many bolts are there....how do i completely take it out....I've never heard of anybody doing this so i thot i would be the first
THANKS-
VTEC FaNTaSIeS is offline
Old 11-13-2003, 08:52 PM   #2
96greencivic
#1 in the Atlantic!
96greencivic's Avatar
Remove bumper
undo about 4 bolts
carefully pry it out!
96greencivic is offline
Old 11-13-2003, 09:35 PM   #3
Bangin' HB
surfing member
Bangin' HB's Avatar
4 bolts on 6th gen, damn. 1 bolt on the 5th gen and i just yanked the b**** out (well, my brother-in-law yanked it when i wasnt looking)
reppin the Teal Hatch Cult@civichatchback.com
"Save a wave, ride a surfer!"
Bangin' HB is offline
Old 11-13-2003, 10:46 PM   #4
VTEC FaNTaSIeS
so did it make any difference at all???
Old 11-13-2003, 10:59 PM   #5
Handlebars
None Taken.
Handlebars's Avatar
i have a how- to in the how to section that will show you everything you want to know, search for it.
Handlebars is offline
Old 11-14-2003, 01:00 AM   #6
phan
there aren't any real performance gains, but you get more of a throaty intake sound after it's removed.
phan is offline
Old 11-14-2003, 06:55 PM   #7
VTEC FaNTaSIeS
but if it's a resonator which slows down air which is passed to the intake then wouldn't you gt a little bit of a hp gain???
Old 11-14-2003, 07:02 PM   #8
VTEC FaNTaSIeS
And....do you think it would make the vtec any louder???
Old 11-14-2003, 07:21 PM   #9
96greencivic
#1 in the Atlantic!
You're not going to hear much Vtec in a SOHC.
You are just going to get a little more throaty noise at open throttle.
I have an Injen SRI in my D16Y8 and I didn't notice much. Sounds good though
Old 11-14-2003, 08:12 PM   #10
phan
exactly.
phan is offline
Old 11-18-2003, 02:41 PM   #11
chimchim
iVTEC, do you?
chimchim's Avatar
I didn't have time to do a full CAI install in one sitting so I pulled the resonator box first, and installed the CAI a few days later.
Pulling the resonator box seemed to actually make me lose low end, and didn't do crap at the high end (except make the rumbling noise as I was throttling and not going anywhere).
My experience: don't pull the resonator box unless you're installing a full CAI.
It seems that the most restrictive part of the stock intake is the filter box. The resonator box isn't actually in the path of the air... the lower intake tube just opens up to it on the side, but the real air flow doesn't actually go into the resonator. I think this is why there really isn't that much restriction due to the resonator and lower tube.
chimchim is offline
Old 11-18-2003, 02:48 PM   #12
chimchim
iVTEC, do you?
chimchim's Avatar
BTW, here's more description on removing it:
1) Remove bumper:
There are several plastic pin/clips along the top of the grill/bumper. Pry up the center with a screwdriver and the center pin will come out, relieving pressure on the outer ring of the plastic clip. Pull the ring out.
Unscrew 1 screw at each wheel well holding the bumper on.
Go under the bumper and unscrew 3 screws.
Pull bumper cover straight off.
2) Loosen splash guard
The plastic splash guard is held by 3 bolts. Only unscrew the one to the far right of the car (the intake side). The plastic is flexible enough.
3) Loosen wheel well guard
The plastic wheel well guard is also attached to the frame near where you took off the splash guard bolt. Unscrew this part. The guard is also very flexible.
4) Remove resonator
Remove 3 bolts: one at the side pointing out, one under the box, and one on the side pointing in just under the coolant resevoir.
Bend the splash and wheel guard back a little, and work the box out.
chimchim is offline
EX Intake Resonator NaptownHonda01 Tech Archive (No Posting) 9 04-26-2007 10:32 PM
Intake Resonator NaptownHonda01 Tech Archive (No Posting) 5 04-15-2007 09:44 PM
How to remove resonator (airbox) from stock intake TilhasBB Tech Archive (No Posting) 20 07-08-2006 03:21 AM
Remove Ehaust Resonator? or not?... kawzhavok Tech Archive (No Posting) 19 03-16-2005 12:36 PM
uninstalling resonator for intake VTEC FaNTaSIeS Tech Archive (No Posting) 0 11-13-2003 08:45 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
